(#526)
Bullitt1841's Avatar
Default 05-06-2015, 09:23 PM
Originally Posted by Duperstar
I have a 535 but on my car. 4,4 and 4,5 are reversed for some reason.
For me, 4/4 and 4/5 seem exactly the same. Have had the JB4 for quite a while and never run into this issue. Even with the BMS Cobb flashes.
sch4400 sch4400 is offline
Car: 08 535i
Default 05-07-2015, 01:25 PM
got code 30FE and 3100 on 08 535i.
delete them code and just pop up again when crusing.
never got them code before mhd flash.
so what should I do ?
DV135i's Avatar
DV135i DV135i is offline
Default 05-07-2015, 02:00 PM
So if we already have the car flashed with the bimmerboost bms flash do we need to flash back to stock first or can we just flash the mhd map right away?
~MHD Stage 2+~3.5 Bar Tmap~PR Ignition Kit~VTT Inlets~VTT Cast Valve Cover~VTT Dual CC~XClutch Twin Disk~BMS Short Shifter~ER Competition FMIC Kit w/ HKS SSQV~3"AR DP's~3" Custom exhaust~Fuel-It Stage 2 Bucket~
Digitalism Digitalism is offline
Car: BMW 335i
Default 05-07-2015, 11:59 PM
You can flash using MHD straight away.
Russjonesr's Avatar
Car: Bmw e92 335i
Default 05-08-2015, 02:55 AM
Which flash are you using and what are you mods...
Russjonesr's Avatar
Car: Bmw e92 335i
Default 05-08-2015, 03:05 AM
See...
http://www.n54tech.com/forums/showpo...&postcount=266
Car: 08 535i
Default 05-08-2015, 08:57 AM
Thanks.
Default 05-08-2015, 09:08 AM
Nobody else is having this issue with the CANflap being always open?
Default 05-08-2015, 11:56 AM
Added MHD 5/7/15 maps to the first post.
enrita's Avatar
enrita enrita is offline
Default 05-08-2015, 12:40 PM
why reverting back to oem vanos tables?
07 335i AT - MOTIV 750 - MHD BMS E85 Flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
Default 05-08-2015, 12:47 PM
Anything to do with post-shift overboosting?
Spxxx's Avatar
Spxxx Spxxx is offline
Car: E92 335i
Default 05-08-2015, 12:48 PM
I am getting some over boosting but I'll live with it as the perfect timing is worth it. I need to do some V dyno runs and test but it feels better post shift with the increased intake Vanos changes
Default 05-08-2015, 12:49 PM
Spent some time on the dyno last week and decided the original Cobb values just provided the best all around performance. Even with single turbos. Your mileage may vary.
Default 05-08-2015, 12:50 PM
Just keep the old backup file and you're good to go. MHD doesn't do or require backups.
leppacan leppacan is offline
Car: 2011 BMW 335is
Default 05-08-2015, 05:55 PM
Terry do you have any ila0s versions for the 335is? I just went through the zips and didn't see them.
BeGooD69 BeGooD69 is offline
Default 05-08-2015, 10:38 PM
I'm running the original bb flash. Is MHD a better flash? Should I go MHD vs original, why? Sorry if it was already answered.
I'm running a 07 BMW 335i with at 6466g2div full bolt on and e85 100% and PI
jordan313 jordan313 is offline
Default 05-09-2015, 09:01 AM
flashed the new pump flash. so much smoother down low
dreptroman dreptroman is offline
Default 05-09-2015, 12:06 PM
Will be installing catlesa DP next week. that is all I will be installing for now.
which map should I install?
We run on 100 octane Gas here (Europe).
Thx
bnk bnk is offline
Default 05-09-2015, 12:22 PM
Thx
100 Oct RON in Europe corresponds to around 94-95 oct AKI in the US.
Default 05-09-2015, 12:48 PM
Run the pump flash, then adjust boost accordingly if you have a JB4.
nyt nyt is offline
Car: 335ix
Default 05-09-2015, 01:29 PM
So when modifying your own base maps with the values from these, for US cars, should we copy the map max voltage, or leave that as what was in the factory bin? Thanks.
Default 05-09-2015, 02:01 PM
I would copy over every value.
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 05-09-2015, 02:13 PM
For the latest MHD BMS flash should we use the same xdf file from the BB flash 1st page for the ije0s.xdf?
AWil335i's Avatar
AWil335i AWil335i is offline
Default 05-09-2015, 02:49 PM
I used the updated bin and copied all defined values to my bin and flashed with MHD. I never got this to work previously but it started right up.
07 E92 335I | JB4 G5 ISO | BMS E85 Flash | DCI | BMS *** | Helix FMIC | Alpina TCU Flash | Walbro GLS392 | E70 | 429rwhp/474rwtq
Fast335i's Avatar
Fast335i Fast335i is offline
Car: 07 BMW 335i
Default 05-09-2015, 03:42 PM
could someone direct me to the proper thread where it explains the proper way to flash with MHD....ive heard keep door open....connect battery charger....etc. My battery is brand new would I still need to do that....
There are a lot of threads with different ways...
Step 1: car off ignition off
step 2: connect k+dcan to usb connector to phone
step 3: keep door open?? etc.
step 4: pick your flash and begin? how long SHOULD the process take
Which BMS flash would be best for E60 with 3.5 map sensor....
2007 BMW 335i...M2 exhaust...Macht Schnell DP's...VRSF 7" FMIC...MM Performance inlet system.....VRSF Chargpipe with Tial BOV....MFACTORY LSD....MHD e60. Wedge tunING.........RB Stealths......N20 Tmap upgrade.....Steve Stage 2 450......H&R Race lowering springs...MT ET Streets 265/40/18 rear.....NGK 5992
