Default 04-09-2015, 02:20 PM
Nope these are JB4 maps.
tjobeid tjobeid is offline
Car: 07 335i coupe
Default 04-09-2015, 02:23 PM
is there an improvement from the ms80 bms e85 flash? Im trying to chase Mauricio hehe
EDIT:"Next up we'll procure a FBO car for some addl testing of the same maps"
NVM i guess ill wait
Mauricio @ MMP's Avatar
Mauricio @ MMP Mauricio @ MMP is offline
Car: 335i Cp TiAg JB3 DCI
Default 04-09-2015, 02:47 PM
Nice results Terry! I wonder when full bolt on will start including turbo inlets in that reference Some day in the future I suppose
Stock Turbo 500whp 540wtq with MMP inlets
http://mmp-e.com
  • inlets (high flow and one piece silicone)
  • high flow outlets
  • turbo development
Car: 07 335i coupe
Default 04-09-2015, 02:57 PM
technically it IS A bolt on INTAKE. if they weren't a pain to install for the average guy it would be selling like hot cakes. Most people don't want to get dirty like us!
just_dirty just_dirty is offline
Car: E92 Gulf Livery 335
Default 04-10-2015, 05:42 PM
You can use new or older back end flash maps with the new JB4 firmware and mode 4/2. The option should be set for ANY back end flash map.
Even the old Low Load AT Pump Flash map?
mike082802 mike082802 is offline
Car: vw passat
Default 04-12-2015, 06:51 PM
Dragged our tune only N54 development car out for a little dyno testing today.
The test car is a 2008 135i automatic, 92k miles on the clock, 100% bone stock except for a JB4+flash, DCI, and Fuel-It Stage1. Testing was done on 40% E85.
Firmware used was 28.82 for the JB4, and the flash file is JB4_MHD_I8A0S_E85, which we expect to post later today with the rest of our MHD development files. Note, power will be the same with the BB flash files.
The main purpose was to test out the new back end flash JB4 maps. If you've been following along you know that if equipped with a back end flash map will select 4/2 on the JB4, which alters its map set. Currently the new map 1 targets 15psi, map 2 targets 17psi, and map 7 targets 19psi. These are peak values and taper towards redline. Map 4 targets 8psi across the board for a "stock like" low boost map.
Overall I was happy with each maps performance and did minimal actual tuning on the dyno. This chart gives a nice spread of what to expect with the new maps when running our back end flash, in a tune + intake only environment. Next up we'll procure a FBO car for some addl testing of the same maps.
Also, I did some map 5 development tuning, and will be posting about that later.
just a quick question, is E60 required to run map 7? i see here you are running E40 for map 7 and the logs look good and in the MHD thread you stae the E85 flash should be used with at least E40.
infliktyd135i's Avatar
infliktyd135i infliktyd135i is offline
Car: 09 135i
Default 04-13-2015, 06:03 PM
I was wondering the exact same thing, why do we need only e40 for map 7 now? Maybe its different for a FBO car?
Default 04-13-2015, 06:56 PM
It's a case by case basis now but e40 may work best especially FBO.
K.Jameel K.Jameel is offline
Car: BMW E92 N54
Default 04-14-2015, 05:11 AM
Hi... Iím new for this Terminology; i installed JB4 three months ago.
1- How do i know it's the latest firmware or if there is any update?
3-i'm using map 5 sometime map 2 because i can sense the pulling stronger with map 2 it's okay.
2- What do you mean by ....Flash ?
Thanks.
BMW 335i '08 E92 N54, JB4 G5 IOS, BMS DCI, VRSF ***, BMS-Tial BOV Kit with Chargepipe, VRSF FMIC, BMS Meth Kit, JB4 MHD BEF, BMS PCV valve, BMS OCC. TCU Alpina_B3 Flash, .
Car: 09 135i
Default 04-14-2015, 11:00 AM
Thanks.
I know its a daunting task but you need to read all the sticky's at the top of the n54 section they should answer your questions thx.
mange87a mange87a is offline
Car: 335I
Default 04-16-2015, 08:31 AM
Is i safe to run E40 on map 7 vid E85 flash on a stock car only with DCI and standard fuel-pump?
Car: BMW E92 N54
Default 04-16-2015, 10:10 AM
I know it silly to aks that question what E40 / DCI stand for
thanks.
Car: 2010 535i
Default 04-16-2015, 10:39 AM
thanks.
E40 = 40% ethanol 60% pump gas. DCI = Dual Cone Intake. FBO = Full Bolt Ons.
Cloud9Blue Cloud9Blue is offline
Car: 09 E92 335i
Default 04-16-2015, 10:59 AM
your stock lpfp likely won't be able to keep on map 7. map 1 and maybe 2 should be ok if your pump is healthy.
09 BMW E92 335i: EFR 7670 / Motiv / AP Racing / Wavetrac / TC Kline [Full Modlist]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins
Default 04-16-2015, 05:32 PM
Stage1 and the (leaner) E85 back end flash is normally required for map 7 on e40+.
Car: 335I
Default 04-16-2015, 11:31 PM
Okey thanks for the answer! Can i run E85-mixture on map 1 & 2? Normaly i use map 5 and the race back end flash.
Car: 09 E92 335i
Default 04-18-2015, 11:57 AM
Curious what a FBO (minus meth) car would do with the same flash and jb4 map? Any short-term plan on getting that on a dyno Terry?
Car: BMW E92 N54
Default 04-20-2015, 07:40 AM
Thanks Bro...
knissel's Avatar
knissel knissel is offline
Car: 08 335xi
Default 04-20-2015, 09:26 AM
Terry I am curious what do you think the potential is of a car completely stock on 93 is with JB4 and MHD?
E85 Calculator for Mobile Android iPhone
11.762 @ 118.40 (335xi Stock Turbo WR)(Totalled)
09 335i xDrive Stock (Sold)
12 GT-R BE 800 awhp 9.8 @ 139
TN54's Avatar
TN54 TN54 is offline
Car: N54
Default 05-26-2015, 06:18 PM
I've been running E30 for a while now and still on my stock LPFP haven't had any issues thus far, been running this mix for about 6 months now.
How come you wouldn't suggest Map 7? curious to understand from your prespective.
I'm on FBO on stock turbos and stock H/L pumps
Certified Australian 335i N54 2009 DCT | JB4 | FBO | E85
Default 05-26-2015, 06:21 PM
e30 does not provide enough octane rating to support the aggressive tune setup for map 7. e60 blend or higher would be ideal for that map, or else I'd just stick to map 5.
stanlalee's Avatar
stanlalee stanlalee is offline
Car: 2007 E92 335i 6sp
Default 05-27-2015, 06:36 AM
I was thinking more along the lines of the increased boost (19psi on map 7) would put more taxing demands on the fuel system than it being an octane concern. 19psi in the midrange really isn't overly ambitious on E30-40 if the fuel system can keep up. The E85 flash timing is what 13-14 peak which isn't that crazy with > E30 either. I've been running more timing down low (and up to 13.5 peak) for over a year with E30-40. I'm all stock except 5" intercooler and drop in filter. No corrections now at 117k miles (I don't run 19psi of boost either but 18 tapering to 14 at 6000rpm)
