04-15-2015, 11:55 AM
I usually have to start the app then connect the cable. Takes 1 or 2 tries but it always connects once my tablet recognizes the otg connection.
07 E92 335I | JB4 G5 ISO | BMS E85 Flash | DCI | BMS *** | Helix FMIC | Alpina TCU Flash | Walbro GLS392 | E70 | 429rwhp/474rwtq
Car: 08 135i , 06 325xi e90
04-15-2015, 12:19 PM
Originally Posted by darkrom
DCT?
Na, its AT .... My car is also back to stock turbos , but the RBs are what did the damage for sure
Car: 135i N54
04-15-2015, 12:20 PM
Yeah I figured it had to be DCT or AT, I got nervous because I want to run RBs on my 6MT eventually, but not if it comes with tranny problems. The MT should hold it all day is my understanding.
Car: 07 335i
04-15-2015, 01:11 PM
Correct! Your clutch on the other hand, if stock, will not!
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF DP's, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch, Wavetrac LSD, M3 FSB, M3 Front & Rear Control arms, M3 RSB, M3 rear subframe bushings, M3 guide rods
Car: 2010 BMW 535i
04-15-2015, 04:34 PM
Originally Posted by BostonBeemah
Bad Inpa cable or bad otg cable. Have you used either one successfully before? For the otg just try putting a flash drive on it and making sure the phone can read it. Also what kind of phone because not all androids have otg capability.
Both the INPA and OTG cables are working properly (tested both of them)
Using a Samsung Galaxy (phone) 3 & 5 with the same results. and no phone case. Both phones have OTG capabilities and verified that it was working properly. Anyone using a Galaxy phone?
Any other input?
Car: AW 135i
04-15-2015, 04:45 PM
Any other input?
I have an s4 and a buddy with an s5 and both work fine. I know Samsung have otg capability so that should be okay. Do you you have any other applications that you use the otg cable with ie. Jb4 mobile app, BMWhat app? If so, go to the applications screen in setting and clear defaults for the app so when you connect the otg cable, it will ask you what program to attach the connection to.
RIP 2008 AW/BL 135i
Car: 335xi
04-15-2015, 06:28 PM
^this, the first time you hook the cable up it should ask you what program to link it to... S5 here as well. Works great for me.
Car: 2010 BMW 535i
04-16-2015, 02:42 PM
It does look like the problem is my Cable is the problem I have the Enthusiast and Basic Kits. http://www.bavariantechnic.com/buy.aspx
The funny thing is that this cable works amazingly with the software they provide for testing and running all of the diagnostics.
Can some one recommend me a cable? I did find one on Amazon for $26 http://www.amazon.com/gp/product/B00...f_rd_i=desktop
What do you guys think? or recommend?
04-16-2015, 02:50 PM
~MHD Stage 2+~3.5 Bar Tmap~PR Ignition Kit~VTT Inlets~VTT Cast Valve Cover~VTT Dual CC~XClutch Twin Disk~BMS Short Shifter~ER Competition FMIC Kit w/ HKS SSQV~3"AR DP's~3" Custom exhaust~Fuel-It Stage 2 Bucket~
Car: 2010 535i
04-16-2015, 03:30 PM
Do not get this one from Amazon. It does not work. I bought it and returned it already. It is the white circuitboard type, and we need the green circuitboard type.
Originally Posted by DV135i
This one is the green circuitboard type and is confirmed working by several MHD users. Mine arrives tomorrow from the same seller.
Car: 2010 BMW 535i
04-16-2015, 04:09 PM
OK then. I just purchase this cable.
Car: AW 135i
04-16-2015, 05:45 PM
There's your problem. This app is designed to work with an Inpa cable and not a Bavarian Technic cable like the Bimmerboost app.
I would not recommend anything but the one stop electronics cable. Have heard others have worked but these cables are guaranteed and don't have to worry about it getting interrupted while writing which I've heard some of the cheaper cables have had happen, not specifically with the mhd app, but when using winkfp or Ncs expert.
RIP 2008 AW/BL 135i
Car: bmw e90 335i
04-16-2015, 09:58 PM
Just flashed with my note 3 took 17min,np at all.
R the jb4 backenedflashes on the app itself the latest flashes?
Need4Speed
Car: 2010 E90 335i M-sport
04-16-2015, 10:00 PM
The BMS MHD flashes are on the 1st post of this thread.
Car: E92 335i
04-16-2015, 10:04 PM
FYI if anyone was wondering how the app determines whether or not to do a full flash (9-18 minutes) vs just a write (1-2 minutes) is it looks at the boost ceiling. So always keep your boost ceiling above 1.28 or below 1.28 unless you want to wait for a full write every time you write. Obviously only pertaining to those with custom maps they're building.
Car: bmw e90 335i
04-16-2015, 10:05 PM
So u download from first page into phone and than how do u located the downloaded files with the mhd app?
04-16-2015, 10:56 PM
Once you download the first page zip files. Your phone should ask you if it must extract the files.
From there the app should automatically find the extracted files on your phone.
 537.75HP 540.63TQ
Need4Speed
04-17-2015, 12:19 AM
Or download the file using a computer and then email yourself the flash you want.
Car: vw passat
04-17-2015, 02:54 AM
are you choosing the option you write a custom flash or write a jb4 back end? i've used both.
Car: 07 335i AT
04-17-2015, 04:52 AM
Originally Posted by Cloud9Blue
Does the flasher license that we bought for flashing JB4 backend flash includes the increase in boost ceiling from 18-21 psi? I am planning to go with upgraded turbo down the line, so just wondering.
Any BMS backend flash, including the one for ST owners, can be flashed with the basic flasher license.
I recommend using "Flash JB4 backend". Not much difference now, but that may come. Plus you can do that because you purchased a full $99 flasher license (reduced to $79 during the beta). But the majority of JB4 users will buy the "JB4 backend only" flasher and will only be able to flash a backend by this mean
Martial
Car: 2007 335i sedan
04-17-2015, 05:34 AM
Martial
I purchased the full license for $79. I did not see an option for "JB4 Backend only" to purchase. Is that version not available yet? Is it significantly reduced in price? I don't have a problem purchasing the full license, because eventually I may load custom flashes.
07 335i 6MT- JB4 G5, DCI, VTT Inlets, VRSF ***, 7" VRSF IC, Fuel-it! Stage 2
04-17-2015, 11:11 AM
Martial
In the beta it required me to pay for the higher boost ceiling to flash the backend map. Does that mean I get a refund?
Car: 335i e92
04-17-2015, 11:38 AM
When visiting the MHD "store", it detects the cable, establishes a connection with the ECU (as seen by voltage readout, vin#, and ecu version) but the store is blank. Nothing to purchase.
Xperia z3c running lolipop
Car: 07 335i e90
04-17-2015, 01:04 PM
How many of you are using a battery charger when flashing?
04-17-2015, 02:31 PM
Not for the 2 minute write, but I do for the full writes.
