nyt nyt is offline
Car: 335ix
Question Exhaust back pressure - 11-03-2014, 12:43 PM
Due to suspicion of clogged cats I'm going to hook up a back pressure gauge to my exhaust soon and monitor during a pull. What range would you expect to see here? I imagine it shouldn't be much under ideal circumstances.
Car: guess...
Default 11-03-2014, 02:02 PM
you probably don't have clogged cats. I much more common issue is low exhaust fluid. the symptoms are the same. just fill it to the full line and your done.
Kish2604's Avatar
Kish2604 Kish2604 is offline
Car: E92 335i
Default 11-03-2014, 02:31 PM
Wtf! Exhaust fluid?????? What fluid are you filling in your exhaust and to what level?
Hahahahhahaha...
|RB old gen|Jb4 G5|3" DP's|ER Competition Cooler|ER Charge pipe|Tial BOV|CM Meth Kit|Dual nozzle setup|BMS cowl filters|AFE intakes+scoops|
|BMS low temp oil thermo|MHD flash + coding|HnR Springs|M3 Control arm kit + H&R + Koni|LED Angel eyes+plate lights
nyt nyt is offline
Car: 335ix
Default 11-03-2014, 04:12 PM
Getting consistent and large timing pulls at around 5000rpm across all the cylinders then it recovers around 6000rpm. I've added fuel, removed fuel, pulled timing, etc. Running E70 still seeing it. Can't think of anything else that cause that. Going to hook the gauge up tomorrow and do a pull, just curious if anyone had an idea of the range this should be.
nyt nyt is offline
Car: 335ix
Default 11-03-2014, 06:03 PM
Map 4 with E70. Targeting 13 degrees advance and 12.3 afr. AFR held dead steady here.
I'm hoping its clogged cats, will be an easy fix if so. I've never tested a performance car with this gauge, so not sure what to expect under WOT. It shouldn't be more than a few PSI I imagine.
drfrink24 drfrink24 is offline
Car: FBO 335xi w/FSB 50/50 meth
Default 11-04-2014, 07:27 AM
Sad to see it's more than just cylinder 5 now
You running a SMFW or DMFW? I recall timing problems at high load in some set ups with DMFW.
nyt nyt is offline
Car: 335ix
Default 11-04-2014, 10:30 AM
6AT. Going to go test this in a minute.
Car: guess...
Default 11-04-2014, 10:40 AM
how many miles do you have on the car? i'm assuming you're talking about your two rear cats as you've removed your two fronts when you installed your *********. I've had dirty cats when my stock turbos were going out. they were burning a qt of oil a week. the ECM continuously through codes for inefficient cats(can't remember the codes off hand). I think if you had clogged cats, even alittle, your ECM would let you know. ...did you check your exhaust fluid for contamination? Might wanna just flush it to be safe.
Default 11-04-2014, 02:18 PM
flush it. lol
N54 | Build Thread
nyt nyt is offline
Car: 335ix
Default 11-04-2014, 02:40 PM
61k miles, got it on the lift late, didn't feel like pulling out the ********* to get to the rear o2 sensors, too much of a pita to reach. Yes rear cats. I'm just going to drop the exhaust, cut it, gut them, and then weld it back up soon and see if its any better :/
loesch's Avatar
loesch loesch is offline
Car: 2011 BMW 135i M Sport
Default 11-04-2014, 08:50 PM
While they're off go for a drive and see if that was the problem before going through the trouble of gutting them.
deltalima0's Avatar
deltalima0 deltalima0 is offline
Car: 07 BMW 335
Default 11-05-2014, 03:47 AM
+1
Just unbolt exhaust from cats you do not need to remove the exhaust then go drive, it will be loud but if there clogged the power will be back when you go wot.
2011 335is DCT
Pure Stage 2 Hi-Flo Turbos | PSP outlets | RB Inlets | Wagner Evo 2 intercooler | Wagner Dpipes's | JB4 G5/MHD| Precision Raceworks Coils |PFS Bucketed Double shot LPFP | Phoenix Charge Pipe with Tial BOV | JB4 G5/MHD | BMS DCI's
RIP 2007 E90 335i
Doc Race 6266 Single Turbo | TFT Charge Pipe | JB4 G5/MHD | FuelIt stg 3 LPFP | Cpe/BMS PI | 100% E85 | DSS Axles | Cpe FMIC | Tial BOV
N54 World Record ET: 10.721 | Best MPH 130.92
nyt nyt is offline
Car: 335ix
Default 11-05-2014, 11:14 AM
Originally Posted by deltalima0
+1
The exhaust is solid from the ********* back. No bolts.
Default 11-05-2014, 11:25 AM
I think they're saying go test without the midpipes attached.
N54 | Build Thread
trebila's Avatar
trebila trebila is offline
Default 11-05-2014, 12:28 PM
NYT, according to your logs, your midpipes are not clogged.
if it was the case, you wouldn't be able to reach your boost targets.
just try without your midpipes to be sure(yes, it'd be louder).
deltalima0's Avatar
Car: 07 BMW 335
Default 11-05-2014, 04:39 PM
Just unbolt from the back part of ********* you can leave everything attached back pressure will be released dumping under car from the ********* it will be loud as **** but it will do the trick to check if mid cats are clogged
2011 335is DCT
RIP 2007 E90 335i
nyt nyt is offline
Car: 335ix
Default 11-05-2014, 11:06 PM
yeah, gonna do that soon I think.
Once the car is warm timing pulls are far worse. Going to be silly loud.
