Originally Posted by Socal Hopeless
How would you rate both The blast and the down *****? How's the ass dyno
Thnx
walnut blasting = 0 power. There seemed to be a minor reduction in fuel consumption after, but nothing significant.
***, only had done on saturday. There's an audible noise difference, it doesn't boost as high and i'm throwing 2A87 (exhaust VANOS) codes much easier now - i have switched them around without luck in fixing.
As an indication of my faith in virtual dyno, it shows i make the same power pre-*** as post-***... I also dont want to go to the actual dyno now either as i made 258kw back in august with ambient temps around 11 degrees (Celsius) and i wont see those same temps again as we're coming into mid spring/summer now.
