O2nice's Avatar
O2nice O2nice is offline
Car: 2007 e92 335i
Default Meth solenoid choices - 04-23-2014, 09:42 AM
I currently have a devils own 300psi solenoid and its not compatible with the jb4's fsb. The solenoid draws 4.75 amps and the fsb only has a 3amp fuse. There is an older 250psi solenoid that works fine with the fab but im not sure of the amps on that one. What solenoids are u guys using anlong with the fsb? I dont like the cooling mist solenoid so i didnt get it but now its looking like its my only option.
NJrep335I's Avatar
NJrep335I NJrep335I is offline
Car: BMW 335I
Default 04-23-2014, 09:56 AM
I'm using the DO 300psi solenoid with the FSB and haven't had any issue's. Are you basing you information on Amp #'s or actually having the fuse blow?
I can't see the Solenoid actually drawing the full 4.75amps but I could be wrong.
O2nice's Avatar
Car: 2007 e92 335i
Default 04-23-2014, 09:59 AM
I have had 2 fuses blow on me like right away.. & im basing it by both, the amps and both fuses being blown
NJrep335I's Avatar
Car: BMW 335I
Default 04-23-2014, 10:21 AM
Interesting.. Like I said I haven't had any issue's but, I just recently replaced my 2 yr old Cooling mist solenoid with the DO 300psi one. I'll keep an eye on it for now.
O2nice's Avatar
Car: 2007 e92 335i
Default 04-23-2014, 10:27 AM
If i were u i would check it good. 1 fuse blew in 2 days and the other blew in 1 day. My kit is wired exactly as the diy for the bms kit. I sonce then put a relay between the solenoid and the fsb's ground wire and its working fine. Im just looking for a way to eliminate all the headache.
illrider illrider is offline
Default 04-23-2014, 12:36 PM
I've been running the DO 300psi solenoid with the JB4 FSB as well with no issues...
danzio2020 danzio2020 is offline
Car: E92 335i 6MT
Default 04-23-2014, 01:06 PM
A friend of mine is running the DO solenoid with FSB and there is no issues at all.
