(#501)
alexx alexx is offline
Car: BMW 335I
Default 04-10-2014, 07:36 PM
really looking forward to trying this out!
(#502)
Car: F06 N55 640i Gran Coupe
Default 04-11-2014, 01:06 AM
Hi Dmacpro, do u have the 0-60 program in it?
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS DP n FULL Custom Exhaust
Custom BC forge 18/17 set up
(#503)
Hugo Alvim Hugo Alvim is offline
Car: BMW 320i f30
Default 04-11-2014, 05:11 AM
It´s on Play Store? Can I update firmware with it?
(#504)
N54mike's Avatar
N54mike N54mike is offline
Car: grocery getter
Default 04-11-2014, 06:34 AM
Maybe I need to raise my price
(#505)
LAZ LAZ is offline
Default 04-11-2014, 06:39 AM
Cant wait to try it out!
JB4 G5//BMS DCI//BMS 3" CATELESS DP//BMS Meth Kit//BMS Backend E85 Flash//Alpina B3 Flash//
Walbro 455lpfp//Yokohama SDrive//BMS SLD//N55 Midpipes//Vibrant Performance Resonators
(#506)
aeturbo aeturbo is offline
Car: 07 335i
Default 04-11-2014, 07:21 AM
Awesome to hear! So I was wondering if I buy this, can I use it on both my tablet and phone? I understand it will not be optimized for my Asus transformer. Can I just copy the apk file to the tablet?
(#507)
N54mike's Avatar
Car: grocery getter
Default 04-11-2014, 07:50 AM
Just download it from the playstore on your transformer as well. Google won't charge you twice for it.
(#508)
N54mike's Avatar
Car: grocery getter
Default 04-11-2014, 07:51 AM
This is an N55 JB4 limitation. Ask Terry to enable roadspeed output on it. He will need to release a firmware update for it.
(#509)
Car: 07 335i
Default 04-11-2014, 08:01 AM
Awesome!
Thanks Mike
(#510)
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 04-11-2014, 09:12 AM
0-60 will work with all platforms (once I code it in) because I use GPS Speed from the android device. So if your device supports GPS then it'll work.
Firmware updating is something I'm working on porting over from iOS as well. It will work I just have to code it in still.
(#511)
N54mike's Avatar
Car: grocery getter
Default 04-11-2014, 09:24 AM
Most internal android GPS receivers are 1hz and don't update nearly fast enough for accurate timing. If you add support for an external bluetooth 10hz gps then it would be permissible.
(#512)
Car: 2008 135i
Default 04-11-2014, 09:37 AM
It should be close enough. Especially if you do some math to keep track of acceleration data then you should be able to interpolate the time pretty closely. This is just an estimator anyways. VBox is the way to go if you want anything better than a good estimate. And adding an external GPS would be good, but I think this will work well enough to get you an idea of what your 0-60 is. I just want 2 things from a JB4 firmware at some point. Oil temp and road speed without wasting a Future Use value on them.
(#513)
JonD JonD is offline
Car: F20 N55
Default 04-11-2014, 01:21 PM
What's the current kit price and what does it include?
(#514)
Element's Avatar
Element Element is offline
Car: BMW 135i N54
Default 04-11-2014, 02:53 PM
Originally Posted by CHECKERED
For the amount of money you are asking for an app is a bit ridicules considering you can connect a laptop for free…just saying
...and if you don't have a laptop $27.99 becomes cheap as can be (especially when all the PC app features are replicated). Just saying.
(#515)
N54mike's Avatar
Car: grocery getter
Default 04-12-2014, 01:43 PM
I can agree on that last bit, especially for the N55!
(#516)
09E90utah's Avatar
09E90utah 09E90utah is offline
Car: 2009 e90 xDrive 6MT
Default 04-13-2014, 12:27 PM
Can you read oil temps and does it charge your device when it's plugged in?
(#517)
Car: 2008 135i
Default 04-13-2014, 04:26 PM
You can read oil temp under FP_L by setting Future Use D to 11.
There is a way to charge your device while using OTG, but you have to root your device and use a custom kernel. I'm not even going to try to explain how to do all this, but you may be able to figure it out by googling around.
(#518)
GetSomeE92 GetSomeE92 is offline
Car: '09 E92
Default 04-13-2014, 04:43 PM
So all you need to buy for this to work is an On-The-Go ("OTG") cable to plug into the phone, and then plug the JB4 USB cable into it?
335i Coupe: E85 BB flash, JB4 G5 ISO (map 7), DCI and 60% E85 blend: 11.7 @ 120 mph.
Former Best with JB4 (G4, map 5) DCI and 40% E85 blend: 2009 BMW 335i Coupe: 12.173 @ 109.490 MPH
(#519)
Car: 2008 135i
Default 04-13-2014, 04:44 PM
Yep. Just make sure your device supports OTG.
(#520)
Default 04-13-2014, 04:50 PM
Which part of the week the apps will be ready? Can't wait..
(#521)
Eclaxton Eclaxton is offline
Default 04-13-2014, 06:39 PM
I emailed you.
(#522)
narstune's Avatar
narstune narstune is offline
Car: '11 E90 335i
Default 04-14-2014, 09:52 AM
Just curious, what makes this any better than the Torque app?
(#523)
Element's Avatar
Car: BMW 135i N54
Default 04-14-2014, 10:15 AM
Couple of things:
- With the JB hogging the CAN-BUS your Torque data is likely delayed/interrupted
- Torque does not display some model specific measures (as far as I'm aware) such as High Pressure fueling, JB or ECU boost targets, etc.
(#524)
gbk99's Avatar
gbk99 gbk99 is offline
Car: 2008 e92
Default 04-14-2014, 12:36 PM
Regarding the code reading feature - Can the app read codes in real time and display them as they pop up, let say if I have an issues and the code pops up/engine goes into limp while at wot etc. ??? Also, can you make a video of the app in action, i am curious what the delay is and how it looks like. Thanks.
(#525)
iv55 iv55 is offline
Car: 2007 335i coupe
Default 04-14-2014, 07:18 PM
I've been waiting for this for a long time and I'd gladly pay double if I can run OTG and MHL at the same time. Are there any screenshots in landscape?
Closed Thread
