Car: 2011 335i
03-19-2014, 06:46 AM
Originally Posted by Fmonteiro444
So you don't have this?
Nope. What software is that?
I am using Accesstuner Race. The only torque request map I have is called "Torque Request - AUTO".
It appears to be the same map as your "Torque Request - High"
Car: 2007 335i E92
03-19-2014, 08:12 PM
Originally Posted by ls3c6
I get the 2D59 overtorque and it makes DSC module mad when I use these values in my high% table... I need to figure that out, anyone have any ideas what torque limit is being over reached?
got the same error tonight. adjusted the torque % high like everyone else to fix alpina d mode. flashing back to stock values...
|2007 E92 SGM 335i|
Cobbv3 • BMS DCI & OCC • VRSF *** & FMIC • E85 • Custom Backend & Alpina TCU flash • ER CP • RB PCV+Cap
Walbro 255 • Rohana RC5 19s • Nittos 555 245/275 • Cyba Scoops • LUX V3 • M3 Cowl • ST Coils • LCI Tails
03-28-2014, 09:28 AM
got the same error 2D59 today, and engine went into limp mode.
there is defenitly an issue with this new torque request % (high) map.
I'm going back to stock too.
Car: 09 E92 SG
03-28-2014, 10:29 AM
I haven't had a single issue with mine.
03-28-2014, 11:29 AM
the same for me since 3-4 weeks, until today...
Car: 2011 335xi
03-28-2014, 11:58 AM
Why not just put the values a bit closer to stock, but not all the way back? If it took 3 weeks to get the error then you should be fine if you just drop the values down slightly.
Car: 09 E92 SG
03-28-2014, 11:59 AM
Couldn't you just clear the code and see if it stays away? I've been fine for about a month now.
03-28-2014, 01:38 PM
I've cleared them, everything was fine after, no more code, but it's not right.
03-29-2014, 04:22 PM
Filipe, I've noticed you have not changed your requested torque (driver) map.
Car: 09 E92 SG
03-29-2014, 04:48 PM
No I haven't, only changed the Torque High
04-01-2014, 02:57 AM
I've tried with stock requested torque (driver) values and Steve Kodra's Torque request % (High) values , and this morning, BAM !!, 2D59 again, absolutely no power, very dangerous in the highway.
Had to stop/start the engine.
I'm going back to stock values for those 2 maps.
Car: 2011 BMW 335xi E90 N55
04-07-2014, 07:19 PM
Check this out. I've found that if I modulate the accelerator just right, I can get S mode to shift up on demand. Sounds like a stick shift if you do it just right. After acceleration, cut throttle back about 1/2 abruptly and it shift up, and if you'd like to accelerate in that next gear, punch it!
05-17-2014, 01:48 AM
Filipe, you're running a low load flash, right?
Did you ever get a 2D59 limp mode code?
Car: 09 E92 SG
05-17-2014, 08:16 AM
I am running a low load flash. I never got that code. I've flashed the DME a dozen times since I've changed the requested torque high table and car drives great.
05-17-2014, 09:32 AM
Right, I'm now running a low load flash, and I'll test again this requested torque (high) map again.
Thanks.
Car: 09 E92 SG
05-17-2014, 11:24 AM
Thanks.
Why did you switch?
05-17-2014, 11:57 AM
Flatline timing postshift issue...
The main con' with the low load flash was the mileage.
I'm now trying few things to get better mileage with Terry's AT E85 flash.
Car: 09 E92 SG
05-17-2014, 12:15 PM
I can send you my flash. I get 21-22mpg with a heavy foot.
Car: 09 E92 SG
05-17-2014, 12:36 PM
Email sent.
05-17-2014, 01:54 PM
Thanks Filipe.
Car: 07 335i AT
05-18-2014, 03:29 PM
Did you use wedge's xdf to get a bette mileage thanks to the 3D fuel scalars?
Car: 2011 335i
05-20-2014, 11:15 AM
Has anyone figured out why the 7603527 flash causes the "car on lift" error with some cars?
It happens to me too. Yet I am able to flash Alpina and other just fine...
Car: 09 E92 SG
05-30-2014, 04:32 PM
So it finally happened. I got the 2D59. I have since changed the table back to stock.
05-30-2014, 10:25 PM
did you change your flash recently ?
Car: 09 E92 SG
05-31-2014, 06:08 AM
Yes. I switched to a high load flash.
