03-06-2014, 01:53 AM
Originally Posted by steve.kodra
I don't believe we will ever get the Alpina to act like the 1494 in normal driving conditions. The trick with increasing the "Requested Torque %" tables is going to be our best bet. You are not going to hurt anything by giving it a try. I have done this change on many cars already. IF...the pedal is a bit too touchy for you with the tables listed in previous posts, change the x-axis values as shown below.
Attachment 18217
with my actual IJEOS.xdf file, I can't edit X/Y axis values for the torque request maps under tunerpro.
Car: 2009 BMW 335i xDrive E90 Sedan Auto Trans
03-06-2014, 07:52 AM
Attachment 18217
It would be cool if we could trick the TCU into thinking the car was going slower than it really is. It seems to me that would effectively make the upshift points higher. Since the TCU is on lockdown and encrypted it seems the only way we can get the desired results is by "tricking it" I'm not sure if this is even possible. And even if it was, then we might run into DME and tune issues cause then the DME would be making decisions off false speed data. Anyone know if this is possible to feed the TCU a false lower value for the speed the car is going and feed the DME the real speed?
2009 335i AT xdrive E90 Sedan
Xhp Stage 2
BQ Tuning Custom 93 Octane Tune
FBO + Inlets
03-06-2014, 08:25 AM
the TCU decision to upshift doesn't seem to be speed related.
It's more load related.
Car: e92 335xi
03-06-2014, 09:51 AM
Not sure that is true, seems to always shift to 6th @ 40 MPH in D unless very heavy throttle. Also in Sport, 6th is always @ 74 MPH never less. Some of the other shift points also seem to be keyed to specific road speeds, depending on throttle.
03-06-2014, 10:12 AM
I agree that under higher load, while accelerating, shift points are moved higher based on load (or possibly torque).
However, I'm talking about when under light load or cruising. In these scenarios I see predictable and consistent shift points that coincide with speed. In other words it always goes into 6th gear at 40 mph under light load / cruising. My goal would be to prevent this from happening so that if you're just cruising around 45 - 50 mph you'll stay in 5th gear.
Looks like Ford guys have options for tuning their ZF trannies. Wish we could do the same for more direct control: http://www.chiptorque.com.au/xflash3...ission-tuning/
But maybe there is a way with DME tables we have available to accomplish this? Maybe someone can hack the Alpina flash, modify it, and not run into checksum or encryption issues or maybe that's easier said than done?
Xhp Stage 2
FBO + Inlets
03-06-2014, 12:22 PM
Couldn't have said it better myself and this is exactly the same experience I have.
Xhp Stage 2
FBO + Inlets
Car: 09 E92 SG
03-07-2014, 09:37 AM
Since changing the requested torque table I have found myself switching to DS mode much less. It is a HUGE improvement from before.
03-07-2014, 10:46 AM
Can you show us your "low" map too ?
I 've flashed Steve Kodra Torque request %(high) map, Alpina B3 "D mode" behaviour is better, but still not what I'm expecting.
It's still upshifting too fast in my opinion.
Maybe I should go further with this high map, or do you think I should mod the driver map too, as sugested by Steve to LS3C6 ??
+1 I would like to see the "low" map as well.
Also, for me when I used the modified requested torque (driver) values it introduced some pretty bad boost oscillations. And I didn't see it further helping the D mode behavior more than what modifying requested torque (low) already did. So at least for me I'm sticking with the default values for the requested torque (driver) table.
Xhp Stage 2
FBO + Inlets
03-07-2014, 10:58 AM
It definitely helps and this might just be a placebo effect but I feel like its more eager to adapt too. For example if I'm accelerating briskly and get over 40 mph sometimes the car will hang out in 5th gear until I completely or almost completely take my foot off the gas rather than up shifting to 6th as soon as I get to 40 mph. Also, I feel like, especially if going up an incline, that the car is more eager to downshift as opposed to boosting like crazy at low RPMs in too high of a gear.
Xhp Stage 2
FBO + Inlets
Car: 08 corvette / 06 vue
03-07-2014, 01:16 PM
I get the 2D59 overtorque and it makes DSC module mad when I use these values in my high% table... I need to figure that out, anyone have any ideas what torque limit is being over reached?
Car: e92 335xi
03-07-2014, 03:43 PM
Are you using ATR with Cobb, or some other tuning platform? Would like to try this at some point if it is better than the Cobb linear throttle map I'm using now (vs stock throttle I was using before).
Also unrelated Alpina flash Q. Somebody on another forum claims newer Alpina B4 deletes automatic upshift in M mode, so you can rev to true redline & hold it and not get upshifted @ 6700 rpm. But only with DSC full off. His Q was is that true with the B3 flash, and I can't honestly say I've tried it with DSC full off. Just DSC on or DTC on. Anybody?
Car: 09 E92 SG
03-07-2014, 03:44 PM
Are you using ATR with Cobb, or some other tuning platform? Would like to try this at some point if it is better than the Cobb linear throttle map I'm suing now (vs stock throttle I was using before).
Using TunerPro
Car: e92 335xi
03-07-2014, 03:48 PM
OK thx.
03-07-2014, 04:08 PM
I'm using Cobb ATR and getting the desired results
Xhp Stage 2
FBO + Inlets
Car: e92 335xi
03-07-2014, 04:36 PM
Cool. Thanks. Maybe this will get me off my ass to learn it.
Car: 07 335i AT
03-10-2014, 02:37 PM
Originally Posted by Eleventeen
The Alpina flash can't be installed on build dates below 03/07; how about this software? I'm rolling in an 09/06 build and wondering if I would be able to install it.
Has this question been answered? I have a pre 03/07 so can't flash with Alpina, but I would like to know if other flashes are possible.
Car: 2011 335i
03-12-2014, 05:34 PM
I might be missing something here but my version of access tuner race has two maps for torque request...
Torque Request (AUTO)
and
Torque Request (DCT/MANUAL)
But from what I understand, they should both be the same map. (Torque Request HIGH)
Any insight
Maybe its a N55 thing?
Car: 2007 335i e92 Coupe
03-12-2014, 05:37 PM
If your build date is pre-3/07, you cannot flash your TCM. Period.
03-12-2014, 05:45 PM
I have a 2010 TCM for sale that will enable anyone with a pre-3/07 build the ability to flash Alpina, 1494 or whatever is available for our platform. All you have to do is install it, which is relatively simple, and flash it yourself, if you have the means, or contact Wedge to flash it for you remotely.
Car: 2011 BMW 335xi E90 N55
03-13-2014, 08:27 AM
I just got the Alpina B3 Flash done by http://www.bimcoding.com/ I was too chicken to do it myself, also weeding thru all the posts on it would have taken a while. So far, I am pleased, but I've barely driven it since the flash last night. RPM gauge drops to 0 on manual shift, as reported in other posts. My favorite feature is the indication of what gear you're in. Drive is much the same, Sport is banging, and Manual may be better than a manual shift.
Car: 2011 335i
03-13-2014, 10:06 AM
OK Just a heads up...
Don't use that modified throttle mapping for an N55 car. Just don't.
You might still be able to improve the alpina D mode via throttle mapping, but the mapping provided here must be for N54 cars. On my N55, the car drove like crap.
Car: 09 E92 SG
03-13-2014, 10:52 AM
Did you copy the table from YOUR "Torque Request % (Low)"?
Car: e92 335xi
03-13-2014, 02:37 PM
Isn't the N55 valvetronic? No conventional throttle IOW. Would not be surprised if N54 maps did not work but who knows.
Car: 2011 335i
03-18-2014, 09:53 AM
What? I don't even have that map. I have a "Torque Request - AUTO" map and that's it.
Yeah this is true but the maps we are talking about are in reference to pedal position and requested torque percentage. Both of those should be pretty platform independent.
Maybe I will try to make a linear map and see what happens.
Car: 09 E92 SG
03-18-2014, 11:24 AM
So you don't have this?
