(#7901)
skysurfer's Avatar
skysurfer skysurfer is offline
Car: 2008 535i
Default 10-29-2013, 12:28 AM
Originally Posted by BimmerNFS
No it is removed
Yes
2008 BMW 535i
JB4 G5, BMS Pump Flash, ( Updated FW ), DCI,
Eisenmann Race Exhaust
ER CP
E60 DP
450 HP / 480 TQ ( when running AEM 320, 50% E85 )
https://www.youtube.com/watch?v=51z_sELokzk
Nachos23's Avatar
Nachos23 Nachos23 is offline
Car: about to purchase 09 335i Xdrive
Default 10-29-2013, 05:46 AM
Thanks; I figured as much, but since the general notes still mention it and the picture is still prominently displayed, i thought i should check
2016 335 GT - let the upgrades begin..
2000 Z3M - too many upgrades to mention ... lol
Nachos23's Avatar
Default 10-29-2013, 05:47 AM
Originally Posted by skysurfer
Yes
Now I have a yes and a no.... perfect.... which one is it?
SeaBee335 SeaBee335 is offline
Gettin' There!
Car: '07 335i E92
Default 10-29-2013, 06:29 AM
Open up the case and check it. If it has diodes, cut em and update firmware, then enjoy!
'07 335i E92 - FBO
Nachos23's Avatar
Default 10-29-2013, 06:39 AM
Was hoping to avoid that, but I now want to run USB cable into glovebox as I've d/l the logger app for my Android, so I might just open it and find out...Was hoping if I could get a difinitive answer, I could avoid removing and opening the unit.
I am able to upload new firmware and control the unit through the steering wheel, but I'm not sure if the presence of the diodes will not allow me to upload the firmware, or just that the firmware will not operate as expected with the diodes present.
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 10-29-2013, 06:53 AM
If brand new, the diodes are not installed. I suggest logging with a computer for your first logs.
Also the software revision number will be part of the log file so you can see what file is already loaded.
Nachos23's Avatar
Default 10-29-2013, 07:11 AM
I will run the cable into the cabin and run the logger.... I have successfully uploaded the latest 27.5 firmware and it uploaded fine. Running a P3 Gauge in analog mode. Running Map 5 or Map 1, I can't seem to generate more than 12psi boost. Was thinking the diodes if installed could be preventing it from generating more boost (like the 13 psi in map 1). Haven't finished the mods though; so could be back pressure from running a stock exhaust. Still need to install the AA intercooler and see if that will help. AA Blowoff installed as is the aFe CAI... Was running the P3 in conjunction with the JB4 until 2 days ago, when I read in another thread that they can interfere with each other, so changed the P3 to analog (vacuum).
Default 10-30-2013, 10:04 AM
I've had a couple customers report a map 4 switch when using the 2STEP. If anyone else has that issue email me I'll send you something to test.
Car: 2009 335i AT
Cool 10-30-2013, 07:40 PM
Do a log in third gear from 2.5K to 7k and post in the help section.
muzzammil15 muzzammil15 is offline
Car: 07 e92
Default 10-30-2013, 08:00 PM
I have DCI, and down *****. I have always used map 5. I was wondering if map2 would be better for me then map 5? Any feed back would be appreciated, thank you.
Jnat Jnat is offline
Car: 09 335xi
Default 10-31-2013, 03:51 AM
Have you tried E85? If not, do yourself a favor and try it with map 5, do two or three 2k-6/7k pulls (3rd gear) and feel the GOODNESS. Map 2 will not do what map 5 does on E. With that said, i'm not sure there's much of a difference without E, possibly a slight edge after pulls for map 5. I def can confirm though, if you use map 5 and don't do the adaptive pulls, you are not experiencing what map 5 has to offer.
09 335XI /Cobb ATR TUNED 18.5 psi/DCI/2ND ***** '''''''/E20/Alpina/VRSF 7inch/VRSF Chargepipe with Tial BOV***
Car: 07 e92
Default 10-31-2013, 12:47 PM
How is map 5 without the E85? Would map 2 be more beneficial for me without e85?
ashmostro's Avatar
ashmostro ashmostro is offline
Car: 2013 335is DCT
Default 10-31-2013, 01:03 PM
Map 5 autotunes, whereas map 2 is fixed boost targets. With e85, map 5 will see the lower temps and knock supression and target higher boost than map 2 and theoretically will still remain stable. Map 2 on small amounts of e85 is fine but kind of defeats the whole point of e85.
2013 335is DCT -- Quaife | JRZ RS1 - 450/800# | M3 + Hardrace arms | e93 M3 + Hotchkis f/r sways | BMS CP + OCC | ETS 5" IC | AFE DP's + DCI | RB PCV + Thermo Delete | Setrab + Improved Racing oil cooling | Stoptech f+r BBK | Cobb BQ Tune
Rotary Rasp Rotary Rasp is offline
Default 10-31-2013, 03:36 PM
It seems like my car is boosting almost 15psi when the oil temp is still cold. Is there a setting to disable the jb4 when the oil is under 160 degrees?
BEAR-AvHistory's Avatar
BEAR-AvHistory BEAR-AvHistory is offline
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
Default 10-31-2013, 04:24 PM
Should do it on default unless its been set to water temp.
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
ashmostro's Avatar
Car: 2013 335is DCT
Default 10-31-2013, 08:01 PM
Where is this adjustment? I don't feel like my jb4 is ever off...
Default 10-31-2013, 09:24 PM
With a 335is it's going to run relatively high boost all the time due to the higher factory boost target.
Default 10-31-2013, 10:46 PM
How do I check?
ashmostro's Avatar
Car: 2013 335is DCT
Default 11-01-2013, 01:49 AM
Indeed, Terry but I can feel the difference between a map 1 setting vs a map 2 for example even when the car is still cold. That doesn't seem like the correct behavior, 335is or not... right?
Car: 09 335xi
Default 11-01-2013, 03:45 AM
IMHO map 5 when the adaptation pulls are done are stronger then map 2 on or off E, I can't back that up with data just seat O pants. On E, it's not debatable, the cars a monster with minimal mods.
bigdaddycain's Avatar
bigdaddycain bigdaddycain is offline
I love me some used mods!
Car: nothing at the moment....
Default 11-01-2013, 05:26 AM
If you're running the Flash you WILL see higher boost levels before you hit the 160 temp threshold.
COBB AP|CP-e|ETS|ER|Forge DVs|KW V1|M3 Sways|BBS CH|BMS|
ashmostro's Avatar
Car: 2013 335is DCT
Default 11-01-2013, 08:29 AM
I'm not. Stock 335is code.
Default 11-01-2013, 08:31 AM
ah, but I am running the backend flash. Is there anything we can do to lower the boost when the engine is cold?
335is 7DCT/JB4
Default 11-01-2013, 08:37 AM
Originally Posted by Rotary Rasp
How do I check?
Set speedo 6 @ tach 3. Will flash the turn signals twice when the oil reaches 160.
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 11-01-2013, 08:38 AM
Yes, stay off the throttle!
