I love me some used mods!
Car: nothing at the moment....
10-09-2013, 01:09 PM
Originally Posted by jbelfi76
I have a ton of questions regarding the JB+ Quick Install (N54 Stage 2). I have a 2008 135i M Sport. Is there a page with all these details for that upgrade? I can't tell from the burger tuning site if it has all the same functionality as the JB4 or what it doesn't have. I'm most interested to see what all the different setting equate to, whether they're all safe for the engine which is otherwise stock besides a CAI, whether I can change the mapping using the steering wheel controls like the JB4, etc etc.
The JB+ is just a boost controller and as stated above has NONE of the functionality that the JB4 G4 or the G5 has.
The G5 is the way to go tho...tons of functionality and dataloging as well.
COBB AP|CP-e|ETS|ER|Forge DVs|KW V1|M3 Sways|BBS CH|BMS|
Car: 2008 135i M Sport
ok. but it looks like to really using anything but Map 1, I need to have extra things on my car that I don't have and don't plan on installing. Can't even do Map 2 because I live in CA and can't get 93 Octane.
Map 0: Stock bypass. This is the only map you may use the OBDII diagnostic port with. Set to map 0 before dropping off for service, using a BT, etc.
Map 1: 13psi (suggested for most stock applications)
Map 2: 14.5psi (suggested for those with ********* and 93 octane)
Map 3: Progressive meth mapping with flow sensor failsafe. See guide to enable. Meth use isn't supported/suggested without a flow sensor and map 3.
Map 4: Stock map w/ CAN active. Allows full logging and in dash gauges on the stock mapping.
Map 5: Autotuning map. Boost ranges between 12-17psi based on your cars octane, conditions, and modifications. Fully E85 compatible. If using E85 we suggest around 30% to start. Refer to the E85 FAQ for addl info.
Map 7: Race gas map. 18.5psi peak boost on the G5 ISO. Requires straight 100-104+ RM2 octane unleaded racing fuel. The expensive stuff. We do not suggest using leaded racing fuel. To use this map with E85 requires the BMS E85 back end flash, inline booster fuel pump, and a 60% E85 mix.
Map 8: Economy / Non-Turbo map. Triggers a 3100 "reduced power mode" code while active. After switching back to a normal map you will need to restart
Car: 2010 535i M Sport
10-09-2013, 02:48 PM
Even Map 1 will give you 5 PSI of boost (more than the max the JB+ can deliver), delivery will be smoother, and it's safer for your engine since it does far more than simply increase boost pressure. Map 5 works fine with stock and will auto tune to the highest safe boost. If you're looking for a cheap and easy to install performance mod, buy a used JB+. But if you buy a JB4 G5 ISO, you'll grin from ear to ear every time you drive your car.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
Premium, Value, Cold Weather, Sport Auto, Navigation, Satellite, Logic 7, Comfort Access, Park Distance, Fold Down Rear Seats, Heated Rear Seats, Rear Side Airbags, JB4 G5 ISO, BMS DCIs, ER Charge Pipe, Proform Clear Bra, LUX H8 160 LED angel eyes
Car: 135i'08 mt6
10-10-2013, 06:38 AM
Guys, sorry for stupid question - but FBO and CPS - what are they standing for?
N54 JB4 G5 ISO, BMS flash, cpe *********, cpe intercooler, cpe intake, bms dual cones, tial blowoff, coolingmist meth, hartge catback, derestricted midpipes,bms oilcatch, P3 vent gauge, KW var2, LSD quaife
10-10-2013, 06:59 AM
FBO = Full Bolt On
CPS = Crank Position Sensor
Car: 2009 e90 xDrive 6MT
10-10-2013, 04:35 PM
I've seen some references to a 27.4 G5 ISO firmware but all I see is 27.3. Is 27.3 the latest and greatest?
Car: 09 335xi
10-10-2013, 06:30 PM
Same question?
09 335XI /Cobb ATR TUNED 18.5 psi/DCI/2ND ***** '''''''/E20/Alpina/VRSF 7inch/VRSF Chargepipe with Tial BOV***
10-10-2013, 06:34 PM
Terry is BETA testing the 27.4 firmware and emailing the file to those that are having and issues with 27.3 or any of the earlier 26.x versions. Once he gets good feedback and is happy with it he will post it on the first page of this post.
10-10-2013, 06:53 PM
27.3 is the latest version. We're always testing things on the back end though. If anything comes up better than 27.3 we'll update this thread.
10-10-2013, 10:03 PM
When we have the backened flash should we set the all map afr and cps values to 0?
~MHD Stage 2+~3.5 Bar Tmap~PR Ignition Kit~VTT Inlets~VTT Cast Valve Cover~VTT Dual CC~XClutch Twin Disk~BMS Short Shifter~ER Competition FMIC Kit w/ HKS SSQV~3"AR DP's~3" Custom exhaust~Fuel-It Stage 2 Bucket~
10-10-2013, 11:52 PM
yes
Pessimistic Poster
Car: 135i N54
10-11-2013, 06:08 AM
Yes set them to 0. I noticed fuel open loop changed from 80 to 40 when I did a reset defaults, not sure if that should be changed too? I asked before and no one was sure.
Car: 09 '335i X-Drive
10-11-2013, 05:24 PM
Ya... I have the same question!
10-11-2013, 05:29 PM
Open loop and FF will adjust themselves as needed. 40 is a fine starting point.
Car: 09 335xi
10-12-2013, 04:59 AM
I recently did a couple of third gear pulls map 5 and my open fuel went to 85 along with my wastegate ff adaption going to 98 (running about E25-30). What is that telling me?
10-12-2013, 08:55 AM
Nothing. The JB4 adjusts those fields as necessary for the conditions/fuel/tuning in place.
Car: 07 335I
10-12-2013, 08:05 PM
hey guys new to the forum and bmw I just picked up a 07 335i with 139,000 on it and would like to put a jb4 g5 on it. would this be ok on a motor with such highmilage? I believe it was mostly highway miles if that helps my case any.
Car: 08 E90 335i
10-13-2013, 06:03 PM
Hello Everyone, my first post here. I just ordered the JB4 G5 ISO and was wondering how can I upload the bms backend flash? I will be running e30 or e40 and I have ***, FMIC and DCI (already own a COBB). I tried to search, found how to do the BB backend flash but didn't see the one that can be done via COBB AP. Thank you,
10-14-2013, 04:22 AM
How often does the JB interface get updated? Im currently on 5/13/2013, just wanna make sure its the latest.
 537.75HP 540.63TQ
10-14-2013, 05:03 AM
Not that often. but you should probably upgrade to the latest version in this post http://www.n54tech.com/forums/showthread.php?t=10605 .
10-14-2013, 05:18 AM
Originally Posted by bigdaddycain
Not that often. I think the latest was a June 2013 date though....so you should probably upgrade to that one.
Thank you.
 537.75HP 540.63TQ
10-14-2013, 08:47 AM
Mine says 9/12/13
10-14-2013, 09:13 AM
yeah, I think Terry tweaked it a few times since June. I revised my earlier post.
Car: 335xi Sport
10-14-2013, 12:11 PM
How do you know it didn't have one installed prior to buying it?????
Regardless, I would do it! If it is a 6 speed, you may be needing a new clutch after you mod it......i've got about 130k on mine and been running JB, meth and e85 for quite some time, no worries.
10-15-2013, 11:29 AM
ISO 27.5 Notes
1) Additional mid throttle changes.
2) Corrected a bug for those running the 3.5 bar MAP sensor.
