Administrator
Car: M340i,X5,Raptor,C7 ZR1
09-17-2012, 12:24 AM
That's why it is good to get a BMS Oil Catch Can on there early. Keeps that crap out.
Car: 07 335i
10-24-2012, 08:01 PM
What socket is needed for the crank pulley to turn the engine over.....for hunting TDC?
-Will
AKA Knight F Mohawk
07 335i, JB4, BMW DCI, !*** *********, full !*** exhaust
Car: 2007 E92 335i
10-24-2012, 08:21 PM
-Will
If you are auto, just unplug the coils, and blip the start button. It will just crank for a second (but obviously not start). You may have to do it 2-3 times to get the right cylinders, but this only takes a minute or two. IMO, much easier than trying to turn the crank pulley.
JB4 G5 - BMS DCI - FORGE DV's - ER Chargepipe - BMS OCC - PLM 3" ********* DP's - CPe FMIC - CM Trunk Meth Kit (2.2 gal, CM12) - H&R springs - Koni Yellows - Magnaflow Race Mufflers - Dimisa 4" Tips - Avant Garde M359 - M3 rep front bumper - BMS Angel Eyes - CF M3 Performance Spoiler
Car: 335i 318ti
10-25-2012, 05:23 AM
-Will
7/8" or 22mm. Here's a pic http://www.n54tech.com/forums/showth...light=leakdown
Car: 07 E90 BMW 335i
10-25-2012, 01:33 PM
Just did mine at 107k, def a bad idea to wait this long. Here is a pic of one of my cleaner valves.
Car: 335i 318ti
10-25-2012, 01:38 PM
Pretty good for 107K.
Car: 535i
11-23-2012, 01:26 PM
About to clean my valves, but isn't it dangerous to use a vacuum to suck out the carb cleaner? Flammable liquid + spark from vacuum = big boom?
Also I need advice on how to get the two open valves to close, can't figure out how to do it.
Car: 2007 335i coupe
11-23-2012, 01:35 PM
That's been addressed a couple times in this thread and your absolutely right.
I can tell you that I sucked mine out with a shop vac and used a wore-out sock as a filter on the inside of the bucket just to knock down the mist. I'm still alive but I may just be lucky.
If I were to do it again then I'd probably dilute it with water as I sucked it up like a dentist if that makes sense.
Car: 535i
11-23-2012, 01:42 PM
Good idea I might try that...
So back to the closing the valve dilemma on an automatic, any suggestions?
11-23-2012, 01:46 PM
I pulled the fan to get to the crank pulley. Kinda a pita but it only adds an hour or so
Car: 535i
11-23-2012, 01:59 PM
So if i pull the fan to get to it, what exactly does the crank pulley look like?
Honestly debating if I want to clean 4 of them and be like eff it with the other two lol.
Car: 335i 318ti
11-23-2012, 02:30 PM
Check post #83.
11-23-2012, 03:37 PM
Originally Posted by Vroom
I tapped the start button and it closed perfectly. But much better as you said to take out fan (2 min job) and use the wrench on the crank.
Car: 535i
11-23-2012, 04:32 PM
Would a remote starter kit work? I'd honestly rather spend the $15 than take apart one more damn thing lol.
N54ever
11-24-2012, 01:22 PM
Download the Diy in post one and you can make your own or buy one. But yeah either way works.
Car: m3
12-01-2012, 08:11 PM
dont take this the wrong way- but if you cant figure out how to turn the engine over, you SHOULDNT be doing this, just because you want to save a few bucks.
abrhouston.com
832-797-9114
Car: 08 335i
12-03-2012, 09:30 AM
I'm planing on doing this soon..@53k miles now. But is it nessasary to remove that fuse connector/box that everyone is having trouble removing to clean the valves?
Car: 335 coupe
12-03-2012, 09:52 AM
Yes, You can't get the intake off without getting it off first. It is attached to the bottom of the intake.
Car: 535i
12-03-2012, 12:36 PM
It was a pain in the ass to remove and reattach it, talk about a headache.
Car: 335 coupe
12-03-2012, 12:41 PM
I only reattached it with one screw to make it easier next time.
Car: 08 335i
12-03-2012, 08:41 PM
+1 good idea
N54ever
12-04-2012, 10:48 AM
Wow mine slid right off the rails. No need to remove screws.
Car: 08 335i
12-14-2012, 10:19 AM
Hey guys I need some assistance. I popped off the front o2 sensor clip. Know where I can get one??
12-14-2012, 12:29 PM
the clip that holds the connector to the valve cover or the actual connector on the O2?
Car: 08 335i
12-14-2012, 01:26 PM
The paper clip looking clip that keeps the connector on
