e90man's Avatar
e90man e90man is offline
N54ever
Default DIY Cheap N54 Walnut Shell Blasting - 08-09-2012, 08:34 PM
Here it is. Finally finished. I feel like I'm forgetting something but with 40 slides, I sure hope not.
EDIT: File removed??? You can download one for yourself at www.bimmerhelp.info
If you see anything or have any concerns let me know. So far the only thing I know I forgot to add was that 25 lbs. of fine walnut shells was more than enough to get the job done.
PM me if you would like the high-resolution picture version ~8MB.
I hope this helps anyone interested.
Edit: I am now offering the modified nipples you see in the DIY for $10/each including shipping within the states HERE
Buy other tools related to N54 valve blasting:
www.bimmerhelp.info
ZZ70SS ZZ70SS is offline
Car: 2007 E92 335i
Default 08-09-2012, 08:43 PM
Nice write-up. I just did this a week ago the hard way with purely carb cleaner and brushes.
Similar results, just a little more patience. Luckily my carb-cleaner vacuum bomb didn't explode! lol
JB4 G5 - BMS DCI - FORGE DV's - ER Chargepipe - BMS OCC - PLM 3" ********* DP's - CPe FMIC - CM Trunk Meth Kit (2.2 gal, CM12) - H&R springs - Koni Yellows - Magnaflow Race Mufflers - Dimisa 4" Tips - Avant Garde M359 - M3 rep front bumper - BMS Angel Eyes - CF M3 Performance Spoiler
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 08-09-2012, 09:03 PM
+10 ^
iv55 iv55 is offline
Car: 2007 335i coupe
Default 08-09-2012, 09:13 PM
Wow! Awesome write up. Really well done.
I rotated my motor by removing the fan and putting a wrench on the crank but the starter method looks much easier.
UsualSuspect UsualSuspect is offline
Car: BMW 135i(SOLD STi)
Default 08-09-2012, 09:23 PM
Thank you for this DIY! You put tons of effort into your write up and I really appreciate it.
rudypoochris rudypoochris is offline
Default 08-09-2012, 10:30 PM
Wow pretty awesome right up. Also, looks like a laborious process. I bet after doing this a couple times it goes much quicker though.
e90man's Avatar
N54ever
Default 08-10-2012, 04:11 AM
Thanks for all of the nice comments!
The devil is truly in the details. I spent a lot of time setting up for the project, trying to make sure that I had everything I needed before I touched the car.
The only thing I did "on the fly" was making the remote starter switch. My original intent was to turn the crank pulley with a socket to move the valves, but after seeing how tight the space is, I decided the pushbutton remote trigger was the way to go.
e90man's Avatar
N54ever
Default 08-10-2012, 10:54 PM
So I drove the car to work yesterday (20 miles each way) for the first time since the blasting and wow...the engine is smooth as silk. No exaggeration. Boost comes on faster and is much more consistent, improved lag, less vibration.
Having bought this car with 47k miles and driving it for over a year now, and comparing that length of ownership with the ONE DAY that I've driven it with clean valves really makes me appreciate how the car ran when it was brand new. Only now it runs like new AND has a JB4, so life is good!
If you've been on the fence about whether to do this yourself, pay someone, or just ignore it, I highly recommend you get it done.
jlcolon2001 jlcolon2001 is offline
Car: 335i 2007
Default 08-11-2012, 08:26 AM
Thanks for this great write up OP. A have a quick question for you. Can I use a smaller air compressor like a 10 gallons one, or less? Any way I'll be blasting the valves just for a minute or so at a time. I'm planning to do this soon, but after this I don't see any other use for the compressor. At least a smaller one will occupy less space in my house. Also a smaller one is cheaper
e90man's Avatar
N54ever
Default 08-11-2012, 08:43 AM
I think you have it figured out if you're doing short duration blasting. You may want to work with higher pressure for a smaller tank to get the most velocity out of your media for the short durations.
Let us know how it turns out!
justohigh justohigh is offline
Default 08-12-2012, 09:43 PM
How much would it cost to buy all that is needed to do this?
e90man's Avatar
N54ever
Default 08-13-2012, 08:41 AM
Depends on what your missing obviously. If you have none of it, you might be better off getting a dealer to do it. My dealer does it for about $700.
Car: 2007 E92 335i
Default 08-13-2012, 09:12 AM
If you do it the old school way (search for other DIY's) with just carb cleaner and a gun-cleaning kit, it can be done for about $30.
It's not fun and kinda messy but worth it in my opinion.
It's just really not worth $400-700 to have a dealer do it when you think of what $700 can buy you in go-fast mods for the N54.
Default 08-13-2012, 10:02 AM
I had a couple guys walnut blast it for $320. Well worth it. The biggest part of the job is getting access, taking off the valve cover and putting it back together. I got a new gasket as well, which is a bonus.
My car had 75k miles on it when I did it. The rear valves were surprisingly clean, then got worse towards the front (1/2 and 3/4). This is due to my meth injection having a scrubbing effect!
Car was more responsive afterwards, felt stronger and more even power delivery, especially at low to medium revs.
Dealer quoted me $900 for same job but without new gasket. ($35 item online.)
mrbillytalent's Avatar
mrbillytalent mrbillytalent is offline
Probably being sarcastic
Car: e46 323i & e90 335i
Default 08-13-2012, 01:30 PM
Thank you so much for this write up!
200k mi 99 blk 4dr e46 m52 323i w/ h&r's k&n cai shark'd
95 e36 m3 s50 5spd stg2 turner re11a's autox toy lol
07 BSM 6spd e90 n54 335i jb4 g5 iso ar dp's SPEC 2+ w/ SMFW BMW ssk bms dci RB pcv 455lph lpfp 50% e85 Syn. BOV hijk lmnop
94 e34 530it 290k 350ci sbc tko600 project
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 08-14-2012, 12:09 PM
gasket for what?
Default 08-14-2012, 12:18 PM
Intake valve cover gasket. At some point they start to leak. My other 535 wagon needs one. 79k miles, so it's due.
najin23's Avatar
Car: 335i CDV
Default 08-14-2012, 12:23 PM
I see. Seems like a very intense time consuming diy but a good result. My local bmw shop quoted 495. I may just have them do it when my car reaches around 70k miles, and probably ask them to replace the gasket also.
Thanks.
wtfmarine's Avatar
wtfmarine wtfmarine is offline
Car: 2007 BMW 335i
Default 08-21-2012, 09:18 AM
Awesome write up! My BMW shop nor dealer offer this service so DIY is my only option.
07 335i sleeper - PT5858 single turbo - stock exhaust - stock wheels
mcmn's Avatar
mcmn mcmn is offline
Default 09-03-2012, 12:29 PM
best diy ever.
cwarren's Avatar
cwarren cwarren is offline
Car: 08 335
Default 09-03-2012, 09:22 PM
nice job very well done diy
BMW86 BMW86 is offline
Car: BMW 135i
Default 09-03-2012, 09:37 PM
Excellent DIY
Anyone have the part# handy for the intake valve gasket?
Car: BMW 135i
Default 09-03-2012, 09:40 PM
Assume this it? http://www.ecstuning.com/BMW-E82-135...Cover/ES18623/
e90man's Avatar
N54ever
Default 09-04-2012, 09:12 AM
Originally Posted by BMW86
That's for the valve cover.
There are 6 Oval rubber gaskets that come in a kit for the intake runners.
See Pic.
sammy_0559's Avatar
sammy_0559 sammy_0559 is offline
Car: e93 2008 Montego Metallic 335i
Default 09-12-2012, 02:15 PM
Great DIY!
tried many times to get the wand done right, i was pretty unsuccessful with tapping the adapter using out press drill. so i found this way easier! and it worked!
Bone stock...Car FS
