(#4751)
chris0325's Avatar
chris0325 chris0325 is offline
Car: 08 335xi coupe
Default 07-27-2012, 10:55 AM
Thanks guys sorry rob I didn't see your reply it was under a quote you did of someone else.
chris0325's Avatar
Car: 08 335xi coupe
Default 07-27-2012, 10:58 AM
Originally Posted by steve.kodra
I like 90 as well. On the G5 settings, go to this G5 thread for all you need to know.
http://www.n54tech.com/forums/showthread.php?t=15904
Hey Steve will what I need be more towards the start of the thread. By the way are you the same Steve that had the you tube videos trash talking the single turbo kit. I would much rather to rb's and stay true to the the car.
robc1976's Avatar
robc1976 robc1976 is offline
Default 07-27-2012, 11:40 AM
Originally Posted by mobilefitt
accd to miken54 you still have an issue....
My PWM is at 53 and boost is perfectly on target
chris0325's Avatar
Car: 08 335xi coupe
Default 07-27-2012, 08:23 PM
So I got my jb4 g5 installed today and WOW is all I can say. I can't wait to do more to the car!
aramsey80 aramsey80 is offline
Car: 2007 335i 4dr auto
Default 07-29-2012, 03:27 PM
where is the newest firmware hex file? cant seem to find it. im on 7/1/12 now..
robc1976's Avatar
Default 07-29-2012, 03:33 PM
Email terry to get it
Default 07-29-2012, 07:08 PM
Added 7/22 firmware to first post. No changes from the version I had emailed out to several of you.
7/22 Firmware Changes
1) Made minor adjustment to throttle behavior at lower boost targets
2) Adjusted meth to block meth flow below 3mph for dragstrip launching purposes.
3) Added PID logic to improve low RPM spool speed for higher boost targets.
Default 07-29-2012, 07:09 PM
Added 7/24 firmware to the first post. It's the same version I've emailed to several of you.
chris0325's Avatar
Car: 08 335xi coupe
Default 07-29-2012, 07:23 PM
Is it the same as the 7/1 or should I go ahead and update?
imageautodetail's Avatar
imageautodetail imageautodetail is offline
Car: 335 e90 spt pack 6mt
Default 07-29-2012, 07:31 PM
what are the changes in the firmware, always liked reading the changes on the g4 updates
paf335i paf335i is offline
Car: 07 335i
Default 07-29-2012, 07:33 PM
Thank you terry much appreciated, now just waiting to get my jb4 back from you from the 15ohm upgrade and should be good to go! thanks for everything!
Car: 07 335i
Default 07-29-2012, 08:40 PM
Is it to late to get the g5 ? Looks like thats the way to go and may help my meth WW kit issues I have been having !
Eleventeen Eleventeen is offline
Default 07-29-2012, 09:28 PM
Hey Terry, did you do away with the option to initiate higher boost on water temp instead of oil temp on the newer firmware? I don't see the option any more.
Ferrari Red F80
Default 07-29-2012, 10:01 PM
It's still in the firmware.
I don't do business or 1 on 1 stuff on the forums, but you can always email me !
robc1976's Avatar
Default 07-30-2012, 12:25 AM
It is different and a lot better, update!
1fast1 1fast1 is offline
tryandkeepup
Default 07-30-2012, 04:55 AM
Is this G5 compatible?
2013 SPONSORED BRENTUNING http://www.brentuning.com
infinity's Avatar
infinity infinity is offline
metanol pawa!!
Default 07-30-2012, 05:18 AM
thanks for the new firm.
Time is the best teacher
MathR601's Avatar
MathR601 MathR601 is offline
Default 07-30-2012, 07:38 AM
Is the G5 available for order?
robc1976's Avatar
Default 07-30-2012, 09:35 AM
No, G5 has its own firmware on a seperate sticky.
iv55 iv55 is offline
Car: 2007 335i coupe
Default 07-30-2012, 09:53 AM
+1
Default 07-30-2012, 10:09 AM
Have not been keeping notes on the G5 firmware, sorry. But faster spool up, fixed a couple bugs, changed meth turn on point to more than 3mph for drag launches, etc.
tryandkeepup
Default 07-30-2012, 11:06 AM
I guess it wasn't there last night but I just looked and it is up, thanks..
robc1976's Avatar
Default 07-30-2012, 11:11 AM
I think t got put up today, I ave been running this firmware for 2 weeks....you will love it!
GtiGyver GtiGyver is offline
Default 07-30-2012, 11:15 AM
Hi Terry,
How do you combine features in the FutureUseX options?
eg: FutureUseD --> rattlefix (99) and water temp vs oil temp (100)
