(#4576)
Default 07-07-2012, 02:38 PM
Originally Posted by 2Slow
T, what do you think the scaling should be with dual pumps? Is the idea to decrease the scaling until the meth flow normalizes at some number?
It's not really setup to handle two pumps. But do a log with scaling at 100, email it in, and we'll address your setup offline.
MathR601's Avatar
MathR601 MathR601 is offline
Default 07-09-2012, 08:03 AM
Used to run on about 50/50 E85 and 94 on the new firmware. Yesterday I put straight 91 octane (not by choice). Switched to map 1 to reset the adaptation and did some pulls. I remember on the old firmware map 1 was very similar and sometime better than map 5 in terms of power. I switched to map 5 and felt a significant power increase over map 1 and the boost gauge was also agreeing. So yes map 5 is not only good for E85 and other high octane fuel types.
But still, I can't wait to get my poison back
aramsey80 aramsey80 is offline
Car: 2007 335i 4dr auto
Default 07-10-2012, 08:50 AM
Hey guys I've been running the g5 for a couple of weeks now. I'm starting to notice something strange. With my meth and e85 50/50 mix, when I get to 120+ mph it always throws a half engine light and reduces power. Any ideas?
mykal335xi mykal335xi is offline
boom
Car: BMW
Default 07-10-2012, 08:53 AM
Happened to me this morning, on a long 2 mile uphill section of highway, but I had the same issue a few other times with the JB4. I will try to start a log before I do it again, I hardly ever got that fast so I haven't had a chance to diagnose it. This morning I was just on E85 mix, no meth or nitrous.
2011 335i m-sport
2008 335xi (Sold)
prelude2perfect's Avatar
prelude2perfect prelude2perfect is offline
Car: '07 335i
Default 07-10-2012, 09:13 AM
Just a suggestion but you might want to scan for codes
Best 1/4 ET: 11.4
Best 1.4 Trap: 127.7
PorkchopExpress PorkchopExpress is offline
Car: 08 E90 335
Default 07-10-2012, 09:32 AM
My guess would be code 29f2. Happens to me running the same 50/50 e85 mixture right around that speed. I even set futureuseA=2 and its still happening. I have a 15ohm g4 and was hoping the g5 would cure my problem, but doesn't sound like it will. So for now Ive dropped my e85 mix down to 45/55. Take some logs and check your fuel pressure to see if it goes over 15.
Default 07-10-2012, 09:43 AM
Step 1: read the code?
Caruso0644's Avatar
Caruso0644 Caruso0644 is offline
Car: E92 335i
Default 07-10-2012, 09:52 AM
I have the same issue alway fuel pressure codes... but I believe i need to start doing a 40/60 mix
15' M4 : JB4 : BMS intake : Meisterhaft full exhaust : AR DP's : MSR Charge ***** : H&R Sport Springs / 08' E92 335i : Montego Blue : JB4-G5 : DCI : BMSMeth : BMSoilCC : VRSF DP's : VRSF Front Mount : 19" Vertini Magic : Bridgestone RE-11 : Carbon CSL Trunk Lip : MtechRearBumper : Mtech FrontBumper
sharptech sharptech is offline
Car: 07 335i
Default 07-10-2012, 10:36 AM
check the code like terry said. also if your a 6mt on higher mixes they tend to go lean post shift and the g5 will flash, and if continued going lean and saying on the throttle I noticed my car would just shut off and limp mode as well. happened to me at 130ish.
07 335i 6mt jb5+fbo+e60 12.9@112mph so far
06 c6 vette- sold 13.0@114.5mph
06 evo9- sold 11.5@123
10 genesis-sold slow
04 srt-4-sold 11.6@126mph
chris0325's Avatar
chris0325 chris0325 is offline
Car: 08 335xi coupe
Default 07-10-2012, 11:48 AM
Hey Terry if you are getting ready to purchase a new jb4 from burgertuning.com can it be shipped with the 15ohm upgrade already done or would I have to send back to have done?
robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default 07-10-2012, 12:16 PM
I am about 99% positive they will do it for you.
robc1976's Avatar
Car: 2007 335i
Default 07-10-2012, 12:17 PM
I got them at 50/50 but 45/55 is fine For "my" car.
mobilefitt's Avatar
mobilefitt mobilefitt is offline
M3 Eater (m3eater)
Car: 07 E90 Non Sport...Sleeper
Send a message via AIM to mobilefitt
Default 07-10-2012, 02:17 PM
ALL NEW G4'S COME WITH 15 OHMS..... Terry is doing "freeish" upgrades for those that have 18 now as well. There may be some shipping or handling fee associated with the trade in. There was a post that has details.
JB4 15ohm w/ FSB & CM10, ETS-FMIC, Evolution Race Works charge pipe, Forge DVs, AR *********, Injen dual cones, DIY catch can-vent to atmosphere, Koni FSD,TSW Donnington 18's, Bridgestone Potenza 760 Sports.
triggz triggz is offline
Car: E92 N54
Default 07-10-2012, 05:18 PM
Terry will fix it...scan it...and send logs
JB4 G5 - FBO + Meth - 11.9@119
robc1976's Avatar
Car: 2007 335i
Default 07-10-2012, 05:28 PM
I had one done by Terry and was way better job them what my local guy did lol!!
Ed_Z Ed_Z is offline
Car: 1M
Default 07-11-2012, 03:41 AM
What is futureuseA=2????
My car is doing the same thing?
Wolf's Avatar
Wolf Wolf is offline
Car: 2012 335is
Default 2012 335is Map Questions - 07-11-2012, 08:04 AM
I have a '12 335is with JB4 (6/23) with DCI and am currently running map 2. I was told by Terry that I could run map 7 with race gas that I have access to but I was wondering what map I should run with e85? I have read about map 5 but that wasn't suggested when I asked about my 335is so not sure if map 5 is appropriate for my application and if it is, under what circumstances it is more aggressive than 2 or 7.
Any ideas?
I don't want to get you drunk, but, ah, that's a very fine Chardonnay you're not drinking.
Stranger2k1 Stranger2k1 is offline
Default 07-11-2012, 08:22 AM
more aggressive in which matter? map5 definitely generates more torque on my car than map7 (both with E85 mix).
map5 is still considered the auto-learning map, so there should be nothing to worry about in my oppinion. still would suggest to take a look at the logs for sure.
chuckd05 chuckd05 is offline
Car: 08 135i , 06 325xi e90
Default 07-11-2012, 08:54 AM
Set future use a to 2 but lower your fp mapping in increments of 10, that's what the jb was controlling with fua still on.
I bet that fixes it but def read the code!!
e92
Default 07-11-2012, 08:56 AM
fu a left alone = auto fp mapping
Fu a = 2 = manual fp mapping
e92
steve.kodra steve.kodra is offline
IXLR8
Car: 335xi
Default 07-11-2012, 09:08 AM
What maps are you running?
Wolf's Avatar
Car: 2012 335is
Default 07-11-2012, 10:01 AM
Thanks. Yes, I meant more aggressive in terms of boost along with increases in HP and Torque. Specifically, I was wondering which map provides highest boost, HP and TQ under the following circumstances for the 335is. I understand the choices for the 335i but since Terry didn't mention map 5 to me at all but I didn't mention E85 at the time only 93 octane vs VS100:
335is, JB4 (6/23) and DCI
- 93 octane only
- 50/50 mix of 93 and E85
- 50/50 mix of 93 and VP100
I can run some logs under the 3 scenarios and determine it for my car but just trying to reach out to see if anyone already had the answer so I could save some time.
Default 07-11-2012, 06:13 PM
Support related questions moves to support section.
RBloodscalp's Avatar
RBloodscalp RBloodscalp is offline
Power slide freak
Car: 09 E82 MT6 JB4 ST3
Default map 5 - 07-12-2012, 03:48 AM
I was just wondering...Is it ok to run map 5 on a daily based ?????
If you are not going JUICE BOX then you are going SLOW
[N54 with RB`S, E82 MT, DCI aFe,CHARGEPIPE,SINGLE BOV&FMIC ACTIVE AUTOWERKES, NST CRANK PULLEY, 3' BMS DP, M PERFORMANCE EXHAUST, BMS MCV, BMS OCC, BMS 2STEP, JB4 G5 ISO board BMS Flash at 20.5psi]
mrbillytalent's Avatar
mrbillytalent mrbillytalent is offline
Probably being sarcastic
Car: e46 323i & e90 335i
Default 07-12-2012, 04:42 AM
It's absolutely safe. A lot of members runs map 5 and an e85 mix daily and have had no outstanding issues. I personally do, and I love it. My biggest issue is traction haha
200k mi 99 blk 4dr e46 m52 323i w/ h&r's k&n cai shark'd
95 e36 m3 s50 5spd stg2 turner re11a's autox toy lol
07 BSM 6spd e90 n54 335i jb4 g5 iso ar dp's SPEC 2+ w/ SMFW BMW ssk bms dci RB pcv 455lph lpfp 50% e85 Syn. BOV hijk lmnop
94 e34 530it 290k 350ci sbc tko600 project
