(#4401)
tntman tntman is offline
Car: BMW 135i
Default 06-04-2012, 07:57 PM
We don't get people riding at 280 degrees often, but the logic right now might be too sharp of a transition. E.g. it goes from full boost to stock boost from 280->284 degrees. Maybe it could be smoothed out to 270->290, etc. But either way I think its time for you to consider some cooling mods.
Im having the same ON and OFF Problem randomly but have no temp issues. it never goes above 240-250 degrees. any ideas why this may be happening? no codes by the way.
Default 06-04-2012, 08:51 PM
Maybe your gas cap is loose? Really, I have no idea. If you need support capture it on a CSV log and email it in.
StephenM StephenM is offline
Default 06-05-2012, 11:40 AM
This sounds like the same situation I'm in, possible that you are running lean. I'm also troubleshooting an intermittent fuel mix code getting thrown at idle to low rpm, so your situation could be different. Like Terry said, need to log it.
shuteng486 shuteng486 is offline
Car: 2010 E60 535I
Default 06-05-2012, 03:11 PM
My USB cable was gone after got service from dealer
So i stuck with firmware upgrade since 9/2/11 ?!! something like that... -_-;;;;
jetblack07 jetblack07 is offline
Car: 07 335i sedan sport package
Default 06-06-2012, 03:31 PM
What was the option to have jb4 active when water temp gets to 160 or did you take it away? It sucks having to wait all that time for the oil to heat up.
*****nevermind found it in the release notes********
2007 jetblack sedan
Bms dci, jb4,
Bms meth kit
and raceland dp's
414hp/446tq
infinity's Avatar
infinity infinity is offline
metanol pawa!!
Default 06-06-2012, 11:38 PM
6.3
Time is the best teacher
aussie e88's Avatar
aussie e88 aussie e88 is offline
Car: e88 n54
Default 06-07-2012, 02:17 AM
can anybody help with interface install. i took out old interface downloaded latest but cant get it to install. msg is cant start application in this location because it is already installed from a different location. im stumped and now have no interface. any help greatly appreciated.
jox's Avatar
jox jox is offline
Car: 135 Convertible
Default 06-07-2012, 03:18 AM
Have you uninstalled it correctly under the Add/Remove Programs in control panel? If not, try that first. Otherwise you will have to do a manual uninstall, have a look here: http://stackoverflow.com/questions/1...k-once-clients
If you don't understand the instructions, be really careful or you might mess up your computer completely!
It might also be possible to run the original installer again (thoe one you installed from the beginning) and uninstall from there.
aussie e88's Avatar
Car: e88 n54
Default 06-07-2012, 03:50 AM
jox, thanks for that all sorted. easy when you know how.
chiaobaby chiaobaby is offline
Car: 335I
Default 06-07-2012, 08:19 AM
Hey Terry what happened to the old feature "pedal target" feature in in the firmware it was like the built in throttle controller mapper ??
Default 06-07-2012, 10:20 AM
That was an old JB3 feature. It was removed in favor of static throttle mapping but more variable lagfix.
Default 06-07-2012, 10:37 AM
Originally Posted by blackedout335i
terry? can you answer my question please
If you have some support question you'd have to email in. We don't do personal support on forums.
blackedout335i blackedout335i is offline
Car: 335i e92
Default hey - 06-07-2012, 10:41 AM
i did ! thank you
mykal335xi mykal335xi is offline
boom
Car: BMW
Default 06-07-2012, 09:51 PM
Don't have any at the moment, but 20 are out there in testing now. Will expand that by another 10 or so next week.
I'm sure you're tired of me asking about the G5, but are all 10 spoken for already?
2011 335i m-sport
2008 335xi (Sold)
Default 06-07-2012, 10:28 PM
Not sure at the moment but will sort that out Monday.
rudypoochris rudypoochris is offline
Default 06-08-2012, 07:21 AM
I would like to get on the G5 train as well. =]
Default 06-08-2012, 08:31 PM
Working on making more but keep in mind they only benefit you if running > 18psi. Otherwise there is no reason to use it over the proven G4 15 ohm.
Dirty Dog's Avatar
Default 06-08-2012, 08:52 PM
We know that T. I'm extremely happy with my G4 15 ohm and 5/23 FW. We just like to throw our money your way cause it makes us feel good and hope it does the same to you.
Default 06-08-2012, 09:08 PM
And we're happy to take it but a lot of guys asking for the G5s really have no idea what they are getting in too. This stuff is for experienced users only who want to run a lot of boost and know the consequences.
stilov stilov is offline
Car: 07 335
Default 06-08-2012, 09:10 PM
I'm still trying to figure out if it is worth me getting them if I plan to run e85, meth cm7 and cm10, push the stock turbos all the way (gonna have new ones soon) and some nitrous.
Default 06-08-2012, 09:14 PM
With nitrous you'll need it just for the nitrous trigger, and depending on the shot the on demand CPS.
boom
Car: BMW
Default 06-08-2012, 09:39 PM
Thanks Terry, I appreciate all the hard work!
2011 335i m-sport
2008 335xi (Sold)
Dirty Dog's Avatar
Default 06-08-2012, 10:06 PM
Consequences.......The only consequence I can think of is that the stock turbo's hopefully give way and then it's onto bigger and better things such as RB's. Right or Wrong?
Default 06-08-2012, 10:28 PM
At higher power levels anything from a blown turbo to a cracked piston to everything in between! But as long as you keep a fair amount of taper in the boost curve along with a meth failsafe then something like a +60 additive on map 3 meth+race gas is fairly safe for an aggressive setup. The people who break things normally try to hold too much boost to redline, don't use enough octane to support it, etc.
Dirty Dog's Avatar
Default 06-08-2012, 11:07 PM
Sorry getting a little OT. I agree Terry. I was just taking the piss (joking). Map 3 does have a nice safe taper IMO. I'm on board when it comes to logging and making sure everything looks healthy. If I'm not sure I just email csv's to you. Also in the process of switching all meth fittings to compression so I'll feel better about a 80/20 mix (done the trunk conversion too). Got me a local E85 gas station as well.
NihonX
