(#2326)
GtiGyver GtiGyver is offline
Default 05-10-2011, 10:01 AM
I've been thinking of it. And it would open only at WOT?
Hmmm, I personally see no problem with that. Sure.
Elie335's Avatar
Elie335 Elie335 is offline
;o
Car: E92 335i/320i
Default 05-10-2011, 03:55 PM
Mr. T, again, lol please do not forget about the max cool feature, I'll keep reminding you every single day
themyst themyst is offline
Super Demigod
Send a message via AIM to themyst
Default 05-10-2011, 06:23 PM
Tip-in boost response please thank you!
E90 LCI N54 6AT
Bash Bash is offline
Car: E92- 335i
Default 05-10-2011, 11:22 PM
Yeah, it can get pretty hot in the summers here in the middle east.
telkayat's Avatar
telkayat telkayat is offline
Default 05-10-2011, 11:34 PM
a7la beirut!
saifsiddiqui saifsiddiqui is offline
Default 05-11-2011, 03:46 AM
You know what would be sick. Have the gas thing show HP. Like the Veyrons. Lol
indy99gpgt indy99gpgt is offline
Engineer
Car: 2008 BSM 335i Coupe
Default 05-11-2011, 04:46 AM
Terry, would it be possible to select which DME codes you want to remove instead of all or none? I had a random fuel pump plausibility code pop up along with a half engine light and I cleared the DME. I then took it to the dealer telling them that the fuel pump was acting up and they told me that there were no codes showing fuel pump issues so no replacment until it happens again.
2008 BSM 335i coupe-jb4.BMS intake.meth
1999 Pontiac Grand Prix-10.5PSI.PRJ LL Cam.supporting mods
drfrink24 drfrink24 is offline
Car: FBO 335xi w/FSB 50/50 meth
Default 05-11-2011, 05:39 AM
I would also like this feature, as I also accidentally enabled autoclear with a misfire code, and haven't had one since.
Steveo's Avatar
Steveo Steveo is offline
Humid 535i
Car: 535i
Default 05-11-2011, 08:44 AM
Terry,
Us 5-ers have a useless MPG needle. Any way we could get a hijacking option to allow oil readings on it? I would love to see oil temp and possibly oil pressure somewhere.
-S
bnk bnk is offline
Default 05-11-2011, 01:38 PM
As Themyst suggested, would it be possible to use CPS module to get even more aggressive timing than the max stock timing?
mushu614 mushu614 is offline
Car: '07 e92 335i
Default 05-11-2011, 02:58 PM
Originally Posted by FoShizzle
I switch between maps fairly often, but sometimes it takes a number of tries to get into the command mode via the steering wheel controls. Am I doing something wrong?
I've had this happen on my '07 335 on initial startup, i have to try a few times but after the first time getting into command mode i never have a problem getting in there again on a single attempt.
are you getting something similar?
Default 05-11-2011, 03:00 PM
Sure. We'll have to play with it a bit to see if there is any hidden HP there. Don't get your hopes up though. We've raised timing ~2 degrees over stock using non-CPS methods and not found much on the dyno to justify it.
just2sxy just2sxy is offline
Default 05-11-2011, 03:12 PM
+1
waiting for max cool as well !! =)
+1
i have autoclear enabled so the ******* ******** code doesnt come up, but i had a half engine light the other night and i cant see what codes were there.
Default 05-11-2011, 03:24 PM
Originally Posted by Steveo
Terry,
-S
One of these days. Any oil temp remappings appear in that MPG gauge.
Elie335's Avatar
;o
Car: E92 335i/320i
Default 05-11-2011, 03:43 PM
wtf? a 335i comes with MPG needle? I thought its only for 328 and lower?
kang159 kang159 is offline
Car: 2010 335i Coupe
Default 05-11-2011, 04:06 PM
5er means 5series no?
Elie335's Avatar
;o
Car: E92 335i/320i
Default 05-11-2011, 04:33 PM
didn't read that LOL
GbreeE90 GbreeE90 is offline
Default 05-11-2011, 11:03 PM
If you log JB4 and your IAT's are at 5 on the log. What temperature is that? I dont know the value being used. Thanks
Dirty Dog's Avatar
Default 05-11-2011, 11:26 PM
Your Inlet Air Temperature is between 50-60 degrees.
5=50
6=60
7=70
8=80
9=90
100 + means your F#*KED and you need to upgrade your FMIC
fire_mike fire_mike is offline
Car: '08 E90 335i
Default 05-11-2011, 11:40 PM
5=50
6=60
7=70
8=80
9=90
So with a IAT of 100+ degrees, you are f@cked? I guess I will have to park the car during the summers in AZ. Bummer.
Default 05-11-2011, 11:45 PM
5=50
6=60
7=70
8=80
9=90
Haha, okay thanks man.
Dirty Dog's Avatar
No Mike just do what I did. Run a hose from your washer jets under the hood down to face the IC and put a non drip misting nozzle at the end and spray your IC with water. I've done it and it works.
Car: '08 E90 335i
Default 05-11-2011, 11:49 PM
I'm thinking I'll probably just drive like a normal person (I know - hard to do in a 335), and keep the on the floor to a minimum. I'm sure the car will not blow up if I get on it now and then when the temps are high.
Car: 335 coupe
Default 05-12-2011, 06:38 AM
I dont think 100 degrees is all that bad.
With my fmic now and 80-90 ambient temps, I hit about 115 degrees.
I've seen some logs where a stock i/c was netting iats of 160+
Steveo's Avatar
Humid 535i
Car: 535i
Default 05-12-2011, 07:57 AM
Sorry, Are you saying there is aleady a way to get oil temp on the MPG needle or it would be a future perk if time allows?
