jpsimon jpsimon is offline
Car: 335xi coupe
Default B58 flash tuning details in the next few days! - 07-12-2018, 07:21 AM
Here we go!!
BSM 340i xDrive (6MT, M-Sport, etc)
datazap.me
Car: 335xi coupe
Default 07-12-2018, 07:28 AM
awww yeahhh
With FEMTO OBD Flasher you can easily make Virtual Read of MDG1 ECU directly from OBD socket. No need to remove or disassemble ECU. All operations are easy and safe.
You will get an 8Mb ORI full file that you can tune to your liking: chip tuning, DPF switch off, EGR switch off, catalytic converter removal, Vmax, etc. After applying the new improvements to the ORI file – you can easily write it back by OBD.
No need to think about checksum calculations. Everything is done automatically. Virtual reading is available for all software variants. If we don’t have the file for your car on our server – we will add it in under 24 hours.
Benefits
FEMTO calculates all checksums inside FLASH (also known as CS);
CVN and CALID will be automatically corrected to match stock;
Dealer program ID number remains the same as original;
Date of programming will not be changed;
Open standard .BIN file after Virtual Reading (VR);
Technical support 24/7.
datazap.me
madking187 madking187 is offline
Car: BMW 340i 2017
Default 07-13-2018, 07:04 AM
But still no information about the horsepower they put right?
Probably we need to see that like how Burgertuning proved their tune.
I think BMS team already flashed the engine but doing some testing .
Bullitt already said that indirectly.
Anyways good news!!!
2017 340i M bodykit
mods:
Sport Springs
K&N drop-in filter
VRSF D0wnP!pe
JB4
