Turboh's Avatar
Turboh Turboh is offline
Car: 2017 BMW 340iX
Default B58 User adjustments by Map - 06-13-2018, 12:09 PM
Hi all,
It appears to me that there is a fair amount of uncertainty on which maps are adjustable and how. The going statement is that absolute maps are adjustable and additive maps are not. Yet going through the threads and my own experience here, I would say that is not absolute...no pun intended
Also the logging parameters are also not all used on the B58.
So have looked over my own notes and summarized them in a spreadsheet.
I am hoping this will become a clearer picture for us of what can and cannot be done and how and why.
Please advise where I am wrong, incomplete, and how to make this SS better for us all. Revise as you wish and I will try to combine all your comments into one sheet for all to use.
FUA and FUD need to be detailed further.
Gain, WGP, FF use could stand further explanation too.
Thank you all for your patience,
Alex
File Type: xls JB4 User Adjustments by Map for B58.xls (31.5 KB, 307 views)
jpsimon jpsimon is offline
Car: 335xi coupe
Default 06-13-2018, 12:27 PM
Maybe import it into google sheets? then it can be edited and viewed online easily
/edit/ here's an editable google sheet. Let me know if that works:
https://docs.google.com/spreadsheets...it?usp=sharing
BSM 340i xDrive (6MT, M-Sport, etc)
datazap.me
Turboh's Avatar
Car: 2017 BMW 340iX
Default 06-13-2018, 12:49 PM
Great. I will work on that tonight.
Default 06-13-2018, 02:56 PM
B48/B58 JB4
FUD:
bit0 - Disable in dash BC button controls
bit1 - Disable wastegate adaption.
bit2 - Full time IAT spoof (for testing)
bit3 - Raise "boost over stock" cap from 10psi to 20psi.
bit4 - Disable startup sweep
bit5 - Disable CANbus when boost is less than 1.5psi
bit6 -
bit7 - Force actual boost value out MAP sensor (for testing)
Turboh's Avatar
Car: 2017 BMW 340iX
Default 06-13-2018, 03:32 PM
Got it. But which maps does it work on?
Thanks.
Default 06-13-2018, 04:58 PM
Thanks.
All
Turboh's Avatar
Car: 2017 BMW 340iX
Default 06-14-2018, 04:57 AM
OK. Got it.
Now, which maps does DWP work on and I assume EWG is needed, correct?
Default 06-14-2018, 09:07 AM
OK. Got it.
All maps, and yes EWG is needed.
Turboh's Avatar
Car: 2017 BMW 340iX
Default 06-15-2018, 12:58 PM
Thank you for your patience.
What about Boost Failsafe, PID gain, auto shift boost...do they apply to all maps?
Does FF/waste gate adaption apply only to map 6 and 7?
Does max boost 1,2,3 apply to all maps or only 6 and 7?
Thank you,
Alex
JBoe JBoe is offline
Car: M240i
Default 06-15-2018, 09:03 PM
Subscribed... when done, this is sticky material.
sc67065's Avatar
sc67065 sc67065 is offline
Car: n55
Default 04-12-2019, 01:19 AM
Sorry to revive an old thread, but this seems untrue. The ewg wires seem to only matter on Map 6. Every other map is an additive map and does not require ewg control.
Can someone confirm?
B48Stone B48Stone is offline
Car: B48 330i
Default 04-12-2019, 06:33 AM
B48/B58 JB4
FUD:
bit6 -
May I know how to setup full throttle IAT spoof on Map6 like Map5 does?
I enabled FUD bit2, but it doesn’t work. I know 1, 10 and 70 for 6cyl, but the behavior is not like what Map5 does.
Default 04-12-2019, 06:55 AM
Correct, but there are some additive maps like meth map where you will not reach target boost (depending on additive value) without EWG connector.
What firmware are you on?
Car: B48 330i
Default 04-12-2019, 07:03 AM
I am on firmware 9. I’ve tried FUD bit2 on with 6cyl value 1, 10, 40, 50, 60 and 70. IAT changes immediately after the setting is effective, not like the way map5 IAT changes only during full throttle.
sc67065's Avatar
Car: n55
Default 04-12-2019, 04:47 PM
Are the EWG wires used for maps 1-5 on a b58?
