carguy19 carguy19 is offline
Car: 335 cpe
Default bosch b48/58 ecu/dme finally cracked ? Terry & staff could this be true? - 06-04-2018, 10:54 AM
reputable foreign company claiming to be able to do ecu flashes
see thread below.
Could it be true? Or is it BS?
http://f30.bimmerpost.com/forums/sho....php?t=1495641
jpsimon jpsimon is offline
Car: 335xi coupe
Default 06-04-2018, 11:25 AM
Pro Tuning Freaks posted about it too, it's legit. PTF says they'll be posting up more info soon.
BSM 340i xDrive (6MT, M-Sport, etc)
datazap.me
Default 06-04-2018, 01:37 PM
I hope it's true! The factory flash and internal fuel limiters have really been holding up our B48/B58 JB4 development.
Car: 335 cpe
Default 06-04-2018, 01:56 PM
me too !!
My car could definitely use a few more hp.
Once one company figures it out, it won't take long for BMS to follow I'm guessing.
Wickedowesix's Avatar
Wickedowesix Wickedowesix is offline
Car: 540i G30
Default 06-05-2018, 08:04 PM
Interesting
Jay1312 Jay1312 is offline
Jay1312
Car: BMW 320i and M5
Default 06-05-2018, 11:01 PM
I can see some other tuners being able to flash the ecu on the b48 and now on the mini b38. The mini b38 flash went to 284 hp and 400 nm from stock 192 hp. With the JB4 max hp on map 2 was 236.
Car: 540i G30
Default 07-04-2018, 07:50 PM
Anyone heard any more updates....?
Bullitt1841's Avatar
Default 07-04-2018, 10:50 PM
Just follow Wrench Studios, A2 Performance, and HC Performance on Instagram. They're all working on it together and posting teasers almost daily.
jalkster jalkster is offline
Car: 340i M-Sport
Default 07-05-2018, 05:19 AM
Wrench Studios supposedly has a b58 testing right now.
340i 8AT DME Stage 2 | JB4 | AP Intake | ER ** | Meisterschaft GTC | Ohlins R&T | Ground Control Camber Plates | MP LSD | 437M | RE-71R
RMM RMM is offline
Car: 120i
Default 08-06-2018, 09:41 AM
hey looking at getting flash tuning tomorrow with some local shops that work with tuners in UK, they have stage 1 which is supposed to be 260hp and stage 2 which is 280 hp, looks like stage 1 is running about 18-19 psi and stage 2 is about 20-21 psi. They quote 1.5 bar for stage 2, which does seem high.
Also I do not really understand why they quote 310hp for B48B (330i) variants and 260hp for stage 1 on the B48A (120i) I have, I was under the impression they were the same mechanically, maybe not? I do know that the TMAP is limited to 1.5 bar on mine and that would limit it, that could be part of the limit, does the B48B/C not have this 1.5 bar TMAP if so how they get 310 hp would surprise me without METH.
I am running "modified" exhaust and BMS intake and BMS METH so I was planning on going stage 2 but will also keep my JB4 for data log and fine tune
my question is should I get the higher boost stage 2 tune or stage 1 and just stack boost on top of that with JB4?
when stacking can JB4 also reduce boost form the flash or only add boost?
Car: 335 cpe
Default 08-06-2018, 11:24 AM
mission performance is doing full b58 flash tunes currently.
Im sure all the rest are not far behind.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 08-16-2018, 09:01 PM
Just in time for the new Supra/Z4 to arrive and breath further life into the B58 flash-tuning market.
Herc Herc is offline
Car: F20 125i
Default 08-16-2018, 11:09 PM
is that wheel or crank numbers ?
Car: F20 125i
Default 08-16-2018, 11:22 PM
You mean B48 the b38 does not even get close to those numbers you state...
Car: 340i M-Sport
Default 08-17-2018, 10:09 AM
This is so much more substantial than people are realizing
Default 08-17-2018, 10:24 AM
On the B48 we made ~270hp at the wheels on JB4 map2 with 91 octane with minimal effort. Easily 280-300whp in there with a little more boost and octane.
Default 08-17-2018, 10:26 AM
First thing you have to realize about these flash tuners, they just make up horsepower numbers. Until you see a dynojet showing the power at the wheels from the car whatever numbers they quote are worthless. Any dyno numbers NOT from a dynojet are also worthless.
Once the car is tuned post a log on JB4 map0 (flash tuning) and let's see how they have set it up, and how we can use the JB4 to add more power and/or make the tuning better.
Nugs Nugs is offline
Car: 2011 135i
Default 08-27-2018, 12:30 AM
What if a before and after is done on the same dyno on the same day?
The raw numbers aren't directly comparable to a dynojet but it will show the delta.
eg. I flashed between stock and tuned while still strapped down and went from 300 to 390whp on a dyno dynamics with a stock M140i.
Peter @ Pure's Avatar
Car: F20 M135i
Default 08-27-2018, 12:41 AM
That looks very nice
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Car: F20 M135i
Default 08-27-2018, 12:55 AM
We did 330whp on stock M140 on a dynojet. And 371whp with jb4 map2 on stock car. 98 eu ron.
peter@pureturbos.eu
pureturbos.eu
Car: 2011 135i
Default 08-27-2018, 01:58 AM
That's on Australian 98 ron, Mission Performance tune.
RMM RMM is offline
Car: 120i
Default 09-15-2018, 01:50 AM
Got stage 2 flash tune for my B48 120i
JB4 for fine tune WGDC and METH control
Personally I think this is pretty powerful combo
1) AFR is now 12.5 to 11.5 at WOT
2) DME target is peak of 22.5 PSI
3) Car gear changes are noticeably faster then pre flash
4) Timing lower, 6 deg at 6k RPM, 5 deg at 5k, at 20 psi. Down form 12-15 deg! yet power is same or better, it looks like my 20i engine had way too much timing for the boost I was running.
5) WGDC is low, but I can fix that with JB4, this is probably main issue with canned flash tunes, each car will likely have variation with WG profile, with JB4 we can correct and custom tune it for our cars
Attached a few logs in map 4, and one in map 7 with METH
RMM RMM is offline
Car: 120i
Default 09-15-2018, 06:26 AM
added a little more WGDC, will leave it here for now
Jay1312
Default 09-15-2018, 01:01 PM
B38 runs on the grand tourer and I had mine Dyno at 286 with 400 no torque.
