Turboh's Avatar
Turboh Turboh is offline
Car: 2017 BMW 340iX
Default User adjustment Vs map type - 05-19-2018, 07:49 AM
Hi all,
I keep reading what appears to be conflicting comments about user adjustable settings and what applies to which map on the B58.
1. Which settings can be used to adjust maps 1,2,3,5, 6 additive.
2. Which settings can be used to adjust maps 6, 7 absolute.
3. EWG wire works only on map6 and 7 absolute right?
4. FF wire works on all maps, right?
Please advise and clarify. Thank you.
Alex
JBoe JBoe is offline
Car: M240i
Default 05-29-2018, 09:09 PM
Good questions... bump for some answers.
Car: M240i
Default 06-02-2018, 09:48 PM
Still no reply?
Default 06-02-2018, 10:07 PM
Originally Posted by Turboh
Hi all,
Alex
1- Maps 1,2,3,5 are additive non adjustable maps. Map 7 is methanol adjustable additive map.
2- Map 6 can be used either way depending on how boost in RPM15000 is set. Below 8psi makes it additive, above that absolute.
3- EWG wire is usually used for maps 6,7,8 intended for WMI, large turbo cars, or cars with throttle problems as result of exhaust modificaitons.
4- Yes, correct.
Turboh's Avatar
Car: 2017 BMW 340iX
Default 06-03-2018, 05:05 AM
Just what I needed. Thank you.
Alex
Wickedowesix's Avatar
Wickedowesix Wickedowesix is offline
Car: 540i G30
Default 06-03-2018, 07:53 AM
1- Maps 1,2,3,5,7 are additive non adjustable maps. Map 8 is methanol adjustable additive map.
2- Map 6 is an absolute map.
3- EWG wire is usually used for maps 6,7,8 intended for Methanol or large turbo cars
4- Yes, correct.
Map 8 in B58? Is that new???
Default 06-04-2018, 02:39 PM
Sorry, Map 7 is the Methanol map.
Let me redo this:
3- EWG wire is usually used for maps 6,7 intended for Methanol or large turbo cars
4- Yes, correct.
Car: M240i
Default 06-04-2018, 08:47 PM
Let me redo this:
4- Yes, correct.
When you say "non-adjustable" is that for boost only? I set my map 1 to the default settings in the sticky. In it, there are settings for duty bias and various others. Do they still matter?
Car: M240i
Default 06-06-2018, 10:49 PM
Bump
335xiRT1 335xiRT1 is offline
Default 06-07-2018, 07:00 AM
1,2,3,5 are additive maps, And are pre set maps.
Only thing adjustable on those maps are FOL setting
2017 340i JB4/ BB TBi/ intake
Turboh's Avatar
Car: 2017 BMW 340iX
Default 06-07-2018, 09:00 AM
Regardless of map type, you do need to have the default settings in place for any of them to work. Learned that the hard way.
Turboh's Avatar
Car: 2017 BMW 340iX
Default 06-07-2018, 09:01 AM
Also, the FF wire is very good for all maps.
jpsimon jpsimon is offline
Car: 335xi coupe
Default 06-07-2018, 09:18 AM
What do you mean by that? I just installed the JB4 the other day along with the the bluetooth connect thing. Are the default settings not already in place?
BSM 340i xDrive (6MT, M-Sport, etc)
datazap.me
Default 06-07-2018, 09:28 AM
FF wires are needed to adjust FOL.
jB4 should have everything setup when you purchase with default settings.
Default 06-07-2018, 10:07 AM
Correct.
Turboh's Avatar
Car: 2017 BMW 340iX
Default 06-07-2018, 12:55 PM
Default setting were not in place for me. Had to enter them manually.
Check your log to make sure the default settings are listed in the heading with the right values.
Car: M240i
Default 06-07-2018, 10:06 PM
This isn't making sense. First I'm told simply picking map 1 or 2 is enough. Then I'm told that I have to put in the settings shown in my post above. Then, the statement is made that those settings don't matter in those maps, except FOL. I have the base JB4, no wastegate or fuel control wires, and I'm on map 1. Do I need to input the settings or not? Do they have an effect or not?
Turboh's Avatar
Car: 2017 BMW 340iX
Default 06-08-2018, 12:09 AM
Check Absolute vs additive maps Link under B58. I know it is confusing.
Default 06-08-2018, 05:23 AM
Leave the default settings shown in your post
Use map1,2,3 or 5 depending on how the car runs (datalog to see)
And you’ll be ok.
Car: M240i
Default 06-08-2018, 06:57 AM
I have, many times. It is a bit confusing so I'm asking for verification. I do understand the maps, but want to have a good base point for starting custom tuning.
Car: M240i
Default 06-08-2018, 07:02 AM
And you’ll be ok.
Thank you for the input, but maps 1 and 2 allow no additional tuning according to posts above. I'm in pump gas 91 and can't support map 3 or 5. Thus, I was going to choose map 6 for a starting point. It's an additive or absolute map depending on settings under boost. I just need a solid starting point confirmed.
It appears that copying the default settings to map 6 and setting boost to 3 across the rpm range, would essentially copy map 1. That's what I want to confirm.
Default 06-08-2018, 09:09 AM
Running EWg wires and map 6 absolute values is best for custom tune.
Turboh's Avatar
Car: 2017 BMW 340iX
Default 06-13-2018, 10:29 AM
I still get confused though. Just read a thread on B58 where Terry seemed to say FUA and Gain adjustment could be made. This gets back to what I have asked about earlier, ..............
Which user adjustments can be made for a B58 engine, on additive maps??? Is a listing available?
Terry or anyone, please clarify...
Thank you all
Default 06-13-2018, 10:39 AM
Thank you all
What are you trying to adjust? FUA is only when EWG wires are installed.
Turboh's Avatar
Car: 2017 BMW 340iX
Default 06-13-2018, 12:16 PM
OK. Now will this adjustment work on Maps 1,2,3,5, or only 6 and 7?
