macrorain macrorain is offline
Car: BMW 330e
Default Will AFR via OBD2 still be accurate when using a piggyback system? - 05-17-2018, 12:32 PM
I have a B48 but I guess this forum is okay still.
My question is whether the AFR levels that can be read in real time through the OBD2 with apps like Dashcommand and Torque will still show the correct information even though signals like boost or fuel have been "tampered with" through JB4 or similar piggyback systems?
Thank you in advance for any replies and comments!
Default 05-17-2018, 01:04 PM
Depends on the piggyback and how its programmed. But generally speaking, will be accurate.
If you have those plugged into the obd 2 port the Jb4 will not be using canbus for tuning. So in that case all your readings will be normal. I would just advise to get a data cable to log your car.
Car: BMW 330e
Default 05-17-2018, 01:12 PM
I'm planning on buying the JB4 with the bluetooth add-on, that will give me these readings on the phone right?
So when I get that this question won't be as relevant I guess, but at the moment I have a piggyback from another company (non-configurable except for switching maps), so I was curious to see what that is actually doing with regards to AFR since the car has thrown a few "too lean" error codes on the map with the highest power. I was thinking it could be interesting to get a data log similar to the ones people throw up from the JB4 with the same parameters, and compare, since their tune and different maps have been dynoed.
So it could be an interesting baseline for when I get the JB4 for what to do (or maybe not do), and what it will probably do in terms of power.
Car: BMW 330e
Default 05-18-2018, 03:56 AM
I've now been able to log a run via an OBD2 reader and format both a log file and a graph relatively similar to what people typically upload from the JB4. It includes rpm/pedal/throttle/ecu boost/afr/ignition timing advance.
Not sure on the rules of this forum. This is not logged by the JB4, and the piggyback system isn't JB4 either. Am I allowed to upload this data in this section of the forum for someone to review? I don't expect BMS people to spend time giving feedback on it, but perhaps others will?
The piggyback system isn't configurable, so it's not about going back and forth and dialing it in, just getting some feedback on how it looks.
Bullitt1841's Avatar
Default 05-18-2018, 06:59 AM
Sure, post it up. We're always curious.
You can use data zap for non-JB4 logs.
jpsimon jpsimon is offline
Car: 335xi coupe
Default 05-18-2018, 07:27 AM
You can use datazap for JB4 logs too
BSM 340i xDrive (6MT, M-Sport, etc)
datazap.me
Car: BMW 330e
Default 05-18-2018, 07:45 AM
Cool. So this is from a B48 330e running Map4 from a european piggyback system (not mentioning the name since I have no idea if that's okay in this forum) which on this map gives about 288hp system power, about 227hp from the B48.
The log is from 3rd + 4th gear starting at around 2k in 3rd.
The boost in the graph and log is from the ECU, so it's not actual boost. Not sure how much they are adding in this particular map, probably around 4psi.
included the JB4ish parameters as a CSV.
Also including two graphs, one with 30 on the y-axis (easier to see the afr) and one with 90 on the y-axis so throttle/pedal is also visible.
My interpretation of this is that the AFR is quite lean, but based on the readout from the OBD2, the ECU is actually targeting around 14.5-14.6 even at close to full throttle and high RPMs. Interested in some confirmation that this is actually okay on this platform even on a moderately tuned setup. As far as I understand the ignition advance timing readout looks okay too.
Would appreciate second opinions on this
File Type: csv VT-map4-2018-05-18-0919-3rd-4th-gear-B48-330e.csv (2 Bytes, 60 views)
Default 05-18-2018, 09:00 AM
Sorry not interested in providing any assistance for non-JB4 systems.
Car: BMW 330e
Default 05-18-2018, 09:05 AM
That is fair enough. Allthough if this actually looks too lean, my solution to that problem would probably be to buy JB4
But as I wrote earlier, I'm not expecting you guys to spend time supporting non-JB4 systems - but perhaps someone else reading the forums have some input
