Default Fuel-It! B58 update with Pure Stage 2 turbo - 12-29-2017, 04:04 PM
Hey guys, we get lots of questions about our B58 progress so we thought wed make a post updating everyone on where were at with this platform and what were currently doing.
Weve had our Pure Stage 2 turbo for a while now and no issues. The car is powerful and shows a lot of potential. When we (actually Pure Turbos) installed the turbo a few months ago it did about 540whp at low WGDC but fueling was an issue so we didnt press on. At this time the tuning constraints for timing and fueling are still the biggest issue and boost control is no problem with the JB4. We are continuing to work on the fueling and timing issues with Terry Burger and making progress but as most know, the DME tends to run very lean due to the often low DME BT no matter how much fuel we throw at it.
**** Running lean on low octane fuel can lead to engine damage. This is risky business until we have all the proper tuning tools in place so keep that in mind when cranking up the boost and consider yourselves warned. 😉 *****
We have tried a variety of configurations and have a couple working theories but ultimately were still fighting the DME. At this time we only run race gas (108 octane) and inject Ignite Racing Fuel E98 when testing high boost. We use CM5 nozzles with full PWM pump control via the JB4 at about 30% duty cycle. In the mean time we would not recommend adding a lot of supplemental fueling beyond what is needed to keep trims from maxing out as it does not help. In this case we do not believe more is better and would strongly caution people not to run too large of nozzles or too much PWM. Doing so is counter productive and increases risk, especially if injecting standard gasoline.
As we make progress we will update everyone in this thread. Please refrain from calling or emailing us individually and ask your questions here so everyone can read the responses.
For those that prefer too, we can use this thread to post logs and work on development to keep everything in one place. We'll also share our logs and information as we progress.
Thanks,
Steve
MR@MRAutosport's Avatar
MR@MRAutosport MR@MRAutosport is offline
Car: BMW
Default 12-29-2017, 07:50 PM
Can't wait to see some numbers
Mrpink Mrpink is offline
Car: M140i
Default 12-31-2017, 02:52 AM
Just curious as to why you are spraying ethanol over methanol?
And would you say CM5 are best for stock turbo?
KrS24's Avatar
KrS24 KrS24 is offline
Car: e92 335i
Default 01-17-2018, 05:58 AM
Any updates?
Bullitt1841's Avatar
Default 01-20-2018, 10:44 AM
Originally Posted by KrS24
Any updates?
Yes. Waiting for Steve to post!
Default 01-20-2018, 12:34 PM
We spent some time with the B58 on the dyno yesterday.
Not bad for only 45% WGDC! More to come out of this car as the tuning progresses but as previously mentioned, tuning is still our biggest obstacle. Consequently we were running very high octane fuel since it tends to run so lean.
Specs:
2017 440i
Fuel-It! ethanol sensor
Pure Turbos Stage 2 Turbo
BMS JB4, intake and TBI
Evolutionracewerks
Torco Race Fuels 108 race ⛽️
135idct 135idct is offline
Default 01-21-2018, 06:54 PM
what's the max boost on 93 fuel?
Default 01-22-2018, 11:29 AM
...we don't have access to or run 93 fuel.
Default 01-22-2018, 11:37 AM
Since I forgot to post a log...
As you can see, we are quite lean due to DME BT being way too low despite high IAT spoof. Consequently thus far we have not found the answer to this issue and the search continues! We do NOT recommend doing this and this is why we are running very high octane fuel and keeping trims manageable but at the same time minimizing the amount of fuel we inject via the throttle body.
Default 01-22-2018, 11:43 AM
Attachment 70907
i don't think it's safe to run 500+whp and the AFR 15 maybe more, very high
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 01-22-2018, 11:47 AM
So the fuel system (stock + TBI) could deliver more fuel, but no one has figured out how to get the DME to request the fuel needed - is that accurate?
The B58 TBI - is that a one-off custom piece with 2 CM5 nozzles, if I understood? Do you plan to sell a PI or TBI kit for the B58?
Default 01-22-2018, 03:09 PM
Hence why we keep re-iterating that, why we are running the fuel we are, and why you don't see any 1/4 mile or 1/2 mile runs from us in this car.
We don't know what the stock fuel system is capable of yet as we have virtually no control over it.
We are running TBI (BMS meth with dual CM5's on PWM) but only enough to keep trims from maxing out and forcing us even leaner.
Once we have control over the DME and fueling, yes we will do a kit but at this time, it is pointless. We can throw all the fuel we want at it...over time it won't matter.
LessIsMore's Avatar
Inner Circle Member
Default 01-23-2018, 10:45 AM
Thanks Steve. I know that if anyone is going to figure out the B58, it's you and Terry
Default 01-23-2018, 07:00 PM
I M inluv340 I M inluv340 is offline
Car: BMW 340i FBO WMI
Default 01-24-2018, 08:30 AM
You guys seem to be running leaner with PS2 than what Im seeing with mine. On 93 @18-9 PSI Im highest at lower RPM around 14.3 then a little before 5k dip into the 13s finishing a pull between 13.3-13.8
Default 01-24-2018, 08:35 AM
With meth? Can you post a log?
I have my PS2 in the garage when I find time to put it in.
Default 01-24-2018, 08:54 AM
X98 and 93. I just switched to E20 to get a little more octane. On 93 it gets me closure to ~95.
Default 01-24-2018, 09:13 AM
Log looks good for the B58. Is that one with 93 only or the E20 blend?
Default 01-24-2018, 10:27 AM
E20
Default 01-24-2018, 12:06 PM
DD settings ~15-16 psi
Default 01-24-2018, 08:10 PM
Post the csv.
Peter @ Pure's Avatar
Car: F20 M135i
Default 01-24-2018, 11:46 PM
In those "richer" logs the dme_bt is up as well compared to Steve's log where DME_BT is 7 only. Meaning you are running other part of the AFR table as well where AFR is programmed to be more rich. (but still quite lean)
The B58 would need flashing capabilities to run 12's afr's and also modify the stock fuel injection. I assume when AFR's come down it will also stress the stock fuel system more.
But a PS2 at 15-16 psi must not feel too bad and reasonably safe
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Default 01-25-2018, 06:11 AM
So are we saying 15-16 is max until flash tune if we want to be safe? It feels nice don’t get me wrong but it’s likely putting down the same power as my pure stage 1 at 19-20 psi which kind of defeats the purpose of the upgrade. The car feels amazing at 18-20 and I really have only run it at that a few times but if it’s not safe I can wait. I’d like to be able to run at 18 until flash tune comes out on occasion wondering if you guys think that is relatively safe or if even that would be pushing it too far? Guys are running PS1 at 23-24psi ( not saying it’s super safe). I know the PS2 is pushing much more volume but I can’t imagine 18psi is more than 22+ with PS1?
***e
Default 01-25-2018, 09:27 AM
So are we saying 15-16 is max until flash tune if we want to be safe? It feels nice dont get me wrong but its likely putting down the same power as my pure stage 1 at 19-20 psi which kind of defeats the purpose of the upgrade. The car feels amazing at 18-20 and I really have only run it at that a few times but if its not safe I can wait. Id like to be able to run at 18 until flash tune comes out on occasion wondering if you guys think that is relatively safe or if even that would be pushing it too far? Guys are running PS1 at 23-24psi ( not saying its super safe). I know the PS2 is pushing much more volume but I cant imagine 18psi is more than 22+ with PS1?
***e
I don't think anyone knows what "safe" for this motor is (besides BMW engineers that developed it) because we don't have enough data for what damages it yet. Without data of specific engine wear or failure, "safe" might be 14.7 AFR all the way to redline. This motor is doing all sorts of new, weird things that defy normal logic, and they're still holding together well.
Default 01-25-2018, 09:45 AM
Given that when the BT targets are closer to actual boost the DME runs AFR targets like we'd expect to see, I'd say the BMW engineers agree with us and 14.7 to redline is no bueno.
We are taking precautions with our car so it doesn't hold us back from testing other components such as the turbos, Jb4 boost control, etc. In addition it also enables us to test different tuning techniques to see if we can get past this issue. However, thus far we have not been able to get AFRs and AFR targets consistent so we strongly caution you on not running too aggressively until we do. If you choose to ignore that or justify it in some other way...no problem but that is our official position on the subject.
