jpsimon jpsimon is offline
Car: 335xi coupe
Default B58 - First JB4 Logs, looking for feedback - 06-05-2018, 07:32 AM
Installed the JB4 last night and took it for a spin. Here are a couple logs to get some feedback about the default settings. Looks there are some timing drops but timing doesn't go to 0 or below like i've seen in other peoples logs.
The car is a 2016 340 x-drive, 6MT. Mods are the JB4 + BMS intake. These are on pump 93 octane. Map 1.
3rd - 4th:
https://***********/u/admin/jb4-defa...-11&zoom=13-80
3rd:
https://***********/u/admin/jb4-defa...-11&zoom=15-68
Logs attached
thanks!
BSM 340i xDrive (6MT, M-Sport, etc)
datazap.me
Last edited by jpsimon; 06-05-2018 at 12:21 PM.. Reason: seriously? block datazap?
Default 06-05-2018, 01:07 PM
Logs are good to me! Update to newest firmware so we can see timing in all 6 cylinders.
Car: 335xi coupe
Default 06-05-2018, 02:29 PM
Will do, thanks
datazap.me
Car: 335xi coupe
Default 06-11-2018, 07:34 AM
Attached is another log with the latest firmware. Same thing as before: 93 octane, map 1.
- What kind of boost should I be seeing with Map 1? Here we're seeing a max of 15 tapering to 11.5 in 3rd gear. Is Map 1 normally like that, or are some default settings not correct? It sort of seems like stock boost.
- Timing looks pretty solid but there's a big difference between Ign_1 and all the others. Ign_1 is quite a bit lower. Is that normal?
- AFR's seem pretty good
I feel like I can get more aggressive with things, what do you think?
datazap.me
Default 06-11-2018, 10:17 PM
You can go up to map 2 and see how that does for you. Timing looks okay, I wouldn't worry much about why cyl 1 is off compared to the others.
Map 1 is an additive map so it is +3 psi over stock boost. So if you click DME BT you can follow the boost path we are targeting +3 psi.
Car: 335xi coupe
Default 06-12-2018, 08:35 AM
Is there anything I can do to prevent the throttle closure when shifting into 4th?
datazap.me
Default 06-12-2018, 12:29 PM
Are you talking about shift bog or the slight overboost after the shift. Once you shifted the throttle is closing slightly to keep boost back down to target.
Car: 335xi coupe
Default 06-12-2018, 02:16 PM
Yeah I guess I'm wondering if there is anything to tweak that will help minimize the boost overshoot, thus minimizing any needed throttle closure.
datazap.me
Default 06-12-2018, 05:08 PM
Maybe lower DWP not sure if the EWG wires would help there but I doubt it.
