Hilly550xi Hilly550xi is offline
Car: 2011 BMW 550xi
Default N63 Log - 01-29-2018, 09:00 AM
New to all of this so not too sure what to look at while logging. Any thoughts, suggestions, or whatever else would be much appreciated. Car is a 2011 550xi with Jb4 Beta + BCM running around 20/80 E85/91 mix. Thanks all
Default 01-29-2018, 11:05 AM
Looks pretty normal but trims are maxed out so you are probably running too much ethanol. How does map 2 look?
Car: 2011 BMW 550xi
Default 01-29-2018, 11:09 AM
Havent logged it in map 2 yet. Will do a run and post that up. Thanks for the feedback Steve
Default 01-30-2018, 10:55 AM
Car: 2011 BMW 550xi
Default 02-12-2018, 12:27 PM
Map 2 Log
Default 02-12-2018, 10:36 PM
Set everything to the default values and then take a good 3rd or 4th gear log from 2k to redline at WOT.
http://www.n54tech.com/forums/showthread.php?t=40626
Car: 2011 BMW 550xi
Default 02-14-2018, 12:15 PM
OK - so went back to map 7 and did two different pulls with two different settings.
"All settings zero" spreadsheet is with user adjustment settings at:
Boost Safety - 20
Fuel open loop - 60
All else set at 0
"same as Terry" spreadsheet user adjustment setting the same as on the first page of the Jb4 Beta and dyno forum you send me:
Boost Safety - 20
PID Gain - 10
Auto Shift Boost redux - 60
FF/Wastegate Adaptation - 60
Fuel Open Loop - 60
Let me know your thoughts
Default 02-14-2018, 06:01 PM
Best to do logs in 3rd and 4th gear from 2k to redline if looking to compare settings, review logs, and assist in adaptions.
Trims are still running high/maxing out but other than that don't see any issues.
Car: 2011 BMW 550xi
Default 02-15-2018, 08:39 AM
Got it - I guess I just need clarification as far as what the default settings are. Is the default settings what is shown on the forum you provided right under the dyno numbers Terry posted?
Reason I am asking is that when I installed the Connect Kit and went to user adjustments, the settings shown was different than what was on that page.
Default 02-15-2018, 01:17 PM
Sometimes the install of the connect kit corrupts them, you'll just need to set them back to the default settings in that thread.
