Car: 2018 Audi S4
12-28-2020, 12:19 PM
I have a bone stock 2018 S4 and always fill up 91 (convenient and no 93 near me). Can I safely run map2 or map3? I am gonna slowly upgrade parts starting with the IC and intake but looking like staying stock for a while. JB4 still worth it?
12-28-2020, 12:32 PM
Map 2 is fine for 91. In winter months most cars that send in logs look good in map 3 as well but not for summer. For map 3 you will need to log it though just so we can be sure all is good.
Car: 2018 Audi S4
12-28-2020, 12:56 PM
Thanks for the quick response, George! This is all new to me so sorry for the seemingly basic questions. I see your name referenced all of the time so I'm glad I got an answer from you!
I live in San Diego so the mornings right now are pretty "chilly" 50-60ish but my mid day it warms back up. Would I have to constantly take logs and adjust my map year round?
12-28-2020, 01:39 PM
For warmer CA climate I would stick with map 2.
If you do have E85 available and you want more power you can always run a mix and get significantly more power.
Car: 2018 Audi S4
01-04-2021, 07:35 AM
Hey George - can you confirm what the correct pin is for an E85 sensor connection? I tried pin 14, but that doesn't seem to be working.
I also have meth setup with FSB FYI, but I thought I remember there being a new pin option with a later update.
Also, will I use the e85 gauge once it is setup?
01-04-2021, 08:05 AM
I happened to email you now as well. Sender needs to be 0-5V. Try set bit 1 to on in ethanol setup.
Car: 2020 Audi S4
Issues with JB4 App -
01-11-2021, 03:20 PM
Trying to find out while my phone JB4 App isnt registering any MPH, PSI, or any of a lot of other data. Not logging it and its not moving and showing 0 on the gauges. Can any one help?
Another questions I have is anyone having this issue...
I recently purchased the JB4 group 7 ( App Build 2.4.6 (9432) Firmware version (76/7//7) during install I completely disconnected the battery after waiting for the sleep mode and finished my install. The issues I am having is on Map 1, 2, & 3 while driving on the highway cruising at about 70-75 with a RPM of 2,000 the vehicle seems to be depressurizing or something almost a stutter throwing air almost back through my intake. I am trying to see who all else is having an issue like this. Once I put it on Map 0 it completely stops. It only does this while coasting at the 2,000 RPM.
01-11-2021, 03:36 PM
Not all parameters in the logging is supported with this model. Do you see rpm and AFR moving whilst connected to it at idle?
Car: 2020 Audi S4
01-11-2021, 04:06 PM
No none of that moves at Idle
01-11-2021, 07:04 PM
Ok. Sent you a picture to check the small end of the OBD connection via email.
Car: Audi SQ5 2021
01-16-2021, 01:51 PM
Hi guys, I just connected the jb4 w Bluetooth in my sq52021, my app wont connect to the jb4 it says error please check hardware. But we double check everything and it seems fine. However, I dont see the Bluetooth hardware light on nor the car will start. Any suggestions? Thanks.
01-16-2021, 02:28 PM
Try reverse the install and only leave the two boost sensors connected or even just the tmap connector, its the one with the coloured wires. Lock the car for a while and get back in with ignition on see if it will let you connected. You might have emailed me, if so continue there. If not george@burgertuning.com to trouble shoot quicker.
Car: 2018 Audi S4
01-18-2021, 09:23 PM
Just got my JB4 installed today and did some pulls on map 2 for logs. Currently bone stock and on 91. Does anyone have a guide on reading logs? First time I've ever pulled performance logs on a car and I'm am very interested in learning more about the numbers. I did send George my log for his expert advice. Might need to do more though because after looking at others, I don't think I collected enough data or had the right conditions.
