(#1401)
infinity's Avatar
infinity infinity is offline
metanol pawa!!
Default 02-19-2011, 11:46 AM
Has anyone tried the map 4 and can tell if the consumption is lower?
What quantity about?
Time is the best teacher
tofu tofu is offline
Car: 335i e92
Default 02-19-2011, 11:48 AM
Originally Posted by Kevron
How about that rev-matched down shifting thing Terry, I'm sure you'll get a lot of takers to test it out for you when you get it created....
mm.. and downshifts to first gear instead of second (in M mode) for us auto users
probably not very useful, but it will make the car feel more "pure" for lack of a better adjective
Default 02-19-2011, 11:53 AM
Right now, map 4 is the same as stock in terms of fuel economy. But fixing that is on the to-do list!
fastfreddy fastfreddy is offline
Car: 07 335i
Default 02-19-2011, 11:55 AM
has there been enough data collected on map 5 to say that it is safe to use as a daily driver on car with only JB4 and DCI running 91, or should I stick to map 1 for now?
infinity's Avatar
metanol pawa!!
Default 02-19-2011, 12:07 PM
then, still we donīt use this map to reduce consumption?
Default 02-19-2011, 12:13 PM
It is like running map 0, or your stock tuning. Mileage might be a touch better than the performance map all around if you go heavier on the throttle but for sustained cruising no real change. Yet!
infinity's Avatar
metanol pawa!!
Default 02-19-2011, 01:05 PM
ok, then we must wait it, but it is very interesting, especially for driving city
mikeyt13 mikeyt13 is offline
Default 02-19-2011, 02:09 PM
COnnected and hit upload firmware but nothing happens. Any ideas?
OldBooster's Avatar
OldBooster OldBooster is offline
Car: 2008 135i AT
Send a message via Skype™ to OldBooster
Default 02-19-2011, 02:21 PM
It takes a good while to upload the firmware. Many minutes. Look at the text block at the bottom of your screen, and it will show you the progress. It counts up to about 417 from Zero.
Terry's unmatched dedication to the N54
Held #1 on www.DragTimes.com:
First to run 11.012 @129.30
Byoung8's Avatar
Byoung8 Byoung8 is offline
Car: E90 335i 07
+1
alpinedevil335's Avatar
alpinedevil335 alpinedevil335 is offline
Car: 09' 335i Sedan
Default 02-19-2011, 02:26 PM
yes, bottom left hand corner of the logging tab shows "Status".
You should also get a message right before upload starts.
Default 02-19-2011, 03:22 PM
Load up the 2/18 version, do some logs, and shoot them in. But so far all has looked safe on 91.
Default 02-19-2011, 04:21 PM
i cant even get the upload to start
Car: 07 335i
Default 02-19-2011, 04:27 PM
ok will do
OldBooster's Avatar
Car: 2008 135i AT
Default 02-19-2011, 04:42 PM
There are many variables to check.
Firmware downloaded to PC
PC hooked to JB4 cable
Ignition on, but engine not running
Open JB4 > logging > file >"connect" > then chose 'upload firmware'
Find latest firmware on PC > 'open' or 'start'
Confirm loading at status box
Default 02-19-2011, 04:46 PM
thanks, ill try again
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 02-19-2011, 04:48 PM
Has Map 5 so far been shown to be more powerful/faster than Map2 with autopid?
2014 F10 535i N55 PWG
Default 02-19-2011, 05:08 PM
For a few but for most they are winding up below map 2 levels based on the safety criteria.
bimmerlex's Avatar
bimmerlex bimmerlex is offline
Car: 2013 e92 (LCI) M-Sport N55
Default 02-19-2011, 05:10 PM
Downloaded just 0202 firmware today, and map5 seems to be more conservative to my butt dyno than map1 on 0201. Don't even know if I want to download 0218 since I read its map5 is even more conservative than 0202...
2013 BMW 335i M-Sport E92 LCI
2012 BMW X5 XDrive35D
2010 BMW 335i E90 (Retired)
2007 BMW 335i E90 (Retired)
LostMarine's Avatar
LostMarine LostMarine is offline
Car: E92 DCT ///M
Default 02-19-2011, 05:34 PM
i wish i could get any logs done. when the roads are clear i have ZERO traction in 3rd gr even if i start @ 65-70mph.I dont want to get into 4th gr pulls around this way. i may have to make a special trip back to Atco just for logs again (opens up next weekend)
Default 02-19-2011, 05:37 PM
Load it and log it, and we'll see!
moodi's Avatar
moodi moodi is offline
Car: 335I
Default 02-20-2011, 12:51 AM
I have expected this ,thats y i didnt upload the new firmware ,it will always be a trade off between POWER and SAFETY ,what ur doing now terry ,is to reduce the the gap.
i think ur map 5 needs lots and lots of testing...it worth the try though...
alq80 alq80 is offline
Car: 07 335i Cp
Default 02-20-2011, 10:49 AM
do you think we can get a control through the steering wheel to reset to default? i.e. incase you want all settings back to how they would be the first time you got the jb4?
is this a viable option or useless to others?
Default 02-20-2011, 10:51 AM
Maps 1, 2, and 7 are unchanged. So definitely upgrade for the other little fixes we throw in there. Even if you don't plan to ever run map 5.
thesalg thesalg is offline
Car: 335xi
Default 02-20-2011, 12:30 PM
Terry found out the source of my oil leak, one of the oil coolers lines split somehow and under high pressure sprayed oil everywhere. Hopefully be fixed next week, so until then I wont be able to get logs . A friend of mine just got his in but isnt familiar with updating firmware and the interface. I'll help him out and get some logs off of that and send it in.
Copyright Đ 2007 - 2022, JB4tech.com
