ChalkWhiteN ChalkWhiteN is offline
Car: 2020 Veloster N
Default Map 1 Log Check Please - 05-04-2021, 08:37 AM
Map 1 Log check, dp and plugs only
Default 05-04-2021, 08:39 AM
Oh and Canadian 91 which I’ve been told is garbage
Default 05-04-2021, 10:29 AM
Yeah...the log looks pretty clean but there are a few relatively minor timing corrections that can probably be attributed to your fuel quality.
Default 05-06-2021, 05:00 PM
Not sure if I should make a new thread for this or not but I added a bottle of octane boost to the tank today and hereís a map 1 pull followed by a map 2 pull, any thoughts?
Chanluder's Avatar
Chanluder Chanluder is offline
Car: Stinger
Default 05-06-2021, 05:06 PM
What kind of octane booster was it? Brand? How many points?
Default 05-06-2021, 05:08 PM
VP Octanium, half a bottle, donít trust putting a whole bottle in nor did I think Iíd need it but the bottle is for 8 points so 4, base gas, 91 Canadian gas(~probably under 87 anywhere else lmao)
AWDGT2's Avatar
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 05-06-2021, 08:34 PM
I hate to say it, but your first pass log looks way better than your second. IAT's were the same so it wasn't heat. Nothing else looked off.... My guess is you have plugs on their way out. One thing you can try is disconnecting your battery for a few minutes, let the ECU reset. It will clear all the adaptives and start you fresh. If your timing still looks that bad after adding octane it's time for plugs.
Default 05-06-2021, 08:53 PM
Ouch I hope not, I didnít put the plugs in more than 8k ago Iíd hope it doesnít burn them up that quick but Iíll check in the morning could just be that I guess. Thank you
Default 05-07-2021, 07:32 PM
Better? Regapped the plugs and disconnected the battery for 30 minutes
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 05-07-2021, 07:45 PM
Timing isn't perfect but much better, this map is your max, though I'd like to see a Map2 now. If it's the same timing as Map1, then I would say you can run Map2. From your trims, it looks like you don't have a fuel wire installed?
Default 05-08-2021, 05:54 AM
I’ve got it installed on the white o2 sensor wire is that correct? That’s what it said on the forum post at the top. I’ll do a map 2 run today, what should my trims look like
Default 05-08-2021, 08:59 AM
As fuel enrichment goes up you should see trims go down, if fuel control is working properly.
Default 05-09-2021, 08:09 AM
Map 1 followed by a map 2, guessing that boost cut means itís a no-go on map 2
Car: 2020 Kia Forte GT
Default 05-10-2021, 12:30 AM
1) Ensure your plugs are gapped to .022
2) If you bought VP Octanium Unleaded, use the whole bottle it's not scalable like the others (Toroco, Boostane, Race Gas) it's not designed to be used as a half bottle.
3) Always log Map 0 first (pass through), then Map 1 and then Map 2 on pump gas ONLY. If you don't understand your logs don't automatically move to octane boosters and such until we know that other problems aren't causing marginal performance.
With things like boosters, you should always drive around awhile before before going WOT. Assuming you don't drive much like most people (to and from work) I suggest doing a few WOT pulls on the interstate/highway/freeway before logging.
I haven't had one issue that I didn't cause such as too much ethanol in the tank.
I am 100% stock except for the K&N drop-in, JB4 with BMS WMI. My biggest problem is traction otherwise it's a 12 second car.
2020 Kia Forte GT
6 Speed Manual
JB4+Bluetooth Connect
Whiteline Springs
13.77@103
Map 7, E30+WMI, Hoosier Drag Radials
Default 05-10-2021, 12:38 PM
The boost cut looks like it was due to wheel spin...traction control off?
Cylinder 4 shows some pretty good timing corrections...I'd look in to that, maybe a plug issue?
Default 05-10-2021, 01:14 PM
Doubtful on the wheel spin in 3rd gear and tc was off. Definitely starting to think plugs, when I took them out to regap them the other day there was a tad bit of black on the ends of each of them. Iíll order those and post logs once thatís all taken care of. Thanks for the help everyone
Default 05-10-2021, 01:34 PM
If you are running without the fuel wire enabled, your plugs will be black...
2020 Kia Forte GT
6 Speed Manual
Whiteline Springs
13.77@103
