Ke90 Ke90 is offline
B58_Dude
Car: M240i
Default E85 mixes + JB4 Question - 04-06-2020, 11:52 AM
If you plan to run any E85 mixtures do you have to purchase the Ethanol Sensor kit from Fuel-it for the JB4?
SHOP BY VEHICLE TYPE - BMW - 2-Series - 240i B58 (F2X) - FLEX FUEL KITS - FUEL-IT!
Does the JB4 require it for tuning/learning or is it just strictly to show what the E85 mixture you currently have? Ex: E60,E40 etc…
I know I will need a tune designed for Ethanol mixture and once I get that, does the JB4 still need the sensor kit too?
Thanks for help.
Default 04-06-2020, 01:30 PM
Not needed to run the sensor kit.
You can run mild blends up to e30 with JB4.
B58_Dude
Car: M240i
Default 04-06-2020, 01:33 PM
Thank you.
B58_Dude
Car: M240i
Default 04-06-2020, 02:38 PM
If I were to run higher blends would it need it? Or can the JB4 run full E85 as long as the BEF is correctly tuned for it?
I plan on upgraded HPFP to start running E85, I just was not sure if then JB4 application needed anything else. (Ex: EWG cables or ethanol analyzer kit)
My understanding is as long as the BEF I am running is for the ethanol mixture and I am accurate when fueling the tank; there is no need to spend another $450 for an ethanol analyzer since the JB4 will still run correctly without it. (As long as correct BEF is loaded)
Thanks again for help.
Default 04-07-2020, 10:24 AM
I would get it for higher blends to make sure you're getting the E content you want for the higher boost you'll probably be pushing with it.
You will need BEF with full e85 and HPFP IIRC.
