nyt nyt is offline
Car: 335ix
Default 01-17-2019, 01:33 AM
Is there a tstat in the cooler? I'd imagine there should be to speed up warmup
2010 335ix - speedtech 6466g2, cams, ported head, built bottom end, 7.5in hd ic, jb4, pi, fuel-it stg3, upgraded 6hp21+cooler, pr coils
Rnm Rnm is offline
Default 01-18-2019, 11:22 AM
Would this thermostat work in conjunction with the bms transmission cooler?
High-Flow Transmission & Differential Fluid Thermostat FSM-145/165
2007 335i - MHD, VRSF 7" FMIC, PLM *****, Stage 2 Fuel-it!
Default 01-18-2019, 11:48 AM
No we decided to skip it to keep cost and install simplicity down, have not seen any need in our testing. But it's the sort of thing you can always add in on your own if you'd like.
NJrep335I's Avatar
NJrep335I NJrep335I is offline
Car: BMW 335I
Default 01-19-2019, 08:08 AM
Do you have plans to upgrade the oil cooler?
Zoki Zoki is offline
Car: 335i E92 N54
Default 01-21-2019, 04:30 AM
Is this mountable anywhere else? I have the PPK Rad mounted behind that fog light, so I assume this wouldn't fit there now. Is it compatible with RHD?
Default 01-24-2019, 09:35 PM
What makes it so great is we're providing a fully plug and play kit and brackets to match. But you can customize the kit as needed for your specific needs. Doubt it on RHD, but not tested.
BMW135xi's Avatar
BMW135xi BMW135xi is offline
Car: BMW 135I
Default 02-03-2019, 04:32 PM
Please , need instructions or pics how to install it. ..Bmw 135I -1M front bumper.
Thanks.
Default 02-03-2019, 08:59 PM
Install guide should be on the site, check back there later. I'll see why it's not posted.
Default 02-04-2019, 09:51 AM
Install guide is up!
BMS E Chassis BMW Transmission Cooler | BurgerTuning.com
http://www.burgertuning.com/instruct...er_install.pdf
BMW135xi's Avatar
Car: BMW 135I
Default 02-04-2019, 02:24 PM
I see it , Thanks...
vtec347 vtec347 is offline
Car: 2007 335i 4dr
Default 02-19-2019, 12:37 PM
What are the dimensions of this cooler? Also are these AN fittings? I tried looking on your website but there's no technical info...i was hoping to place it on passenger side where my stock oil cooler was.
Default 02-19-2019, 01:10 PM
I don't have exact dimensions but it's like a 25 row oil cooler -10AN yes.
You removed your engine oil cooler on the passenger side?
Car: 2007 335i 4dr
Default 02-19-2019, 01:29 PM
I'm in the middle of upgrading...well, pretty much everything. I have the PSP oil cooler with thermostat. So that mounts front and center which would eliminate stock oil cooler. So I figured why not mount tranny cooler there in its place... I can figure out mounting myself. Just wanted to know if its gonna fit (dimensions of cooler itself). Also if I'm going to need longer lines and I was planning on doing another in line thermostat.
Are the factory trans cooler connections 10AN ?
Default 02-20-2019, 09:55 AM
Nothing will work unfortunately for the passenger side.
This was all developed for the driverside to be PNP.
Check the install guide and you'll see why.
The factory trans cooler are OEM spec quick disconnect.
Our lines are custom made to accept this so no extra leaks, and AN fittings.
APDE90N54 APDE90N54 is offline
Car: 335i e90 n54
Default BMS TRANSMISSION COOLER DIY VIDEO - 03-10-2019, 06:31 PM
What's up!
I seen quite a bit of interest in a diy for this new cooler, check out the video on my channel.
BURGER MOTORSPORTS TRANSCOOLER (BMW E90 335I) - YouTube
It is very straight forward but I thought maybe some visual reference might help the community out.
Thanks and enjoy!
Default 03-11-2019, 01:36 PM
Originally Posted by APDE90N54
What's up!
Thanks and enjoy!
This is awesome! Thanks for the video.
Trans should shift a bit smoother and crisp from my initial testing.
How is it so far with you?
Car: 335i e90 n54
Default 03-12-2019, 03:17 PM
Yes, I like it so far.
Definitely an upgrade from the stock.
I also do notice that the shifts are as smooth as butter and I can pusht the rpms a bit more without having the trans wanting to shift
Car: 335i e90 n54
Default Updated BMS Transmission cooler DIY video - 03-23-2019, 05:45 PM
Check out the DIY video on speed theory performance.
BURGER MOTORSPORTS TRANSMISSION COOLER - YouTube
SPANKY's Avatar
SPANKY SPANKY is offline
Car: 2008 335i
Default 05-21-2019, 07:24 AM
Is site down?tried clicking the trans cooler and not available,same for install video
E90 SEDAN '08
-SiNGLE TURBO AUTO TRANS*FSB G5 ISO*100%METH**FUEL iT!STAGE 2*ALPiNA FLASH-
-NGK PLUGS*BMS OCC*RB VALVE-
-E85 MHD FLASH-
Default 05-21-2019, 09:40 AM
https://www.burgertuning.com/product...18031564423283
Link for install guide will be up shortly, some bugs on the website.
SPANKY's Avatar
Car: 2008 335i
Default 05-21-2019, 09:48 AM
Thanks,working now.
E90 SEDAN '08
-E85 MHD FLASH-
SPANKY's Avatar
Car: 2008 335i
Default 05-21-2019, 09:52 AM
So losing the brake duct to front drivers side brake would be a issue?concern?
E90 SEDAN '08
-E85 MHD FLASH-
msport335 msport335 is offline
Car: E90 LCI
Default 05-21-2019, 06:22 PM
is there an option to just buy the lines, fittings and brackets minus the cooler?
Default 05-22-2019, 10:13 AM
Nothing we have noticed on our car. Been running it for over a year.
Sorry, we don't piece the kits. For $399 it's a pretty great bargain!
Car: E90 LCI
Default 05-22-2019, 06:06 PM
How would this cooler compare to a Setrab 25 row cooler or similar?
