DamnDatsun's Avatar
Car: 2010 135i msport
Default Launch control device? - 10-12-2019, 03:52 PM
https://www.maperformance.com/produc...ssion-vehicles
I'm curious if JB4 would be able to control a lunch control device like the one pictured above. It lets you adjust how quick the clutch engagement is off the line, allowing constant launches that can be dialed in along with potentially saving drive line components. It's plumbed between the clutch slave and clutch master.
I'm curious jb4 would be able to control this device, so that it is only powered in first gear. Allowing the following shifts to act normal (no power to launch control device so fluid flows through it unimpeded).
Any thoughts?
