Jan-HH Jan-HH is offline
Car: Mini Cooper S F56
Default Error Codes - 11-29-2019, 07:17 PM
Hello,
I have finally successful installed the JB4 and installed the Firmware
MINI_B38_B48_6_2.hex
on it.
The Car is a 2018 Mini Cooper S wit 192 HP.
I filled the "Map 6 Boost" with the Numbers from the N54-Website.
In the Dashboard is now the yellow Triangel-Alert and the Connected-System says, I have to go to dealer to check.
In the JB4-App there are two Error-Codes even with MAP 0:
121201TMAP Signal with engine off
101F01 Throttle valve opening angel pressure -- ignore, tuner code
Also the JB4 - App Dashboard shows nothing. Only "Gear" and "Map" are frozen, "RPM", "IGN 1", "AFR" and "IAT" are at Zero, no reaction.
What to do?
Default 11-30-2019, 05:30 AM
some additional Infos:
- only the Gauge for Gear and Map are working
- Dashboard of the Mini shows no yellow/orange Warning Triangel anymore
- in the JB4 App the errors are still appearing when reading out - also they can’t be deleted
- the App does not Log (no matter what Map (1, 2 or 4)
- when parking the car I always have to log in again and Bluetooth also has to connect every time newly again - what sometimes fails and needs several minutes until it’s connected
a little bit disappointing so far....
Default 12-02-2019, 12:07 AM
Some more infos:
Installed JB4-App new on my iPhone, pulled out and plugged in OBD-Connector and started again. Installed Firmware again.
- Now I have the Error 104302 (absolute pressure sensor, intake manifold...)
- The two other Errors are gone - or not? Who knows, as 50% of attempts the App says, its not possible to read the Errors
- No Warning Signal in Mini Dashboard
- Gauges in the App are not working except Gear and Map
This Morning after connecting App a new Point in the Login-Menu between "Save" and "Cancel": "Unlink Current Kit" - when I start the App now, this Point "Unlink Current Kit" is gone again....amazing App.
Log-CSV cant be uploaded, becaus it is mor than 500KB.......(Upload Errors
2019-12-02 07_11_10_Map-1.csv:
Your file of 560.6 KB bytes exceeds the forum's limit of 488.3 KB for this filetype.)
Kit was installed before in a BMW 140i, I took away the EWK-Cable.
Default 12-02-2019, 12:18 AM
Here is the Log zipped
Default 12-02-2019, 01:16 PM
Load up the latest BMW v14 firmware posted and lets evaluate that on it!
Jay1312 Jay1312 is offline
Jay1312
Car: BMW 320i and M5
Default 12-02-2019, 03:04 PM
BMW v14 but isn’t that for b58/48 and not suitable for mini or has the mini firmware now ported to the bmw?
Default 12-02-2019, 05:38 PM
We updated it so as a test let's see what happens.
Default 12-03-2019, 01:11 PM
Hello Tery,
thank you! I am in contact with Ando and we try to figure out, what the problem is
First I will have to check all the connectors (but I am sure, the connections are okay und installation is 100% okay).
If that is not successful, we might try the BMW-Firmware, if you think that won't cause harm to the Engine.
CU
Default 12-06-2019, 05:45 PM
It's a more advanced issue so will need to continue working with us via email on it.
