blackdm's Avatar
blackdm blackdm is offline
Car: F82 M4
Icon1 The methanol injection problem - 09-04-2019, 02:33 AM
I have a BM3 back end flash that does not turn on the methanol injection and has a normal time-space combustion ratio. The air fuel ratio is too thick after starting the injection. Using the 100%meth
File Type: csv 2019-09-04 16_12_27_Map-4 (NO meth ).csv (17.8 KB, 108 views)
17 F82 M4 dct/ BM3 Custom flash/ BMS JB4 ISO /200 mesh exhaust Top section / BP Racing Metal Chargepipes and J-Pipe / CSF ColdFront / NGK Racing 0.2 / BMS Methanol injection / 763M / Cup2 /Phoenix Racing Intercooler/ EVENTURI INTAKE
blackdm's Avatar
Car: F82 M4
Icon1 09-04-2019, 02:41 AM
Question 2: the meth reading in jb4 mobile APP is 7 ~ 10 in normal driving. Is this normal?
Default 09-07-2019, 03:14 PM
I think I helped you via email already, but the meth is working normally. We should lower the fuel trims in your back end flash.
fm6933 fm6933 is offline
Car: m6 gran coupe 2014
Default hello im new on jb4 and having same problem - 02-24-2020, 08:46 PM
hello brother same problem new to jb4
kompressor kompressor is offline
Car: m3 2015
Default 06-14-2020, 08:30 AM
hello guys i have a m3 s55 jb4 wmi with fsb, connected to jb4, which would be a complete setup for methanol injection to work on all maps
Default 06-14-2020, 01:02 PM
Meth trigger = 1 on user adjustment page will get meth flowing on all maps.
Car: m3 2015
Default m3 s55 - 06-14-2020, 02:23 PM
I did meth tiger = 2, but even so it did not work. I put an LED on the fsb connection that connects to the methanol pump wire so that it can turn on but it did not work. and wmi with fsb module and I have doubts about the complete setup, can someone help
Car: m3 2015
Default 06-14-2020, 03:29 PM
sorry I trigger meth = 1
Car: m3 2015
Default 06-14-2020, 03:39 PM
ull set required for m3 s55.turbina pure dowpipe.
intake cts, inlet pipe ftp, wmi water cooler suprior cts, front water cooler. there is a flach map orignal from the factory which map jb4 i must use to go 700 hp, it is possible only with jb4.ewhich setup can i use
Car: m3 2015
Default 06-15-2020, 03:51 PM
Setup m3 s55 tubo pure 2 injection meth
Car: m3 2015
Default 06-17-2020, 06:02 AM
Good morning, someone could get me the setup to run JB4 FSB WMI S55 by favos
