jraptor0440 jraptor0440 is offline
Car: 2021 A4 Sline
Default 2021 A4 Group 16 - 10-15-2021, 08:58 AM
I have a 2021 A4 2.0 265HP with Group 16 JB4. What firmware should I be using? Currently it is on 61- VAG MK8 SENT. Is this correct?
Default 10-15-2021, 09:27 AM
That is correct. There is no update for this model yet.
2021 VW Golf 8 R
Car: 2021 A4 Sline
Default 10-15-2021, 09:33 AM
Ok great, Thank you.
Another question. When I go into user Adjustment, should everything be blank on the mobile App? Or does this only matter if using MAP 6. I am currently using MAP 2
Default 10-15-2021, 09:54 AM
The values that need to be there will only populate once connected to the JB4. The app is just a window to see the settings on the JB4 and nothing is stored on the actual phone device besides logs when you take them.
2021 VW Golf 8 R
Car: 2021 A4 Sline
Default 10-15-2021, 10:17 AM
Ok so when I connect to JB4. Everything is 0 except Max boost at 28 and fuel open loop at 30. Do I only change these if I'm using MAP 6 or should there be values in there even on MAP 2?
Default 10-15-2021, 10:28 AM
You leave those as is. They are global settings and affect all the maps.
The rest is if we do a custom map on the car. You can email me at george@burgertuning.com and we can work on that together.
2021 VW Golf 8 R
Car: 2021 A4 Sline
Default 10-15-2021, 10:30 AM
Awesome. Thank you again George.
