(#101)
Dustinís GT2 Dustinís GT2 is offline
Car: 2018 Stinger GT2AWD
Default 05-18-2018, 05:25 PM
Originally Posted by stingerGT
I can't find the post now, but I believe they actually removed material from the cast piece going into the c at. If my memory is correct, the p ipe narrows quite a bit there. You kinda see the right side (inlet) is a narrow cast piece.
Correct. Looking for the YouTube video now.
Default 05-18-2018, 05:30 PM
https://youtu.be/lw56rqlMLQc
Tork video on porting the down pipe.
Kjeronimo27 Kjeronimo27 is offline
Car: n63
Default 05-19-2018, 10:19 AM
I've seen this cars make 450 wheel already ??? is this true
if so this is insane money vs performance buy
Default 05-25-2018, 04:27 PM
Good news Stinger owners... Just got full CANbus working on our Kia JB4! The JB4 can now read the full set of engine data including pedal, throttle, engine speed, AFR in both banks, fuel trims in both banks, various temperatures, ignition advance, etc, and incorporate all that in to its tuning! Including things like boost by speed for improved traction, expanded safety systems like run lean and over boost, code read/delete, etc, etc. All other Kia tuning boxes are now obsolete.
All you'll need is an OBDII cable to enable it which we can send you, and the latest firmware which I'll add to the first post shortly.
Default 05-25-2018, 05:15 PM
When can you send the OBD cable?
hungtran505 hungtran505 is offline
Car: Kia Stinger
Default 05-25-2018, 05:20 PM
Yes I would like to know as well. When can you send it?
Default 05-25-2018, 06:56 PM
Just email us with your BMS order number and we'll get the cables out.
Car: Kia Stinger
Default 05-25-2018, 07:06 PM
Hi Terry
I just sent you an email.
jerrym79 jerrym79 is offline
Car: 2018 STINGER GT1
Can anyone please walk me through map 3 and changing the boost level manually? I would appreciate the help. Thanks all.
Car: Kia Stinger
Default 05-25-2018, 07:13 PM
Do we need the connect kit for the canbus or we can log it though our laptop?
Default 05-25-2018, 07:15 PM
Laptop works fine for logging too. They work the same way.
Deider1 Deider1 is offline
Car: Stinger GT2
Default Update install failure! - 05-27-2018, 09:03 AM
When updating the bluetooth failed connection and did not complete install. Now motor runs like ****. Can I send this to BMS and have this update installed?
Default 05-29-2018, 08:52 AM
You need to keep trying until you get firmware updated. Or if you can't sort it out order a 2580 master update chipset on our site which will have firmware preloaded: http://www.burgertuning.com/JB4_upgrades.html
Car: Kia Stinger
Default 05-29-2018, 09:00 AM
Can someone give us a walk though for map 3 on how it work
Default 05-29-2018, 09:16 AM
Update the OBDII and CANbus as that changes everything. Then you can use map6 for an RPM based custom profile.
Car: Kia Stinger
Default 05-29-2018, 09:29 AM
So on map 6 I can adjust the boost level after the firmware update for canbus.
Default 05-29-2018, 09:31 AM
Yes but start by logging map2, it's pretty good, and then evaluate. Any custom tuning you do has to be based on your own log evaluation.
Car: Kia Stinger
Default 05-29-2018, 09:33 AM
Ok
07335i's Avatar
07335i 07335i is offline
Default 05-29-2018, 10:20 AM
anyone run on the dyno with jb4 ???
JeremyF JeremyF is offline
Car: Bmw440
Default Dealer - 06-01-2018, 08:34 PM
He happens to work for a Kia dealer and told me as long as you remove the parts before going in generally it's not a problem. He said they are scanning the cars checking for flash tuning though now. Per usual if you can't afford to fix it, don't risk modifying it, but we expect our tuning to be very reliable. The motor appears overbuilt for the factory power levels.
Is there any way to remove the trail the dealer can see if they look for tuning?
Default 06-01-2018, 08:40 PM
If you flash the computer? Doubt it!
Default tuning/log - 06-04-2018, 10:43 PM
did some logging with can-bus cable today here is what i got
Car: Kia Stinger
Default 06-05-2018, 06:37 AM
What are your setting on map 2 under user setting?
Default 06-05-2018, 06:49 AM
What do u mean the user tab I can take a pic of it if I want I have done a little changing since I have experiance tuning though with other programs but I have a few changes and statted where i went into over boost at all levels and just changed it one setting at a time until I got it in a good place.
Car: Kia Stinger
Default 06-05-2018, 06:52 AM
I want to get to 20psi.
