(#1451)
Default 09-21-2018, 10:02 PM
Originally Posted by Erikb
Uploaded the new firmware and tried to clear the stored code; 118001 mixture to lea,n this morning, the clearing seems to work
Great, glad to hear!
Default 09-21-2018, 10:03 PM
Originally Posted by louism140i_
Hi terry Iím running v9 at the min on my m140i running map7 with meth, is it worst doing the update to v10 yet or wait a few weeks. Thanks
If you want to try the new stuff and help provide feedback, go for it.
bavarianmw bavarianmw is offline
Car: 17 320i, 16 M3 (outgoing), 18 340i (incoming)
Default 09-22-2018, 07:41 PM
Good timing for me with the latest update. I have a late production 340 MPPSK, and the newest BMW release. Today I got the jb4 hooked up with ewg and ff, along with the straighp1p3 setup (even though not recommended lol).
I can confirm that on v9, I could not clear codes. After trying 11test, the JB4 cleared all the codes I had, multiples for fuel pressure something, manifold pressure, boost sensor voltage.... I assume starightp1p3 setup is to blame.
So map 1, real choppy. Tried map4 (stock w can bus) and much better, but maybe not perfect. I look forward to trying map6 and seeing if I can pull a good log. Unless there is a better suggestion from the experts? Thanks. --MW
Snowman Snowman is offline
Car: BMW M135I
Default Yesterday, 05:55 AM
Since my questions seems to have been overlooked by Terry and others ill post them again..
How much of an issue is throttle closures with JB4 and B58 nowdays?
Im just replacing my N54 with a B58 and did some reasearch and found out that jerky operation due to throttle closures was a real issue when running JB4.
However the information i found were from the early days for the B58 and JB4.
I also read in the patch notes that JB4 can control timing, how is that possible on the B58 since from my understanding JB4 only controls boost and fuel pressure for the N54 and N55?
RMM RMM is offline
Car: 120i
Default Yesterday, 06:20 AM
I tried v11 test map and it went a bit crazy, was jerking a lot.
Target was like 12 psi with a 50 meth adder on map 7 !
meth was engage totally randomly, when it did AFR wet to like 9's was jerking form misfire probably as trims go so low AFR cannot regulate anymore
I changed back to v9, everything great again
screen shot of it and log attached, if you have meth I would stay away
Default Yesterday, 09:35 AM
Why is your flash target 22psi? Is the flash stock or modified?
RMM RMM is offline
Car: 120i
Default Yesterday, 10:00 AM
stage 2 flash, post flash normal AFR is 12.5 to 11.8 at WOT
trying to figure out how to run with meth and flash tune, no meth flow in map 6 or map 4, but use map 7 and can get meth flow so I just use that with JB4 target slightly below like at a 45 to 50 adder and it seems to work pretty good
Default Yesterday, 10:55 AM
Since it's a complicated setup you'll have to send in logs via email to evaluate.
Default Yesterday, 01:50 PM
My map 6 logs from 11test which code clearing DOES work on newest BMW DME firmware.
No expert here, but I see throttle closure cause of smelly mod, in low rpms? If so what setting should I try, FUA? Can I add more boost? The car feels very strong, I am quite pleased so far. Thanks all.
340i MPPSK
smelly / loud mod
jb4 11test with ewg + ff
93 octane
map 6 default with:
15 lbs to 2000
16 lbs 2500 to 5500
14 lbs 6000 +
f9kandy f9kandy is online now
Car: M140i
Default Yesterday, 03:23 PM
RMM, it looks like you are getting throttle closures due to overboost, the meth is just shutting down with the throttle.
Default Yesterday, 05:56 PM
In these logs flash target is 10psi, the other ones had it as 22psi. So not sure what is going on or why your flash target would change so much. Nothing here applies to the general population so you'll need to make your own thread in the support area if you want addl feedback on it.
Default Yesterday, 08:34 PM
I'll take this to a support thread if I need to, but these are the only logs I ever posted here, and I just installed everything. Am I mixed up? I don't know what a flash target is, this is oem MPPSK dme.
Does this help?
