(#476)
Default 09-16-2018, 08:48 PM
Fuel is momentarily cut off during the shift, so AFR isn't going to be accurate at shift points.
Logs look good to me though. What's the fuel mix?
HTXgearhead HTXgearhead is offline
Car: Mercedes C43
Default 09-16-2018, 09:08 PM
Fuel is E30 for all logs. I added the DA and temp on the log title.
Default 09-16-2018, 09:36 PM
Roger that. Give map7 a whirl on the E30 mix!
Car: Mercedes C43
Default 09-17-2018, 07:01 PM
2018 C43, E30 fuel, 2280DA, 88F. Throttle closure is MUCH better now. MPH is off a slightly, but also improved.
I will post more map 7 logs when time allows.
Default 09-17-2018, 08:02 PM
Good, the new logic looks better for you.
agchenry agchenry is offline
Car: 2018 AMG C43
Default 09-17-2018, 08:57 PM
MAP 7 60-130 11.54
E30 MAP7 83F DA 1500
File Type: csv 2018-09-17 22_38_00 M7 E30 83F DA1500.csv (15.8 KB, 14 views)
Default 09-18-2018, 08:06 AM
Log looks clean! I think to move things forward we're going to need to push boost up. To do that we may need to work out an add on wire or two for the JB4 to add to the wastegate duty cycle. I'll have to get a C43 to swing by the office so I can poke around a bit.
TXC400 TXC400 is offline
Car: MERCEDES C400
Default 09-18-2018, 09:19 AM
That is what we need! lol
jalndrs jalndrs is offline
Car: 2011 335i M-Sport
Default 09-18-2018, 11:08 AM
Terry, getting my schedule A service next Tuesday then will install my JB4 and will provide additional logs for review. Thank you for helping take this platform to the next level.
Iggs Iggs is offline
Car: Mercedes C450
Default 09-18-2018, 08:32 PM
Hey Terry,
Thought I'd chime in here as well as I was able to obtain some logs after doing some runs on the new firmware.
Just a little info on what I've got:
- C450
- Outside Temp was 17.9 Degrees Celsius (64F)
- DA was 942Ft
- Fuel being run was 94 Octane
Map 2 definitely feels noticeably stronger after the new update - if there's any additional combos you want me to try let me know. I'm hoping to be able to hit a dragstrip close to me this thursday and obtain even more logs.
Here are my logs - Happy to answer any additional questions:
Default 09-19-2018, 07:51 AM
Logs look good, thanks!
Car: Mercedes C43
Default 09-20-2018, 11:29 AM
I know a guy in the LA area that can drop his C43 off for a few hours for the wastegate testing. Want his contact info?
Default 09-20-2018, 11:30 AM
Sure have him email me, terry@burgertuning.com. Thanks. I'm pretty busy this week but should have time next week to poke around!
amkreadgto amkreadgto is offline
Car: C205 C43
Default 09-21-2018, 04:16 PM
Some models are not logging AFR on the same PID for some reason. We'll have to get one of those cars in locally to check them out, maybe do a firmware update for it. We have fuel trims at least so can see the fueling side is fine.
Map1 looks fine, go for map2.
Hi Terry,
Map2 logs.
80F
83% humidity
93 Pump gas
K&N & catl3ss D0vvnpip3
Is the boost kind of low for Map2? Fuel trim and timing looks OK...
Does the boost increase after the engine heats up more? Made these runs 5mins after morning start up. Though temp is warm here...
2018 C43 Coupe
K&N
Cat13ss D0vvn P!p3
93 Pump Gas
Default 09-21-2018, 09:46 PM
Originally Posted by amkreadgto
Hi Terry,
Map2 logs.
80F
83% humidity
93 Pump gas
Update to the newer firmware and relog map2.
Car: Mercedes C450
Default 09-22-2018, 05:46 AM
Terry! help us 450 owners hit the times that the 43s are lol..
So I went to the dragstrip on thursday with the following config:
C450
DA was 1463ft
MS109 Race Fuel was used
Outside Temp was around 19 degrees celsius
it seems as though the difference between the transmissions (9 Speed vs 7 Speed) is the reason why C43s are able to cut into the 11s and I'm stuck in low 12s (12.3 was the best I could get @ 115 mph on Map 7 - one of the C43s got 11.7).
I'm of the opinion that they're more geared to run in the higher RPM range with the 2 extra gears and thus get more access to boost.. I'm lucky to see 20 PSI.. car just doesn't wanna do any higher than that and the only time I saw 20 PSI was at the track when I ran MS109... otherwise I usually never see anything higher than 19
Anyways I'll include my logs here for your review. Let me know if I need to be doing something differently.
Car: C205 C43
Default 09-22-2018, 04:07 PM
Hi Terry,
Uploaded the Test4 FW. Attached are logs for Map1 & Map2. Boost seems right on compare to the previous Map2. How does the rest of the data look? If all good, any way I can tweak it more with just 93 pump gas? (93 is all I can get here.)
So there is only 1 psi difference now between Map1 & 2?
80F
83% humidity
93 pump gas
2018 C43 Coupe
K&N
Cat13ss D0vvn P!p3
93 Pump Gas
Default Yesterday, 09:12 AM
C450
DA was 1463ft
Tuning looks good. For kicks on the race gas you could try a map6 with a +8psi target just to see if times continue to improve. Ultimately though I think we'll need to get wastegate control going to push boost higher.
Default Yesterday, 09:13 AM
Hi Terry,
80F
83% humidity
93 pump gas
Yes roughly a 1psi difference between map1 and map2 now.
Timing and boost look good, as do fuel trims, but we need to get AFR working on these! Anyone with a C43 that can't log AFR in our area we'd love for you to swing by for an hour.
Car: Mercedes C450
Default Yesterday, 03:42 PM
Sounds good... based on the logs I provided is there any particular rpm range that you would recommend I request 8psi?
Let me know if there is any way I can help with wastegate control... unfortunately I canít be there physically but I am more than happy to help beta test anything out and provide logs and data. Really wanna see this platform and jb4 do great things together!
Default Yesterday, 04:16 PM
We'd need a local car in here to play with. As a test you could just ramp boost up to 8psi using map6 and evaluate.
bmxathon bmxathon is offline
Car: C400
Default How does this log look? - Yesterday, 05:36 PM
Terry, here is a log I did and I’m wondering what you think. The trims look high and the afr looks a bit high as well but I wanted your opinion. I’m just trying things out to see what can be done.
DA: 1,345
Temp: 89F
E40 blend
Map 7
Default Yesterday, 05:55 PM
Would need to see higher RPM to see if fueling sorts itself out, but we'll have to get the JB4 fuel pressure connector installed likely for this heavy E85 mix on map7 levels. Which on older harnesses (with purple plug on them) requires relocating a wire in the DB25.
