Roopj Roopj is offline
Car: 2017 Ford Raptor
Default Hard shifts with Map 1 and above - 03-08-2020, 06:30 PM
I've only had my JB4 for a short time on my 2017 Raptor but I have a problem with the transmission every time I change from Map 0 onward. I start having HARD shifts that almost seem like slipping between gears 1-3 and 6-8. I've jumped between Map 1 and Map 3 and I get the same effect. When I move back to Map 0 the problem goes away. 40K miles and runs on 93 octane regularly.
Have you encountered this problem before or know of a way to fix it? I like the gains I get but the hard shifting I can't handle.
Thanks in advance.
Default 03-09-2020, 11:03 AM
Are you on update firmware?
Is your OBD2 plugged in correctly?
Default 03-09-2020, 05:25 PM
Yes I've got the OBD plug in firm and I've recently updated to the newest firmware (ver 8 i think)
Default 03-09-2020, 09:28 PM
When you can lets see a log on map1 to see if that sheds any light on the issue.
Default 03-11-2020, 06:48 PM
Attached are logs from Map 1 and 3. I'm hoping it's not something with the transmission as I've seen problems with it on this forum.
Default 03-11-2020, 06:50 PM
oops, Map 1 was too big to be attached. Here's the link for it on my gdrive:
2020-03-10 17_05_25_Map-1.csv - Google Sheets
Default 03-14-2020, 04:34 PM
Hi - any updates after reviewing the 2 outputs?
Default 03-23-2020, 04:07 PM
Can anyone help? Been waiting a while now
