Car: M140i
Default Map 2/3 log review - 10-10-2018, 02:52 PM
Just wondered if someone could check these logs and that things seem to be running okay ?
Thanks in advance
Default 10-12-2018, 08:59 AM
Looks very strong, logs are great. What mods and fuel are you using?
Car: M140i
Default 10-12-2018, 01:29 PM
Ah thatís good to hear, thank you ! Iím running UK Shell V-power which is rated 99 octane, equivalent to US 93 I believe ! Also got a custom *** back exhaust, aFe pro dry S air filter, hot climate air intake pipe (extra pipe that goes from the front grill into the stock air box).
Car: M140i
Default 10-16-2018, 03:38 AM
Going to be running a sports *** soon so I will get some more logs once it's in ! will try map 2 & 3 with it also, maybe even map 5...
Car: M140i
Default 10-20-2018, 12:22 PM
Okay so got my sports c-a-t, hereís a quick log I got this evening in map 1, appreciated if someone can tell me how this looks ? Iím still not sure what constitutes as a good log lol
Car: M140i
Default Map 2 logs with cobra SC - 10-22-2018, 04:30 AM
Hi again, also done some map 2 logs today, are there any settings I should have active now Iíve changed c-a-t ? Had an error code of 12AF20...
Car: M140i
Default 10-25-2018, 08:32 AM
just bumping this, hoping someone might be able to give me some guidance on any settings I should adjust for the new c-a-t ? Or whether I should order the EWG wires ?
T52's Avatar
T52 T52 is offline
Car: 2016 BMW 340i xDrive
Default Log Review - 10-26-2018, 11:49 AM
Hi! Could you look at the attached log and let me know how it looks?
Bullitt1841's Avatar
Default 10-28-2018, 11:25 AM
Sorry, I don't agree with Payam. Although the logs look "happy," you are running way too lean for an M car. Get the EWG and FF wires and keep the boost stock until you do.
If you can't get your AFR richer, you're going to be running too hot and the longevity of your engine, turbo, and converter will suffer. Get a flash if you still can't get it rich.
Just my opinion.
Car: M140i
Default 10-29-2018, 08:07 AM
Just my opinion.
I do plan to flash the car at some point down the line and I was planning on the EWG/FF wires in the future too. What sort of AFR would you consider appropriate ? Not had the oil heat up above 109 degrees Celsius though..
Car: M140i
Default 10-30-2018, 03:10 AM
Just my opinion.
If you take a look at my first post, and look at .csv 2, this is map 3 and from what I understand this is running healthier in terms of afr than map 2 ?
Correct me if I am wrong ?
Although not logged map 3 with my new sports c-a-t yet so I don't know if this will still apply.
f9kandy f9kandy is offline
Car: M140i
Default 10-31-2018, 05:20 AM
I also sometimes see the AFR richen up in higher gears at high boost, I don't see this as a good sign, it is not reflected in the fuel trims. My take on this... the DME is adding fuel to try combat high EGT at this point, it is normally accompanied by a reduced DME boost target.
Car: M140i
Default 11-02-2018, 04:30 AM
I'm going to order the EWG/FF wires soon, will get some logs going once they're fitted and hopefully see a better AFR..
