B58ftw B58ftw is offline
Brad Z
Car: BMW 340i xDrive MPPSK
Default JB4 WMI Boost target B58? - 10-28-2019, 08:47 AM
I'm in the process of upgrading my HPFP and want to up the boost on my external wastegate. It seems like the highest boost target using map 7 is ~24psi. Is there any way to up the boost target to ~27psi without having to resort to an external trigger for WMI?
CntryClub007's Avatar
CntryClub007 CntryClub007 is offline
Car: F30 340i / E70 X5-35i
Default 10-28-2019, 10:47 AM
Curious - Are you going XDI or B58TU, or which pump on the upgrade? You planning to go E85 with the upgrade?
| 2016 BMW 340i | M-Sport |
| CG Catted + AWE | BMS Intake | FTP Turbo Inlet + CP | JB4 + MHD BEF | XHP Stage 3 | BMS Meth Kit | VP M1
Brad Z
Default 10-28-2019, 10:51 AM
It's actually Spool Performance; they're doing field testing so I'm getting a beta unit at a good price. I wish I could go E85 but here in New England the nearest gas station with E85 is like 30 miles away- I miss Florida.
Default 10-28-2019, 11:37 AM
If using a JB4 you can use map 6 and put in a custom boost profile to your needs.
WMI should be integrated into your JB4 as well.
