terryd5150's Avatar
terryd5150 terryd5150 is offline
Car: BMW 335xi
Default JB4 for Meth and PI BOTH. - 03-25-2018, 09:40 AM
Somewhat of a basic question, but searching the internet I can only find information on one or the other.
Regardless, can a JB4 control both Meth and PI (E50) at the same time?
Meth would be dual cm5/7 CP nozzles (for cooling only), PI would be fed off a stage 3 lpfp.
Can JB4 do it?
If so, what would be needed to make it work?
Default 03-25-2018, 09:53 AM
With FSB orange installed the JB4 can control WMI. Although, normally it's a waste of time. If you have PI you're using E85 and don't need WMI. If you odn't have E85 you don't need PI.
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 03-25-2018, 10:15 AM
Can JB4 do it?
I think you should connect everything except JB4 signal (blue) #16. not sure but Terry should confirm this, though you will only see PI signal.
N55 - Doc race 6266.
luchocamp's Avatar
Default 03-25-2018, 11:03 AM
Terry I think meth injection and E85 port injection if you live in hot weather like caribbean is good. Without meth flow even with Port injection working I saw 20-25 over ambient.
A90 Supra Full Weight No Nitrous 10.78@133mph
BMW M4 10.96@132mph no prep track stock turbos
Default 03-25-2018, 11:17 AM
With E85 being so knock resistant the drop in IAT doesn't carry the same performance benefits as it would on normal gas though. Thus the minimal benefit.
Stoolz Stoolz is offline
Car: 11 135i
Default 03-25-2018, 12:47 PM
So.
Being in sub tropical Australia , I left a cm5 nozzle installed for Iat reduction. I would prefer to completely remove my meth kit which is the reason I went PI in the first place. (Had someone post on here to keep it).
Meth is a waste of time then?
I have E85 2 blocks away, no issue there.
Default 03-25-2018, 12:51 PM
Since it's already installed measure performance with and without it and make the determination. Something like Dragy is great for doing that.
alex_beridze alex_beridze is offline
Car: BMW 335
Default 12-18-2018, 07:32 AM
Hello Terry
I need to use PI for meth with fuel it rail and jb4 pi controller, but for IAT cooling I need to use charge pipe meth too with 4CM nozzle. how I can use both system at same time? I don't need logging of charge pipe meth I need only control it with solenoid from jb4. is it possible?
BR Alex
Car: guess...
Default 12-18-2018, 09:35 AM
Originally Posted by alex_beridze
Hello Terry
BR Alex
So you want to run 6 meth injectors via PI through the Fuel-It rail and control them with the PI Controller, right? Were you going to run a meth line from the fuel(meth) rail to a single meth nozzle in the chargepipe? You could put a hobbs switch controlled solenoid in the CM4 line. The rail would supply the meth to the PI injectors AND the CM4, the PI controller would turn on the pump(via 10A relay), solenoid and fire injectors and the adjustable hobbs switch would activate the ground to the solenoid running to the CM4.
I think anything's possible if you have the time, money and determination.
Car: BMW 335
Default 12-18-2018, 10:02 AM
Hello
Can i run solenoid directly from JB4 without hobbit switch?
Default 12-18-2018, 11:13 AM
Hello
What are you trying to do?
Car: BMW 335
Default 12-18-2018, 11:24 AM
Hello
I need to run PI controller for meth and for IAT cooling need olso one 4cm nozzle on the chargepipe, but i dont know where connect solenoid for chargepipe meth. Trebilla sed i dont need fsb i must attach solenoid directly to jb4 but dont know how
Car: guess...
Default 12-28-2018, 10:26 AM
If I connect the G5 NLS relay kit's output to a meth pump, will the "External Trigger" values of the JB4 interface be relevant to when the pump turns on?
