(#326)
Default 10-01-2017, 08:48 PM
The MMPs tend to have very tight wasteagtes, so you'll want to start with menu12 low like around 1500rpm, and a relatively flat duty bias (with RPM FF gain disabled), and evaluate something like map2 to start.
Angel67's Avatar
Angel67 Angel67 is offline
Default 10-01-2017, 09:21 PM
Many thanks, Terry. Much appreciated.
Stay tuned (pun intended!)...
a
ps: On the stock turbos running the OTS Cobb Stage 2 + FMIC Agressive map, on Canadian 94 octane, it was peaking around 18.5 psi, but with the addition of the MMPs plus inlets / outlets plus the new LPFP (only those three changes) it was peaking at 20.2 (assuming the old stock TMAP was reading this right) but AFR was not good.
E92 335xi
arhoads335i arhoads335i is offline
Default 10-03-2017, 05:01 AM
Hey Terry I'm having some waist gate rattle on acceleration. These are brand new stage 1 turbos. I've played around with menu 10 a ton and i can not find a spot where it goes away. The rattle occurs around 1-3 psi. But once over 3-4 psi it stops. It's at partial throttle. Any ideas? I hear there can be some tuning done to the WGDC that can help with this.
K.Jameel K.Jameel is offline
Car: BMW E92 N54
Default 10-04-2017, 06:07 AM
I have the same waist gate rattle when i had set menu12 low like around 1800 / 1900rpm
The rattle occurs around 1-1.6 psi
BMW 335i '08 E92 N54, JB4 G5 IOS, BMS DCI, VRSF ***, BMS-Tial BOV Kit with Chargepipe, VRSF FMIC, BMS Meth Kit, JB4 MHD BEF, BMS PCV valve, BMS OCC. TCU Alpina_B3 Flash, .
Default 10-04-2017, 06:32 AM
did it get fixed when you moved it up? I can't get it to move past 3k but it still makes noise at 2600
Default 10-04-2017, 03:18 PM
Menu10 stops being used around 1psi, so 2-4psi, would be menu12. If you can capture the rattle in a log you can then identify the WGDC its coming up under and try to tune around that.
woo24 woo24 is offline
Car: E82 135i
Default 10-05-2017, 05:17 AM
n54 135i FBO wif inlet n wmi
juz install vargas stage 2
which flash sould i install?
Default 10-05-2017, 05:50 AM
Right so I turned menu 12 up to 3000rpm, it sounds way better but there still is the slightest bit of rattle. Is there a way to lock in a value higher than 3000rpm?
Car: BMW E92 N54
Default 10-05-2017, 06:08 AM
when it was the default value 2800 no rattle / noise down low to 2500 it's fine.
also notice when i had set it to 1500 car stars to smoke slightly when revving even my turbos are new.
N54QC N54QC is offline
Car: 07 BMW 335i
Default 10-05-2017, 01:21 PM
If you are running 93oct and meth, use the race flash.
Car: E82 135i
Default 10-07-2017, 01:36 AM
got it thank
Angel67's Avatar
Default 10-07-2017, 08:06 AM
Anybody have experience with Torco octane booster?
They say 16 ounces takes 10 gallons of 91 to 96 and 32 ounces takes it to 101, or 16 ounces in 93 takes it to 98 and 32 takes it to 103.
Would we use the Race BEF for all the above combinations (ie, 91 treated to 96 or 101, or 93 treated to 98 or 103).
E92 335xi
naoaki's Avatar
naoaki naoaki is offline
Default 10-09-2017, 01:41 AM
Hello. I am running Turbo Lab stage 1 turbo MMP inlet and outlet FMIC and BMS meth kit dual CM 7. The fuel is 94 octane and E 85 is not used. I am wondering how much to start with the number to start setting up. How much psi should I start with?
BMW 2007 E90 335i
Default 10-09-2017, 07:57 AM
Start with a 40 addictive and evaluate.
Peguecha Peguecha is offline
Car: 335i n54 manual
Cool 10-18-2017, 03:43 PM
Hi, good day to all.
I live in Mexico and I do not have good tunners in these states, I would like to ask for your help, I have an e92 with Intercooler big autowerk, meth devilsown, intake inlets MMP, chargepipe with blow off tial, Turbocharger's Hybrid Hexon R550, JB4 burger
I have the cable and interface for MHD but I want to ask for your help to put the best tunning to my car, I am currently using the map 5 of jb4 and wanted to ask for your recommendation.
Greetings to all and excellent cars yours.
Car: 07 BMW 335i
Default 10-18-2017, 04:14 PM
You can either do some logging and post in the support section and people can help you dial it in or you can do a remote custom tune through someone like Trebila.
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 10-19-2017, 12:01 PM
Terry,
Flat DB meaning, small incremental from 50, say 51,52,53....?
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
Angel67's Avatar
Default 10-19-2017, 07:17 PM
I have a very similar setup. Dyno tuning session ended up producing a curve (aiming for a 400bhp daily driver tune):
DB
15 50
20 50
25 50
30 50
35 56
40 54
45 50
50 47
55 47
60 45
65 45
70 43
E92 335xi
najin23's Avatar
Car: 335i CDV
Default 10-19-2017, 07:42 PM
I will reference that. Thank you very much
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
najin23's Avatar
Car: 335i CDV
Default 10-22-2017, 08:14 PM
Now, for the initial test, you set all the user settings to the one at the first post, then you do map 6 to test or map 2?
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
Angel67's Avatar
Default 10-22-2017, 08:28 PM
I think I would start with 2.
E92 335xi
najin23's Avatar
Car: 335i CDV
Default 10-23-2017, 07:51 AM
Ok, Thanks. BTW, what is your settings? Fuel? Flash? Any concerns about the turbo kit?
How do you like it so far? Your insight helps me a lot. Thank you very much.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
Angel67's Avatar
Default 10-23-2017, 08:11 AM
Pump BEF on 94 AKI. What other settings you asking about (besides DB which is as above)?
E92 335xi
Angel67's Avatar
Default 10-23-2017, 08:12 AM
And yes I like the MMP turbos very much.
E92 335xi
Default 10-23-2017, 09:48 AM
Always start with a mild map like map2 to evaluate the dutybias tuning, boost control, fueling, etc.
