(#4251)
x99percent x99percent is offline
Car: 2008 135i
Default 07-28-2017, 09:38 AM
Originally Posted by Dmac @ BMS/DMD
Are you still able to replicate this easily?
Not anymore. No longer have that phone (my experience with the Sony phone was short-lived... returned it due to a defect) and the replacement Samsung has no issues.
(#4252)
BlackB's Avatar
BlackB BlackB is offline
Car: BMW e92 335i
Default 07-29-2017, 01:24 AM
Hello,
After the update no connection from the JB4 telephone BT to the mobile phone with BT A162 and A162 of the software made. In the software everything is as pre-set (E-Serie-N54, Bluuetooth-Rev3 ...) Why "not currently logged in"?
Greetings from Germany
(#4253)
as3.0cl as3.0cl is offline
Car: 335is
Default 07-29-2017, 05:11 AM
Galaxy s8, on android 7.0
couple of things i have noticed.
First, the app will randomly disconnnect and then i have to reconnect to the JB4. this is using the BT connect kit v3. the connectivity is intermittent and is hard to replicate
2011 335is - Alpine White on Red - JB4+Trebila BEF l BMS DCI l Mishimoto IC l BMS OCC l Phoenix CP l BWS WMI 100% CM5+CM10 l Turbosmart Plumb Backs l N54tech Dpipes
(#4254)
DB90 DB90 is offline
Car: M135i
Default 07-29-2017, 06:23 AM
iPhone 6, rev 2, latest app version.
I live in the U.K. However my Country is coming up as Norway. I've tried loging in and out to see if it will change but it hasn't. I'm not sure if this is affecting the auto code clear because I've had a few ******* ******** dectected codes recently. To my understanding countries outside of the USA weren't going to be affected?
M135i 8AT / JB4 + EWG Harness / N20 TMAP / VRSF 5" HD FMIC / Fuel-It TBI / Fuel-It STG2 LPFP / Pure High Flow Inlet / FTP Charge & Boost ***** / Richter ***** / Backbox delete / E50 Fuel / ngk 5992s / BBS CH-R's / KW V3 Coilovers / M4 LCA's / GP Front Splitter & Side Blades.
100-200kph: 7.8s
1/4 mile: 11.9s @ 120mph
(#4255)
BlackB's Avatar
Car: BMW e92 335i
Default 07-29-2017, 10:18 PM
JB4 mobil BT Rev.3 to Android after the update to A162 = "Must be logged in to connect."
(#4256)
SINasTER's Avatar
SINasTER SINasTER is offline
Car: BMW 335xi E90
Default 07-31-2017, 04:17 PM
Maybe it's a stupid question but what is the new dial on the app named E85??
I don't use E85 but it indicates around 40-55 on that dial... Is it the octane rating Or something like that??
BMW 550 M-Sport xDrive 2011
JB4 stage 2
Custom 3" D.P.s
ESR RF2 19" wheels
(#4257)
JazRedGT JazRedGT is offline
Car: 2007 335i E-92 6AT
Default 07-31-2017, 08:33 PM
Its the virtual e85 rating of your current fuel. You have to set the offset to 132 under the WMI settinvs page for it to read somewjat accurate.
2007 AW 335i E-92 6AT MMP Stage 3 @ 25psi / JB4 G5 ISO / XHP STG3 / VRSF D-Ps / MMP INLETS&OUTLETS / WEDGE MHD E50 BACKEND / CW EXHAUST / CPe CP / GReddy RS BOV / BMS METH KIT / WAGNER IC / PR STAGE3 LPFP 10.92 @ 132 1.72 60ft 6.96 @ 103 1.55 60ft
(#4258)
MaxiMuse's Avatar
MaxiMuse MaxiMuse is offline
Car: BMW E93 335i (JB4 G4)
Default 08-01-2017, 12:01 AM
Hi everyone, what is about the OSx support for JB4?
*How To Get It:
Link temporarily removed. Will be back up Sunday/Monday.
When this link will be back again, on what Sunday or Monday???=)
I am waiting for a while...
(#4259)
finnd1's Avatar
finnd1 finnd1 is offline
Car: 2009 e60 n54
Default 08-01-2017, 06:45 AM
Perhaps your phone is pining for the fjords? I understand Norway is quite beautiful.
(#4260)
Ridergas Ridergas is offline
Car: BMW M135i F21
Default 08-01-2017, 06:53 AM
M135i N55 B30A
Samsung galaxy S6
Android 7.0
interface version A162
N55_FSERIES_OBDII_PWG_11_T1.hex
I can't connect in bluetooth ? Before it worked ?
The message Error Must be logged in to connect
(#4261)
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 08-01-2017, 11:39 AM
Originally Posted by Maximum996
With the latest update, is pwm always pegged at 99?bug?
iOS, Android, or OS X?
Originally Posted by moffe
I must say I haven't checked yet if these things are fixed yet on the latest beta:
But I have noticed before that the gears in Golf R facelift the 7th gear is not shown, only 6.
Also oil temp is not working.
And code reading does not work, I have fault codes and it's not shown in the app. When using ODB eleven or VCDS they shows.
Is there any date when 0-60 will be added back and is it possible to have 0-100km/h and perhaps use ODB readings for the speed and/or GPS? So that you could choose by yourself? I have noticed that the speed from ODB is pretty much the same that GPS is shown, for me at least
The gear thing is JB4 related as I've tested the interface manually with input up to 10 and it works fine.
Not all params are supported by all engine types so you'd need to make sure your type supports that and that your JB4 firmware is current. As far as code readings I've not had a single report that it isn't working and I know its working fine on my end. Maybe double check your CANbus/OBDII connection?
0-60 (estimation) is already on iOS and now that the big server update is out on all platforms I can get back to messing with it on Android. Again, 0-60 IS NOT THAT ACCURATE with any mobile device due to the slow 1hz gps refresh rate of pretty much all mobile devices.
Glad to hear you don't have the issue anymore.
Originally Posted by BlackB
Hello,
Means you need to create an account and login to it from the Account Settings in the app.
Email me. support@jb4connectkit.com
Only USA, you're fine.
*How To Get It:
Look a few posts up. I posted the link a few days ago.
Originally Posted by Ridergas
M135i N55 B30A
Samsung galaxy S6
Android 7.0
Create an account and login to it in the settings page of the app.
(#4262)
ehagerty ehagerty is offline
Car: 2014 F22 M235i
Default 08-01-2017, 01:50 PM
Does this work without any additional hardware? What about on the F8x platform. I am utilizing the fuel sensor to run the additional higher maps and mixing.
(#4263)
risktaker76's Avatar
risktaker76 risktaker76 is offline
Car: BMW 440XI MPPSK
Default 08-03-2017, 10:18 AM
What is the FuelEn Gauge? What is the scale and what is normal/abnormal?
Why cant we have a simple FAQ or manual with all parameters... I always feel likes it pulling teeth with the JB4 and the JB4 app..
(#4264)
Car: 335is
Default 08-03-2017, 10:23 AM
http://www.n54tech.com/forums/showthread.php?t=21269
(#4265)
Default 08-03-2017, 11:34 AM
Thats outdated - good amount of the information isnt relevant anymore with the B58 and much of it is cryptic... Its a good start but useless once your deep into tuning..
We need that updated with MUCH MUCH more details.
(#4266)
Mr. T Mr. T is offline
Default 08-03-2017, 11:01 PM
Does the OsX version of the jb4 app support the virtual flex fuel sensor?
Edit: NVM, upon further inspection I think I found my answer
(#4267)
Car: 2008 E93
Default 08-04-2017, 04:21 PM
Whats the purpose of having to sign up for an acct and logging in ???? For jb4 mobile
(#4268)
afranke afranke is offline
Car: 2013 ActiveHybrid 3
Default 08-04-2017, 07:38 PM
Did the option to view meth flow in the iOS app disappear? I can't find it on the list for the gauges.
(#4269)
BlackB's Avatar
Car: BMW e92 335i
Default 08-07-2017, 07:56 AM
After logging in, everyting goes!
JB4 G5 Map6+7/BT Rev.3 Android/MHD V8.0 S2+E85+BEF/Wagner FMIC/BMS WMI CM10/RB Ex.PCV+Mishimoto OCC/Oil Cooler+Mocal Valve+Stead Line+BMS Billet Oil Filter Housing/BMS N54 DCI o. SIMOTA Intake/MMP ALU In+Outlads/MMP S3 Turbo/BMS OCC/Precision Raceworks Ignition/NGK/M3 Cowl Filter/BMS ALU Chargepipe/Phoenix Racing Port Intake JB4 PI Module+Fuel Line Y-Adapter+Ethanol Sensor/Fuel IT S3+Hobbs switch12.5Psi/6AT Oil Cooler Xhp/Wavetrac/Powerflex/H&R/M3 Suspension Parts/B16 PSS10/N20 T MAP.
(#4270)
Car: 2008 135i
Default 08-07-2017, 12:55 PM
Yes. Anyone using the beta OS X app (link in the previous page) please let me know if you have any issues.
Security.
Did you toggle Using Ethanol Kit in the settings page?
(#4271)
Default 08-07-2017, 12:57 PM
Yes, as I think I am using the kit (Fuel-It rail/BT sensor and BMS PI controller).
(#4272)
vam0s vam0s is offline
Default 08-10-2017, 10:13 AM
What should i do?
I bought jb4 app but supprisingly the app doesent work with my phone beacuse it only recognizes powered usb hub. Is there anyway to get around this setting? My phone is Huawei p10+
(#4273)
DaZuc DaZuc is offline
Car: 335i xDrive
Default 08-10-2017, 11:12 AM
Originally Posted by vam0s
What should i do?
You need a device that supports OTG.
(#4274)
jager335 jager335 is offline
Car: 08' Bmw e92 Msport 335i
Default 08-11-2017, 10:49 PM
Hi I'm in Australia and I cannot turn on passive delete through the jb4 app. Everytime I slide the switch to on with the accessories on and engine off and click to save the settings I get an error saying N20 valid number 0-1 and won't let me save it. Does anybody know how I could fix this?
Thx
Adam.
(#4275)
Car: 2008 135i
Default 08-12-2017, 12:29 AM
That setting isn't really needed anymore with the new E85 options. Just follow the E85 setup in the WMI tab and disable the "Using Ethanol Kit" option.
Thx
Adam.
iOS or Android? Email me. support@jb4connectkit.com
Also I'll have some news for everyone tomorrow about a requested feature coming to the next iOS and Android builds.
Closed Thread
