(#3251)
copperman05 copperman05 is offline
Car: BMW M135i
Default 03-11-2016, 10:04 AM
Originally Posted by YO335IVERT
Why I can't get the app to download the firmware? Has anyone having this problem? Phone connect to jb4 but when I go to firmware, it shows that it's about to download but when I go to the green arrow nothing shows up.
You have to wait for the forum page to load then find the required fw select and it will download and be available to update.
M235i 8AT JB4, EWG, BCS DP, BCS powervalve catback, Wagner FMIC.
(#3252)
str8shot str8shot is offline
Car: N54 135i
Default 03-11-2016, 04:25 PM
Anyone have this issue? Text for map selection, and menus to set gauge types are all behind the gauges and unreadable.
Nexus 7 running 5.1.1 I believe.
2008 Montego Blue 135i Coupe // Sport Package // JB4 G5 Iso in passive mode with custom e30 MHD tune // Bluetooth e85 content analyzer with JB4 integration // Walboro 255 inline pump // BMS downp|pes // VRSF 7" FMIC // ER charge pipe // Turbosmart BOV // Injen intake // M-Factory SMFW // F10 550i clutch // Vorshlag camber plates // Hotchkis FSB // Turner adjustable drop links // AST 5100 coilovers // Hawk HPS pads // Ti backing plates // Stoptech stainless lines // Turner 15mm front spacers
(#3253)
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 03-11-2016, 07:32 PM
Back from my trip.
Originally Posted by kharma
Interesting. What's your engine setting in the app? I get brief moments of RPM readout under load but usually nothing. I'm just trying to understand what we can expect to work for the VWs, anything here is a bonus IMO as I purchased mainly so I don't have to lug my laptop along to switch/tweak maps and log.
Xperia Z3 Compact
5.1.1
(VW)
A075
I'm not familiar with the VW cars at all. If you're having specific issues that are JB4 related, I'd post a request in the support section.
Originally Posted by The Leopard
I like the new update. The two findings I have are:
  • Gauge color - please change back to red. Red matches all of the lights and gauges in the car. Green, besides sticking-out and not looking as good, is visually distracting while driving due to contrast with everything else.
  • Small spacing issue on DME code tab
The release versions of the updates will have selectable gauge colors.
Which spacing are you referring to?
Originally Posted by Pips
I've tried all the engine settings, doesn't really matter which one. Rpm goes crazy regardless.
I'm just worried that it's something with the JB1, if the rpm readings are faulty for the jb then the maps won't work as supposed = less power.
I don't have a windows machine (my work laptop wouldn't recognise the USB drivers for the jb program at all) so right now I can't verify my suspicions. Will maybe get hold of a win laptop during the weekend.
A few people have mentioned RPM issues so test it with the USB Windows interface and let us know.
I'm not sure if I'm posting this in the right place but here goes. I just got the app and running it from my samsung note 4 phone via OTG cable the app works great, but now my steering wheel controls to control the JB4 don't seem to be doing anything, when I try to go into the JB4 menu my dash has the orange screen comes up but it does not display what menu I'm in nor what settings is running on the car, but on the app/phone it shows that i'm on map2 but not on my dash, I've tried changing the menu by using the up/down volume button as well as the up/down track button but nothing happens on the dash but only on the app the speedo or the rev don't move as it use to prior the use of the app when changing menu or maps. What can I do to get my dash to function back to normal via steering wheel control, I thought the app is suppose to work in conjunction with steering wheel control. I'll post a video of this also....please help btw I'm running firmware G5 ISO 32-0-2
That's very abnormal. I use the steering wheel controls with the app connected all the time. Did you recently update your firmware? Does it still do it with the kit disconnected?
iOS or Android? Does it show that the hex file actually downloaded?
I'm guessing you are in my beta group? Which build version?
(#3254)
BobVader's Avatar
BobVader BobVader is offline
Car: 335xi 2008
Default 03-13-2016, 06:03 AM
I have rev 2 of kit wit ios app (last version)
My problem: I can select oil temp and water temp...but read nothing ....always at 0...why?
Jb4 g5 iso for n54
'08 BMW 335xi // Sedan // Black Sapphire // Sports Package//Mods: JB4 G5 iso|MHD bef Race|Hexon rr600|inlets|stage 2 fuel pump|N20 tmap 3.5|Chargepipe|Diverter valve|RB pcvalve|BMS Meth kit|AA Speed Delimiter|BMS tuning gauge|UR CL DP|BMS DCI|AA Exhaust|HELIX fmic|CDV|H&R coilover|10mm Spacers H&R on 4 wheels|**Record for XI's on dragtimes.com, before new turbo and inlets...new results soon...11.768s@118.70**Top speed 186,4 mph GPS, vbox 60-130mph 7.9,
(#3255)
Car: 2008 135i
Default 03-13-2016, 11:17 AM
Jb4 g5 iso for n54
Sounds like you need to update your JB4 firmware. What version are you currently on?
(#3256)
BobVader's Avatar
Car: 335xi 2008
Default 03-13-2016, 03:07 PM
2013 version...best perf for my car...I need uppgrade ? ****!
(#3257)
Caruso0644's Avatar
Caruso0644 Caruso0644 is offline
Default 03-13-2016, 06:29 PM
When I connect none of my gauges work and can't check codes? Seems to have all my user settings though and tells me correct map. I updated my JB4 through the app as well. Any idea?
15' M4 : JB4 : BMS intake : Meisterhaft full exhaust : AR DP's : MSR Charge ***** : H&R Sport Springs / 08' E92 335i : Montego Blue : JB4-G5 : DCI : BMSMeth : BMSoilCC : VRSF DP's : VRSF Front Mount : 19" Vertini Magic : Bridgestone RE-11 : Carbon CSL Trunk Lip : MtechRearBumper : Mtech FrontBumper
(#3258)
Car: 2008 135i
Default 03-13-2016, 07:10 PM
I don't understand your question.
That's usually a problem with the CAN wires or OBD hookup. Log?
(#3259)
Caruso0644's Avatar
Default 03-13-2016, 07:22 PM
That's usually a problem with the CAN wires or OBD hookup. Log?[/QUOTE]
Ahh I still have to hook up my OBD cord, I never did that. I was unaware it was needed for the Bluetooth setup.
(#3260)
Caruso0644's Avatar
Default 03-13-2016, 07:23 PM
Can I hook the CAN wires or should I hook up OBD cord?
(#3261)
Car: 2008 135i
Default 03-13-2016, 07:28 PM
Ahh I still have to hook up my OBD cord, I never did that. I was unaware it was needed for the Bluetooth setup.[/QUOTE]
The JB4 has to get access to the CAN bus to get a large chunk of the logging info.
That would be a question for the general support section.
(#3262)
The Leopard's Avatar
Car: E92
Default 03-13-2016, 07:31 PM
The connection loop issue reappeared for me today. 6 connects each time.
Also, when can we get the red gauges back? This is a serious issue for me.
TS N54
(#3263)
Car: 2008 135i
Default 03-13-2016, 07:37 PM
A084 should have it fixed again. Should be live in the next few hours. I'll try to look at adding in the color options this week. After that, if everything is good it should be time for the next public release.
(#3264)
BobVader's Avatar
Car: 335xi 2008
Default 03-13-2016, 08:30 PM
Just because with new firmware my car boost 10-12 psi and poor performance...with old firmware...17.5 psi and very good performance. I don t know why
If I want new gauge...i need new firmware but car don t perform well... I must stay with old firmware... But no water temp and oil temp...very damage
(#3265)
Car: 2008 135i
Default 03-13-2016, 09:25 PM
You'll need to make a post in the general support section for JB4 firmware related questions.
(#3266)
Car: N54 135i
Default 03-14-2016, 06:56 AM
A081 is the build number. I'm not sure if I'm in the beta group or not.
(#3267)
Car: 2008 135i
Default 03-14-2016, 07:53 PM
Yep, that's an older beta. Update to the newest one.
(#3268)
Jschappert1 Jschappert1 is offline
Car: m235i
Default 03-14-2016, 08:10 PM
How can I get in the beta?
2014 M235i AT
JB4 Stage 2
Intake
35% e85
(#3269)
Car: 2008 135i
Default 03-16-2016, 11:57 AM
https://play.google.com/apps/testing...o91.jb4_mobile
(#3270)
Car: m235i
Default beta - 03-16-2016, 12:05 PM
Hey is there a testing for Ipad? or just android?
if you have an ipad beta that would be awesome plz let me know and if not can u put me on list for when it does
best
Jeff
2014 M235i AT
JB4 Stage 2
Intake
35% e85
(#3271)
Car: 2008 135i
Default 03-16-2016, 12:17 PM
best
Jeff
Yep. Just need your iTunes email address.
(#3272)
Car: m235i
Default itunes user acct - 03-16-2016, 12:33 PM
Jeff.schappert@gmail.com
thank you
2014 M235i AT
JB4 Stage 2
Intake
35% e85
(#3273)
iturbo's Avatar
iturbo iturbo is offline
Car: 2009 335i e92
Default 03-16-2016, 01:54 PM
Checking in after several months to check if 0-60 timing works yet?
2009 335i e92 n54 | FBO | JB4 | e85 flash |
(#3274)
Car: m235i
Default 03-16-2016, 02:03 PM
how do i download it now o will it get sent to me? and is it for ipad or laptop
2014 M235i AT
JB4 Stage 2
Intake
35% e85
(#3275)
Car: 2008 135i
Default 03-16-2016, 02:15 PM
I'll add you today.
It's still disabled as I haven't had time to mess with the new external GPS modules.
Question to users: As far as 0-60/quarter mile do you want a precision tool or a fun toy? If you just want a fun toy we can use the built in GPS modules which have a terrible 1hz refresh.
Closed Thread
