(#476)
135idct 135idct is offline
Default 06-19-2014, 12:37 PM
Causes unnecessary pollution so you should route it back to the intake path even for dedicated race cars.
i mean this one..
Default 06-19-2014, 12:39 PM
Oh, it can stay there, or be removed. Doesn't matter. Ours were removed.
Default 06-21-2014, 03:33 PM
Terry, ill try 14.7psi spring instead of 9psi
what do u think?
Default 06-21-2014, 07:54 PM
what do u think?
Can't hurt to try it. Ideally the 12psi spring is what you want though.
Default 06-22-2014, 01:27 AM
12 spring works great. I don't know what's so hard to just go by what is proven to work lol.
spirit35 spirit35 is offline
Car: 335 N54
Default 06-24-2014, 02:19 PM
That power is expected for a kit FFTEC5862 top mount with 93RON?
alexim's Avatar
alexim alexim is offline
Car: 1M
Default 06-24-2014, 06:56 PM
T, couple logs on maps 3 and 4. How's it look? Replaced the WG spring but boost still drops on high rpm...
Default 06-24-2014, 06:59 PM
Looks good. Is CPS2500 set to 1?
alexim's Avatar
Car: 1M
Default 06-24-2014, 07:01 PM
It is.. And CPS2000 is 7 and FUB is 1..
Default 06-24-2014, 07:03 PM
Raise DWP up to 65. Also grab a photo of the settings page.
alexim's Avatar
Car: 1M
Default 06-24-2014, 07:08 PM
Here's a photo... I had DWP at 55 but had a boost spike of 26psi on 3rd.. So lowered to 50 (that's what it was at on those logs)... Should I still try 65??
Default 06-24-2014, 07:11 PM
I'd have to see the logs. When raising DWP you normally need to lower FF a bit so it can learn back up. Or you'll get boost spikes until it does.
I'd probably raise PID gain to 30 as well.
alexim's Avatar
Car: 1M
Default 06-24-2014, 07:15 PM
Great... I'm on vacation now. Will test and post later.. Thanks a lot!!
Default 06-24-2014, 07:17 PM
On second thought PWM is only at 70% in those logs. Maybe just bump DWP up by 5 and see how pid gain 30 and 35 look.
Default 06-26-2014, 04:05 PM
Terry, if i run a manual boost controller what should i do to: DWP,FF and PID gain.
Default 06-26-2014, 04:26 PM
Just don't do it, MBCs don't work right.
Default 06-28-2014, 05:17 AM
is this code normal, sometimes it appear 2C7C lambda probe behind catalytic converter 2, signal
im running straight pipe to the oem muffler.
Default 06-28-2014, 08:40 AM
Signal code wouldn't be normal. But rear o2 sensor codes are to be expected as you are mixing the signals where they are normally separate.
Kit335 Kit335 is offline
Car: Bmw 335i
Default 06-28-2014, 07:03 PM
Originally Posted by NJrep335I
Already running BMS OCC, so check. Having a hard time trying to picture the routing for the line back to the inlet filter. Seems all Cone inlets are run directly off the turbo without any other fittings.
A picture would be great if anyone has one. Thanks!
Would like to see a picture as well. Need help with this too.
sch4400 sch4400 is offline
Car: 08 535i
Default 07-01-2014, 11:13 AM
attached Log files.
map3, and map7 with meth.(55% meth +45% water)
The boost little bit over boost on map3.
what set up should I change....??
any problem on the log??
Default 07-01-2014, 01:45 PM
Originally Posted by sch4400
attached Log files.
Logs look good. Clean trims and pretty is being maxed out on map 7. LPFP is at the lowest I'd push it to and timing isnt dropping either so thats good. Only thing is map 3 is over boosting, not sure why. Map 7 is on dot though.
Car: 08 535i
Default 07-02-2014, 08:00 AM
I was running several time to test the map 3 and map 7.
but..map 7 and map 3 was not reallly faster than map 1. I don't know why...
There is kinda of private road 1.6 km .... and I did full gas pedal each time.
The map1,map3,map7 was almost same speed around 250km .
gear ratio problem???
Default 07-02-2014, 08:12 AM
When looking at single turbo logs always look at FF vs PWM. If FF is much higher than you should manually lower the FF value to speed up its learning process. In your map 3 log its wayyy too high. Should probably learn down to around 100. The map 7 log is closer. Needs to learn down maybe a couple more points.
Car: 08 535i
Default 07-02-2014, 08:20 AM
thanks...
The FF was around 140.
so..I will try the ff value 100.
Default 07-02-2014, 08:26 AM
Just change it to 100 for map 3 and then it will adjust itself up or down as needed. It remembers it on a per map basis.
