(#2726)
Twilly Twilly is offline
Car: 07 335i 6MT
Default 11-30-2017, 06:20 AM
wastegate pressures are now where they are suppose to be (9-10pai) ! but other map I cant get over wastegate pressure. I will double check my lines but does it matter what connector I plug the Mac solenoid in to?
Default 11-30-2017, 08:41 AM
It does not. If you're not able to build boost over WG spring when WGDC is going up then then you will want to isolate whether you have a physical or electrical issue with the boost control.
Car: 2013 Genesis Coupe
Default 12-06-2017, 10:29 AM
I bought the Mac solenoid from the bms website and the vacuum npt nipple size seems to be 1/8", my turbo kit came with 1/4" vacuum lines, would 1/8" lines be sufficient enough for vacuum lines?
Default 12-06-2017, 10:30 AM
I'd suggest using hard lines, not rubber lines. But the size doens't matter much.
Default 12-06-2017, 12:09 PM
Yes I plan on using stainless steel lines, just wanted to make sure I got the right size lines
Car: 07 335i 6MT
Default 12-06-2017, 02:51 PM
I keep getting kicked out of maps for too lean. I have ADV sensors, I clicked ADV sensor option in MHD is there any changes I have to make in the JB4?
Default 12-06-2017, 05:47 PM
JB4 log?
For ADV sensor disable the JB4 single turbo o2 sensor pressure compensation.
imad777 imad777 is offline
Car: BMW 335i
Default 12-07-2017, 04:45 AM
Hello guys, few questions on NLS/2step
1. I can't hold the set revs for the start. It starts with 2.500 (where 2500 is the setting) for example, goes to 3500-4000 and then back. Never stable
2. Rolling launch isn't working at all, or again flies with revs
3. I am unable to set setting 4/4 in the JB steering wheel menu (it jumps back to 4/3
Any help is appreciated. No sure if relevant, but the car isn't running "shelf" flash, so if JB4 BE flash is a mandatory, then I will try with it first. It single turbo setup..
2007 335i MT N54
MHD+JB4 Garret GTW3684 ST
FMIC, DP, 3" *****, Fuel-It Stage 1, MF LSD.
Default 12-10-2017, 02:51 PM
For anti lag to work several flash changes are needed. Did you migrate those over?
sch4400 sch4400 is offline
Car: 08 535i
Default 12-11-2017, 08:00 AM
any link to buy the hard lines???
I use the rubber lines...the rubber lines already 3 times replaced..
Car: 07 335i 6MT
Default 12-26-2017, 10:36 AM
hey guys im having an issue still with having jb4 control boost over wastegate pressures.
heres my log, wonder if you guys can see something im not seeing. Ive checked my lines they look fine. and I have done the proper jb4 BEF and Frimware files.
VM 6266, CKI o2 sensors, stock Map sensor
Please let me know what you think or if you guys have any other suggestions!
p.s first time posting a log so hopefully it worked
File Type: csv 2017-12-21 18_21_35 single turbo log.csv (11.4 KB, 107 views)
phv628's Avatar
phv628 phv628 is offline
Car: BMW 2009 335i xdrive
Default 12-28-2017, 06:41 AM
Looks like you're nowhere near target boost. Did you plug in your MAC solenoid?
|E92 335i xDrive| |JB4+MHD BEF| |VM Single Turbo Kit + PTE 6466| |Built Auto Trans| |xHP Trans Flash| |Stage 4-Triple Walbro 450s, fpr + return| |EOS Intake with Port Injection| |AD-ENG FMIC + AD-ENG OCC| |RB PCV Kit| |PR Ignition kit| |Built N54: Darton Sleeved, Manley I-Beam Rods+ARP Rod Bolts, JE 9.5:1 Pistons, JE Wrist Pins, VAC coated main & rod bearings + ARP Head Studs| |Keyed crankshaft snout, crank hub, timing & oil pump sprockets + VTT crank-bolt capture| |ADV Oxygen Sensors|
Default 12-28-2017, 03:46 PM
Assuming you get the same boost on map1 (WGDC pinned at 0%) then its some sort of mechanical or electrical issue on the solenoid or wastegate.
Car: 07 335i 6MT
Default 01-02-2018, 02:30 PM
hey Terry thanks for the reply. Im trying to see if I have an electrical issues with the solenoid. any suggestions on how to test the solenoid? I figured Id just hug up my voltmeter to the back of the solenoid and see if I see any voltage while the wgdc is changing.
Default 01-02-2018, 09:31 PM
In the frist post we might have some directions, or in the thread. If you can get WGDC around 50% at idle you should hear solenoid clicking away.
rac rac is offline
Car: 2008 135i 6MT
Default 01-04-2018, 10:40 PM
How is load scaled / reported back to the dme on the current firmware when going to an n20 tmap? Is load capped, scaled linearly from 75, or something else? Want to know how to adjust my flash to suit.
Default 01-06-2018, 05:19 PM
Just log and look at dme bt, ECU psi, and load.
Default 01-15-2018, 09:15 AM
I'm almost done with my ST install, do I need to reset my JB4 setting back to default or will the firmware change the settings when I upload them? I'm aware of setting ff low and letting it relearn and setting dwp at 75 as a starting point but I'm mainly referring to fuel open loop, etc. Also, will fresh stock spark plugs be good for safety 17psi? I'm working on isolating an issue before putting my ngks.
Default 01-15-2018, 10:26 AM
You'd need to manually change any settings. Key is evaluating map1 first to ensure your hardware is OK. The map2 to ensure you achieve boost control of a low boost target. Before moving forward.
Default 01-15-2018, 10:32 AM
So what settings do you recomend to manually change initially? My fuel open loop is at 90, ff is somewhere in the 90s, and dwp is at default, this is on my current twin setup. Once everything is installed tonight I'm going to flash to the st firmware
Default 01-15-2018, 11:07 AM
Just input the values that are on first page of this thread.
Default 01-15-2018, 11:16 AM
Got it, thank you very much
Default 01-15-2018, 02:27 PM
Start with map 1 as Terry said to make sure youre hittigg WG boost. Then move onto map 2 etc evaluating the logs as you go.
Default 01-15-2018, 02:31 PM
What E85 mix do I need for 20psi for map 2 or would 91 pump be fine?
Default 01-15-2018, 07:49 PM
When you do the map1 log if boost looks like this, way out of control, you know there is a physical issue with the WG or solenoid plumbing.
