(#4526)
P.S's Avatar
P.S P.S is offline
Car: M135i xDrive
Default 03-08-2018, 03:42 AM
Latest beta version for android doesn't recognize phone orientation. Therefore can't be used in landscape orientation, which is pita because phone blocks iDrive screen.
And log graphs are pretty useless at portrait mode.
M135i xDrive EWG, JB4, Pure S2, Pure inlet, N20 tmap, c a tless, Wagner fmic, FTP chargepipe, Fuel-it PI, BMS PI controller, Fuel-it lpfp, ACF Performance back end flash. 10.9s @ 204km/h
(#4527)
WaqasRiyami's Avatar
Car: Bmw 535i - 2011
Default 03-08-2018, 02:16 PM
Device: Galaxy S8
OS: Android 8
Engine type: N55 F-Series
App build: JB4 A219
Kit Revision: Rev 3
JB4 Firmware Version:ISO_10_T6.hex
Is there a new Beta ?? i am not getting any updates in my android, but i am in the beta group
(#4528)
Pho3niX90 Pho3niX90 is offline
Car: 2013 M5
Default 03-13-2018, 04:34 AM
Originally Posted by Dmac @ BMS/DMD
iPhone only at this time. Most of my Android dev time has been spent trying to make BT functionality more seamless for the majority of users/devices. It's in a better place than it was and will be even better with the upcoming update. After this I plan on getting back to the rest of my Android todo list.
Also Android users, log-based 0-60 timing is ready to go for vehicles that support the MPH output. For now the fastest 0-60 time is displayed whenever you tap on a log.
Please use the GPS speed if the car is not logging the speed. What else is the GPS currently used for? Either or use OBD2 protocol as all cars work with PID 13 for mode 1
(#4529)
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 03-17-2018, 11:33 AM
No issues with orientation on any of my devices. Did you enable orientation lock by chance?
Originally Posted by WaqasRiyami
Device: Galaxy S8
OS: Android 8
App build: JB4 A219
Kit Revision: Rev 3
A223 is the current build. Includes:
*New BT libs (only supports Rev 3 kits at this time, adding more support over the weekend).
*Best 0-60 calculation display when a log is selected. Only works if your car supports the mph output param.
Let me know if any of you run into issues on A223.
No point in GPS as your phone's GPS refresh rate is 1hz and even paired with the accelerometer won't necessarily lead to accurate speed timing. I have zero CANbus/OBDII control as all of that is handled by the JB4 itself.
(#4530)
Default 03-17-2018, 11:41 AM
When will KM timings be available for the 0-100 runs ? Why do you only support MPH ?
(#4531)
BlackB's Avatar
BlackB BlackB is offline
Car: BMW e92 335i
Default 03-19-2018, 04:04 AM
After the last update of the app (which in my opinion took place automatically at the end of January), I do not get display results for the ethanol content (now called e85), trans temp, water temp or mph. I know ethanol and trans temp are used to indicate, but clearly not anymore. I've noticed that there are a few new "bits" in the WMI category, but I do not know what settings to use.
JB4 G5 Map6+7/BT Rev.3 Android/MHD V8.0 S2+E85+BEF/Wagner FMIC/BMS WMI CM10/RB Ex.PCV+Mishimoto OCC/Oil Cooler+Mocal Valve+Stead Line+BMS Billet Oil Filter Housing/BMS N54 DCI o. SIMOTA Intake/MMP ALU In+Outlads/MMP S3 Turbo/BMS OCC/Precision Raceworks Ignition/NGK/M3 Cowl Filter/BMS ALU Chargepipe/Phoenix Racing Port Intake JB4 PI Module+Fuel Line Y-Adapter+Ethanol Sensor/Fuel IT S3+Hobbs switch12.5Psi/6AT Oil Cooler Xhp/Wavetrac/Powerflex/H&R/M3 Suspension Parts/B16 PSS10/N20 T MAP.
(#4532)
SilverJester SilverJester is offline
Car: 2007 335i Coupe
Default 03-22-2018, 07:38 AM
Yes I've noticed my ethanol content (now called e85) is always 0 now. I know there were lots of updates to both the JB4 itself and the mobile app regarding calculated ethanol (Virtual Sensor), but I have an ethanol sensor and would like to get it working again. I tried turning on "bit1: JB4 15/16 FlexFuel Input" but that didn't seem to do anything. What do I have to do to enable my sensor again?
2008 335i MT
VRSF Inlets | MMP Outlets | VRSF Chargepipe | Turbosmart Race Port | VRSF DownP***s | VRSF 7" FMIC | BMS DCI | BMS Cowl Filters |Spec 3+ Clutch | mFactory Flywheel | UUC SSK | UUC DSSR | Rouge Engineering Trans Mounts (Best Mod Ever) | TWM A6 Leopard Shift Knob (1.07lbs, 2nd Best Mod) | Boost Concepts FPM-1 | Fuel-it ES-1 |JB4 G5 ISO | MHD Flasher
(#4533)
Car: 2008 135i
Default 03-22-2018, 05:21 PM
I can add in a toggle to for metric speed timing.
No issues on my end, but I'll test again on a few devices to verify.
(#4534)
Car: 2008 135i
Default 03-22-2018, 05:22 PM
I'll be updating my server code over the next day so bear with me if there are any interruptions in service.
(#4535)
phoebee phoebee is offline
Car: 428i
Default 03-23-2018, 12:30 AM
Please update JB4 Mobile for IOS.
I need to click for map change like android(current ver.)
IOS still very uncomfortable change map now.
Please.......
F32 / 428i / 2014+ewg / N26 / 93octane / all stocks / JB4mobile rev.3 on iPhone
(#4536)
Default 03-23-2018, 12:32 AM
I can add in a toggle to for metric speed timing..
Please Do that.Alot of us using Metric timings.
(#4537)
S3nder S3nder is offline
Car: 135i e82
Default 04-03-2018, 01:03 PM
Device: Example iPhone 5S or Galaxy S4
OS: 11.3(iOS)
Engine type: N54 E Series
App build: Jb4 8052
Kit Revision: Rev 3
JB4 Firmware Version: n54 g5 Mac 134
Problem experienced: Hi . How Do i See up email account to send logs via email ?
(#4538)
Default 04-03-2018, 01:47 PM
We need a toggle for metric speed timing
(#4539)
joeinsd joeinsd is offline
Car: 2010 e92 335i msport
Default 04-04-2018, 08:52 AM
OS: 11.3(iOS)
App build: Jb4 8052
Kit Revision: Rev 3
Set the email account up in the phone’s native email app. Once it’s in there, you’ll be able to use it in JB4
(#4540)
Car: 135i e82
Default 04-04-2018, 10:40 AM
Yes finally got this
(#4541)
135BMWAddict's Avatar
135BMWAddict 135BMWAddict is offline
Car: 2009 135i
Default 04-04-2018, 11:02 AM
@Dmac
Hopefully the server code update went smooth.
When do you plan to release the next iOS update for the app(looking forward to some of the fixes)? Also is there any way to get on a BETA release to help you test?
Mods
- ST GTX3582R, JB4+BEF, PI, Stage 3 Fuel, E80
(#4542)
Flyknit Flyknit is offline
Car: 440i GC
Default 04-11-2018, 06:24 AM
I have issue with my JB where the map gets reset back to map 0 intermittently after a short while. I posted the issue in another thread (http://www.n54tech.com/forums/showthread.php?t=52506) but was suggested to post in here.
Will someone able to help assist or advise? Many thanks.
(#4543)
Car: 2008 135i
Default 04-11-2018, 09:45 PM
Please.......
That should be enabled by double or triple tapping a map gauge.
Working on it.
Originally Posted by 135BMWAddict
@Dmac
Went through fine luckily. . I'm in the middle of another behind the scenes update for both iOS and Android. Got stuck remedying another Android issue so once that's resolved I'll be back on track for the next public release. Just email me (orders@jb4connectkit.com) and I'll send you an invite.
Believe we've been speaking via email, but if not send this to me (support@jb4connectkit.com).
(#4544)
Bullitt1841's Avatar
Default 04-11-2018, 10:04 PM
I have been having this issue for several months now. I believe it is a communication issue between the Bluetooth module and the app. I seem to only get it at very light throttle.
(#4545)
Car: 440i GC
Default 04-12-2018, 07:45 AM
How did you resolve this issue? I leaving JB4 as map 0 for now and thinking of taking out JB4 due to this issue as I don't want to keep setting the map each time I start up my engine.
Also, sorry for the noob question but I'm wondering how is this related to the Bluetooth module. I'd have thought this is the JB4 unit itself that stores the map and bluetooth module is just to enable the communication with the app. My map get reset even when I don't have the ios app running.
(#4546)
Default 04-12-2018, 09:31 AM
Putting it back into whatever map you want seems to work just fine. However it will keep getting the error because the app "sees" a map value of some random number, gets confused, then automatically switches to Map 0. I believe this is built into the app by design. Donnie (the developer) told me it must be getting the communication corrupted somehow, but at (seemingly) random times.
If you don't have the app open and in the foreground, it won't ever switch. Therefore (in my case at least), I think it is related to the Bluetooth module and/or the app.
I could be wrong, though, and it is very interesting that both of us have the B58 engine. That could be pointing to something else.
The JB4 will run perfectly fine on its own, though. So don't take it out just yet!
(#4547)
Default 04-12-2018, 10:27 AM
Please.......
How come you're so adamant about changing maps on the app? Do it on the fly with the steering wheel controls. Takes literally 2 seconds.
By the way, Donnie, appreciate that you updated the map selections (and other areas) to be bigger now!
(#4548)
Car: 440i GC
Default 04-12-2018, 04:53 PM
Thanks. Let me try set the map to map 1 and monitor (by not running the app at all). I guess you can only tell whether it reset back to map 0 by looking at the dash during engine start up.
Friend of mine 340 (B58 also) also encounter the same issue.
(#4549)
Default 04-12-2018, 05:30 PM
Definitely does not take 2 seconds on the F-series...
(#4550)
Default 04-12-2018, 05:32 PM
Interesting. Might be something with the B58 firmware.
Closed Thread
