Default JB4 N54 Hybrid Turbo Setup Directions - 09-01-2015, 08:14 PM
We're going to use this thread to keep notes related to setting up OEM modified twin turbos (e.g. hybrid turbos) including RB, PURE, Vargas, Hexon, etc. Feel free to post questions as you have them and I'll work on updating the post with answers as we go.
Basic setup notes:
1) Larger than OEM turbos require a back end flash map to be loaded via the BB free software or MHD software.
2) You'll need a 3.5bar TMAP sensor to allow proper boost control above the 20psi factory TMAP sensor limit. The required adapter and part number are both here: http://www.burgertuning.com/N54_JB4_upgrades.html
3) We strongly suggest a BMS OCC, BMS vacuum side OCC or replacement PCV, and a high flow inlet system with larger turbos.
4) Use the flash map that most appropriately matches the octane to be used. For pump gas no meth use PUMP, for pump gas with meth or light E85 or race gas mixtures use RACE, and for 40% E85 or more use E85 HYBRID map.
5) For E85, no meth, TBI or port injection is required to supplement the high pressure fuel system. At a minimum Fuel-IT Stage1 low pressure upgrade is required and in most cases with E85 a Fuel-IT Stage3 low pressure upgrade is suggested.
6) Larger turbos require special duty bias adjustments to get boost on target. Note default settings below as a starting point. FUD/Options bit6 (disable RPM FF gain) must be turned on. Duty bias starts at 50 and ramps up to 68 at 7000rpm. This profile is a good starting point for all hybrid turbos.
7) We suggest starting with a lower map like map 2 to evaluate boost control and then working up from there.
...Will add more as we have it! Feel free to direct any hybrid turbo tuning questions to this thread and Steve, Jon, or myself will answer.
Newguy123's Avatar
Car: 12' 135i
Default 09-01-2015, 08:19 PM
This makes me wish I bought an N54
18í Glacier white RS3
#PURETURBOS
#FUELIT
gunda gunda is offline
Car: BMW 335i E92
Default 09-01-2015, 09:32 PM
Awesome idea Terry, this will be very helpful and probably cut down the amount of questions people have when upgrading there turbos.
BostonBeemah's Avatar
Car: AW 135i
Default 09-01-2015, 10:06 PM
Gotta love the updates and support!!
RIP 2008 AW/BL 135i
firemanjust1's Avatar
firemanjust1 firemanjust1 is offline
Car: 2008 BMW 335xi
Default 09-01-2015, 10:46 PM
I look forward to some good info here great idea Terry.
JB4/G5 ISO ,AR DP,BMS DCI,NGK 5992 BMS Meth kit dual nozzle CM 7 & 5,VRSF 7 IC, Stett chargpipe, E60 mix, 255 Walbro, Bms Race flash. RB turbos , VTT inlets ,BMS OCC, 3.5 N20 sensor, Conti DWS
Default 09-02-2015, 09:49 AM
The thread will come in handy as I'm working on some hybrid specific spool up code changes right now. Could use a few logs from various hybrid turbos in say 4th gear starting at 1800rpm. You can stop around 4000rpm or whenever boost is fully on target.
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 09-02-2015, 06:24 PM
subscribed! Great thread Terry!
Looking forward to seeing your advancements for point #6.
Will 3rd gear logs not suffice?
deltalima0's Avatar
deltalima0 deltalima0 is offline
Car: 07 BMW 335
Default 09-02-2015, 06:31 PM
Terry I can do whatever testing you need, just say what you need logged.
Regular RBs with thrust upgrade, TFT inlets, HFS meth kit 100% meth, FBO, JB4 G5/BMS E85 flash/MHD E60 blend stg 2 LPFP.
2011 335is DCT
Pure Stage 2 Hi-Flo Turbos | PSP outlets | RB Inlets | Wagner Evo 2 intercooler | Wagner Dpipes's | JB4 G5/MHD| Precision Raceworks Coils |PFS Bucketed Double shot LPFP | Phoenix Charge Pipe with Tial BOV | JB4 G5/MHD | BMS DCI's
RIP 2007 E90 335i
Doc Race 6266 Single Turbo | TFT Charge Pipe | JB4 G5/MHD | FuelIt stg 3 LPFP | Cpe/BMS PI | 100% E85 | DSS Axles | Cpe FMIC | Tial BOV
N54 World Record ET: 10.721 | Best MPH 130.92
Default 09-02-2015, 08:31 PM
OK cool drop me a note and I can shoot something over to test.
Default 09-04-2015, 08:11 AM
Thanks for the logs on the test firmware. During spool when boost is more than 3psi below target it holds PWM at 100%. We've found this to be the perfect balance between spool speed and over shoot.
Next up I'll email you about redoing duty bias using a new function that lets us eliminate the unevenness in the FF curve.
Trickcruiser's Avatar
Default 09-04-2015, 07:09 AM
Subscribed!
Eristoff's Avatar
Eristoff Eristoff is offline
Car: BMW e92 335i n54 coupe (2006)
Default 09-04-2015, 07:58 AM
Nice Have a friend who can test the new stuff. European car. Email me if you want tiagobaloca@gmail.com
E92 335i coupe 10/2006 @ BMS DCI ; JB4 G5 ISO ; AR Design 3" DPīs ; APEX EC7 18" wheels ; BMS OCC ; BEF ; MMP inlets & outlets ; RB PCV valve ; Vibrant ressonators
Default 09-05-2015, 09:27 AM
Here is the same car using the new larger turbo duty bias logic. Basically this removes any RPM gain from the duty bias calculation and lets you enter the RPM based gain manually. The benefit is this eliminates jagged FF steps you'd see between RPM break points. Those are caused by the JB4 mapping doing one thing and the manual FF bias adjustment doing another between the 500 rpm break points entered.
Disable FF gain is within the FUD bits options.
On the test car this was done with duty bias all set to 50. It's on RB turbos with inlets and those work pretty well with no RPM gain due to reduced back pressure. But you can see PWM trending up slightly relative to FF so we'll add 2 to each position starting at 4000rpm to trend FF up to match. Also note there is an EGT calculation based decay rate built in to FF which is why you see it trending down as the run continues.
Default 09-06-2015, 08:28 AM
Adjusted his duty bias slightly with the FUD = 95 option and PWM and FF are now moving nicely together. We scaled everything up to 60 instead of the default 50 as with the 3.5bar TMAP sensor his FF was sitting close to 150 and out of range. Shifting everything up 10 on duty bias allowed FF to get down to 130 allowing for both upward and downward movement in the future.
Bullitt1841's Avatar
Default 09-06-2015, 09:47 AM
This looks promising, Terry. But what about the slight overboost causing throttle closure right after boost meets target? I'm getting the same thing with the old Duty Bias tuning method. Haven't tried the new method just yet.
Default 09-06-2015, 12:15 PM
That just tells you the spool up and boost targeting is working well. Throttle movement of less than 30% is rather irrelevent. If you spend all day trying to to tune that out you'll be going slower in the long run. The best way to "fix" it would be a manual FUA setting to reduce the throttle safety. Which I would not suggest either unless there is some good reason to do so. As a general rule most of you guys worry much more about throttle than you should. It's like the "hot air intake" myth of tuning. It has to close 40% or more for more than a second or two before you even start to notice a torque output change on a dyno chart. Yet people will dramatically dampen their performance just to avoid even minor movement. It makes no sense.
Default 09-06-2015, 12:29 PM
I could care less about the throttle actually closing that amount. I was just curious about the overboost, which for me causes timing delay and fueling problems with high E85 mixes.
Default 09-06-2015, 01:41 PM
You will need to evaluate your logs and adjust your duty bias by RPM settings as needed for your specific tuning objectives.
miksebik miksebik is offline
Car: E92 335i
Default 09-07-2015, 12:58 AM
Terry, I have ISO 31.1, will update it today.
With Hexon RR500 the power surges too abruptly, the car is much more wild than is sometimes convenient
Today I will send you the log on 4th, from 1800rpm, OK?
E92 335i N54, Hexon RR500, JB4, DCI, MMP inlets, ER chargepipe, Turbosmart Kompact Dual Port BOV, ATM IC, Wagner downp*pes, MPerformance exhaust, oil cooler, trebila flash (via MHD Flasher), E60, M Performance 370mm brakes, styling 313 wheels, M Performance suspension, Fuelit Stage2, MFactory LSD, MFactory SMWF
TN54's Avatar
TN54 TN54 is offline
Car: N54
Default 09-07-2015, 02:09 AM
I like this thread. Good information for bigger turbos
Certified Australian 335i N54 2009 DCT | JB4 | FBO | E85
Car: E92 335i
Default 09-07-2015, 06:27 AM
So here it is: log on 4th 1700-4000rpm, Raceflash and map2.
Hexon RR500.
Default 09-07-2015, 09:03 AM
Hexon RR500.
Looks pretty tame to me? Shrug. If you are talking part throttle then log that, uncheck view WOT only to log part throttle. Given how low PWM is at 17psi you probably need a lower menu 12 setting. Something like 2000rpm.
Car: E92 335i
Default 09-08-2015, 12:02 AM
OK, thank you. I will try to change the menu 12..
What I wanted to say is that with the new ISO 31.x the car behaves like never before. For example on 1st or 2nd gear, when accelerating hard, the car literally jerks as the DTC overreacts (even with DTC button pushed once, I do not have balls to turn it off completely). Before, it slowed down the car a bit but it was not so abrupt. Like hitting something, you know..
I thought this is more ISO31 related than "request support"
ftl135i ftl135i is offline
Default 09-07-2015, 12:22 PM
Hi Terry .
I run fbo+meth+mmp inlet+rb turbo stage 2 and I have the map sensor 3.5.
I am targeting 28 or 30 psi
So what I have to do
Default 09-07-2015, 12:42 PM
What fuel? Load the race back and flash and start by logging map 3 with a 50 additive to evaluate it.
