Prtyper Prtyper is offline
Car: 15 bmw m6
Default jb4+wmi+******* ** s63tu map 8 - 06-13-2018, 09:15 AM
attached is a full throttle log.. from 20-120mph.. im not sure everything is running as it should. car drives fine. just want to double check.
Default 06-13-2018, 10:51 AM
You should update your JB4 firmware
http://www.n54tech.com/forums/showthread.php?t=31292
It looks like methanol isn't fully spraying, there might be air in the line you will need to purge.
You are overboosting that's why throttle is closing, you should lower FF to 80.
What are the mods and fueling?
Kraest Kraest is offline
Car: 2013 535i
Default 06-13-2018, 11:02 AM
Holy Throttle Closure, Batman!
2017 Porsche 718
SOLD 2016 BMW M3
Silverstone II Metallic | Sakhir Orange Interior
JB4, BMS E85 IGN BEF, E85, | 7.36 60-130
SOLD 2008 BMW M3
SOLD 2013 535i M-Sport
Pure Stage 2 Turbo @ 22 PSI | VRSF Ca+Less D0wnPipe | ER Aluminum Chargepipe| Custom Exhaust| GFB DV+ | Upgraded F10 Turbo Inlet | N20 3.5 Bar TMAP | 40% E85/93 Octane Blend | BMS FSB Meth Kit w/100% Methanol Injection | Trebila BEF | JB4 with PWG ISO Firmware | BMS Intake | Stock Fuel System
Car: 15 bmw m6
Default 06-13-2018, 11:32 AM
ive been driving like this for about a week now..i press purge jsut to make sure the meth is fllowing through the lines and it looks like it is. could it be one of my lines are kinked? in what menu can i lower the FF to 80? using the jb4 mobile app. also, if i update will i lose my CEL delete? also my mods are *** less down p ipe full exhaust, bms charge p ipe, bms in takes and bms methanol kit..i apologize if its hard to read..this site blocks all of the words. i am using 93 octane
Drag_n54's Avatar
Drag_n54 Drag_n54 is offline
Car: '09 BMW 335i
Default 06-13-2018, 12:16 PM
It's under user adjustments. Hopefully you're purging with the line disconnected at the nozzle
F30 335i PWG AT l MHD Stage 2+ E30 l WMI l VRSF D.P l VRSF FMIC l VRSF C.P l FTP Outlet l FTP Inlet l GFB DV+ l OCC l NGK 97506 .020 l Stage 2 LPFP l Resonator Delete w/ Stock Muffler
Car: 15 bmw m6
Default 06-13-2018, 12:41 PM
i was not aware of this.. i will do it when i get home.
Car: 15 bmw m6
Default 06-13-2018, 05:08 PM
I did another run. After setting FF to 80..and disconnecting the meth lines at the nozzles and purging the system until no bubbles were visible.. here were my results
Car: 2013 535i
Default 06-13-2018, 06:41 PM
Bad capture.
Looks like you logged the car decelerating
2017 Porsche 718
SOLD 2016 BMW M3
SOLD 2008 BMW M3
Default 06-14-2018, 10:02 AM
Nothing in the log.
