drdiabetes drdiabetes is offline
Car: bmw 335i e92 AT
Default Best set up for single 6466?? - 01-22-2019, 11:40 AM
Hello I am from Argentina.
I am planning to go into single turbo.
I chose doc race 6466 single turbo kit.
Here we don't have e85 so after doing reserch and talking with fuel it and doc race decided to buy fuel it stage 2 lpfp and direct port injection kit for methanol with 750cc injectors.
I also chose MHD flash and xHp flash for the AT
I am not built engine.
Stock exhaust . Should I go at least straight midpipes??
Does anyone have similar setup?? Suggestions???
How much power is it capable of? I saw too many n54 6466 but most of them run e85.
Thank you very much
Wink 01-22-2019, 02:47 PM
Thank you very much
You mean JB4 AND MHD for the BEF, right?
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 01-23-2019, 07:54 AM
Yes I do dave
tisdrew tisdrew is offline
Car: 2009 e90 335i 6MT
Default 01-23-2019, 11:58 AM
Thank you very much
Depends how much meth you're comfortable spraying. 500 any day of the week. Unlikely you'll hit 700 on just pump+meth.
N54MoreBoost N54MoreBoost is offline
Car: 2007 335i Sedan
Default 02-05-2019, 01:00 PM
I made 440 wheel on a doc race 6466 93 octane running off the wastegate spring. 540 with agressive timing 20psi and blew the stock motor. Both runs factory exhaust same day dynojet. Hope this helps
2007 335i AT Sedan | Doc Race 6466 | Fuel it Stg 3 Lpfp | VRSF 7' FMIC | JB4 G5 | MHD| VRSF Charge pipe w/ Tial BoV | XHP Stg 3 Flash
